Old Oct 09, 2008, 04:36 AM
Cameras are EVERYWHERE...
tvdude310's Avatar
Los Angeles
Aiptek A-HD+ for FPV (and any off topic drivel)
Hello-
I'm starting this thread to help develop the Aiptek A-HD+ 1080p camcorder for use with FPV.
This camera records in HD while sending a standard definition signal (480 lines) out it's A/V jack. This SD signal can be used as the FPV downlink.
The Aiptek is no super broadcast-quality camera by any stretch of the imagination (at $150-$200, how could it be?). But it does make some very nice movies. At full 1080p, it suffers from motion artifacting. But at 720p/60 it looks really good for a cheap HD camcorder.
It records to SDHC cards, up to 32gb. Faster cards make a big difference here, so don't cheap out. A 4gb card can hold around 1-2 hours of HD at 1080 or 720/60, and 3-4 hours at 720/30. (These are just rough numbers)
One of the biggest problems when using this camera for FPV is, "how do you pan and tilt it?"
It's been done, but it sure didn't look easy. I wondered if the camera module in the camcorder could be separated and extended on a ribbon cable, so I completely disassembled mine. Voila! It's not that hard.
Now the idea is to find the right connectors and cable to make the adapter cable.
And we can all be the "HDFPV" guys since our videos will always be in HD.
Questions, comments, suggestions and one-liners all welcome.
tvdude310 is offline Find More Posts by tvdude310
Old Oct 09, 2008, 04:52 AM
Closed Account
Joined May 2007
Well done Rob, look forward to seeing if you can source the extension cable, or components to make them.
Ive just put my Aiptek pan/tilt version 2 on hold.
What a difference a day makes, this is the way of the future for fpv, lol.
cheers.
Wobby is offline Find More Posts by Wobby
Old Oct 09, 2008, 05:18 AM
Kildare, Ireland
Joined Jul 2008
Has anyone run their Aiptek off their flight battery?
pajo1981 is offline Find More Posts by pajo1981
Old Oct 09, 2008, 05:40 AM
Johan Moelich
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
If you have some old broken laptop or hifi lying around, there should be some ribbon cable inside, if you can't source it somewhere else. I always keep boxes full of broken electronics around "just in case".
Moelich73 is online now Find More Posts by Moelich73
Old Oct 09, 2008, 06:47 AM
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
Does anyone know what type of connector that is? I'd bet it is available from a standard electronics distributor like Mouser, Digikey, Allied, etc.
The ribbon cable is probably available too! This is VERY interesting!
Can you get some close-ups of the ribbon cable and connectors?
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
Old Oct 09, 2008, 06:59 AM
hoysome's Avatar
Alberta, Canada
Joined Jun 2008
I would probably advise against using a ribon cable. you need to be able to get a ferrite ring on it as close to the camera as possible. Ive seen the insides of some of theese types of cameras before, and those with the camera not directly connected to the main board Always have a ferrite ring on their cable. You can use a bundle of small wires to the same effect as a ribon cable anyway
hoysome is offline Find More Posts by hoysome
Old Oct 09, 2008, 07:38 AM
FRANCE
Joined Feb 2008
hello,
what if you use a piece of mirror instead of pan/tilt the camera ?
rbsense is offline Find More Posts by rbsense
Old Oct 09, 2008, 07:42 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
How many wires do you need? A network cable has 8 if I remember correctly. Or a telephone cable can also work.
Old Oct 09, 2008, 07:43 AM
hoysome's Avatar
Alberta, Canada
Joined Jun 2008
mirror will show the image backwards and upside down. the upside down can be fixed by placing the camera at another angle, but backwards is unfixable untill post processing.
bestview: Alot.
Old Oct 09, 2008, 07:44 AM
Kildare, Ireland
Joined Jul 2008
A mirror- that's an excellent idea! Point the camera backwards at a P&T mounted mirror...
Old Oct 09, 2008, 07:46 AM
Kildare, Ireland
Joined Jul 2008
My IF-OSC has an option to mirror the image. The Aiptek has no such option I suppose.
Old Oct 09, 2008, 07:47 AM
Kildare, Ireland
Joined Jul 2008
bestview: Alot.
A mirror won't show the image upside down just backwards.
Joined Sep 2007
I would be interested in how long it takes for the
picture to travel trough the cam (from lens to AV).
Even a relatively short delay can be verry annoying...
kaback is offline Find More Posts by kaback
Old Oct 09, 2008, 08:04 AM
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
I've ordered connectors for the camera from here:
http://www.4uconnector.com
Look under "Board to Board" connectors. I ordered a bunch of samples to see which one would be the most appropriate to use for the camera. Just waiting on them...
docphi is offline Find More Posts by docphi
Old Oct 09, 2008, 08:11 AM
kestasxxx's Avatar
Baltic States
Joined Jun 2008
bestview: Alot.
In my aiptek camera I find silicone.Remove camera not imposible.
kestasxxx is offline Find More Posts by kestasxxx
Discussion Need help with Aiptek wiring harness for FPV & flight recording MinneFlyer Video Piloting (FPV/RPV) 5 Oct 08, 2008 11:53 PM
Question Aiptek A-HD 720P for FPV? anci3nt Video Piloting (FPV/RPV) 17 Mar 02, 2008 02:23 AM
Cool Off topic use for my new Aiptek English Electric SCRAPS (Southern Counties Radio-control Aerial Photographers) 3 Oct 03, 2006 04:39 PM
