Old Oct 08, 2008, 04:00 PM
tacchino is offline
Find More Posts by tacchino
Trying to build & to fly
tacchino's Avatar
Italy
Joined Sep 2007
Build Log
FunBuild 2 - Reggiane RE2005 'Sagittario'
This is my entry for my very first contest, and also for my fourth balsa build. I do not know how I will do it, but I'll try because of the first word of the contest name: Fun.
I'll try to build a Reggiane RE2005 'Sagittario'. It's a rare, yet very nice, Italian WWII fighter, built in 30 pieces or so.
You can information in many places: here , and here , for example, while here you can find some color schemes.
As far as I understood, there are no kits, but the few I built has been almost always from plans (with only one notable exception ), so also this one will be from a plan: this one , modified and enlarged by an user of the italian Baronerosso forum from a glow combat version plan by Animor Dobrovich.
As I do not like easy things, I'll follow partly the modified plan, but most likely with the combat size, i.e. 91cm wingspan. Furthermore, I would like to cover it with modelspan or oracover and not with balsa, to make it lighter and slower (for my thumbs).
Now I'm finishing a DVII , then I'll clean up my table and start this one. No hurry.
tacchino is offline Find More Posts by tacchino
Old Oct 08, 2008, 04:07 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
tacchino ,
Nice choice ! Looks like the Me109 had a lot of influence on the designer .
Great to have you aboard the FunBuild and looking forward to you build . What is the size ? , and any ideas on a power system ?
Thanks again for participating ,
-John
jofrost is offline Find More Posts by jofrost
Old Oct 08, 2008, 04:17 PM
W@CC0 is offline
Find More Posts by W@CC0
The wings are not on fire
W@CC0's Avatar
Duffel - Belgium
Joined Jan 2004
Hey, cool, a Sagittario
Very good choise because it is a great looking plane. And I am pretty sure it will become a great flyer
If you choose for the 3th plane on profiles in one of your links I can provide you with image files for the faces on the fuselage, the scarecrow and the emblem on the tail.
Good luck on your build
I'll be following this with interest
Tom
W@CC0 is offline Find More Posts by W@CC0
Old Oct 08, 2008, 04:22 PM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
[QUOTE=jofrost]tacchino ,
Looks more like they took a Seversky P-35 and mounted a Daimler-Benz engine to it... Same tail planes, same wing. Just a little cleaning up, around the cabin area.
challenger_i is offline Find More Posts by challenger_i
tacchino is offline
tacchino's Avatar
Italy
Joined Sep 2007
Originally Posted by jofrost
tacchino ,
-John
You convinced me...
I perceive the Sagittario as similar but more roundish than the Me109, but I'm not able to explain exactly why.
The most likely size, as I mentioned, will be 91cm wingspan (about 35"). But I'm not sure yet, I have to look at plans, and try to understand what is better for me (I prefer to build small).
Regarding the power system, I'm a beginner (or so), so I do not know what weight I can expect (from balsa), and also is my first warbird - which I would prefer to be slow, for my kind of flight.
I'll ask support here to choose, when it will be the time.
Old Oct 08, 2008, 04:27 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
A very good airplane to model! You will get all the help you need from the other builders here. It may be a contest, but everyone wants everyone else to do well!
I agree with your choice of size. ~90cm will keep the price of materials low, and it can be flown nearly anywhere.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
tacchino is offline
tacchino's Avatar
Italy
Joined Sep 2007
Tom, Challenger, (EDIT: and Geoff!) thanks for the interest: I can tell I'll be slow, so be patient with me.
Tom: I still do not know which I'll do, but surely part of choice will be made basing on the availability of pictures for decals (I have somethng already), so thanks for the offer.
Old Oct 08, 2008, 04:42 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
tacchino ,
At 35" span should still be fairly light . A lot will depend on construction method . Will it be stick and tissue type construction ( lighter ) or fully sheeted ?
A lot depends on how you want it to fly , and the type of conditions you usually have to fly in . I like mine to be able to at least handle a light steady breeze , but have very limited field size so I also tend to build smaller and lighter .
-John
Old Oct 09, 2008, 12:44 AM
tacchino is offline
tacchino's Avatar
Italy
Joined Sep 2007
tacchino ,
-John
stick and tissue, although the original design is for fully sheeted. I could also reduce to 30", but at that point perhaps will be more difficult to fly.
I fly in a small field close to my home, alone, and by the way I'm not a good flyer, because I fly only to test what I built. So my thumbs are still rough.
By the way, have also other very detailed material, perhaps more useful for a real scale build: http://sobchak.wordpress.com/2008/02...05-sagittario/ and http://www.airwar.ru/other/draw/reggianere2005lk.html
Old Oct 09, 2008, 03:55 AM
W@CC0 is offline
W@CC0's Avatar
Duffel - Belgium
Joined Jan 2004
tacchino ,
That is because the Re.2005 was based on the earlier Re.2000 series of aircraft. And the designer of the Re.2000 based his design on the Seversky. Therefor, it looks very similar. The wing of the 2005 was enlarged and a DB 605 was used instead of the radial or other DB's on earlier versions.
Tacchino,
If you go for a +/- 30" plane that is fully sheeted, ask some advice from thomanie. He has an excellent FW190 at that size in the same construction method and he has build some other warbirds too. He might have an idea for a good power combination, battery, prop etc.
And here at the website of tdm models are also a lot of 30" warbirds with information about weight and power setups.
Tom
Old Oct 09, 2008, 07:17 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
The fuselage of the sagittario is all compound curves, so stick and tissue will be easier than a sheeted build. I think its one of the most attractive planes of WW2. Here's a pic of my 1.4m span version.
Scaledown is offline Find More Posts by Scaledown
Old Oct 09, 2008, 03:44 PM
tacchino is offline
tacchino's Avatar
Italy
Joined Sep 2007
Tom: thanks for the link, I also found one interesting thread by thomanie . However, if not necessary, I will avoid full sheeted construction.
Scaledown: really nice, do you have some thread about it, or photos?
Old Oct 09, 2008, 03:51 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
tacchino ,
You can always add more stringers to take away the starved horse look.
-John
Old Oct 12, 2008, 06:50 AM
Scaledown's Avatar
Joined Sep 2004
Painting it in matt colour also makes the stringers less noticable.
No I didn't do a build thread on mine, I wasn't registered with RCgroups at the time. Its in semi retirement these days. Spectators usually thought it was a messerschmitt or a spitfire!
Old Oct 21, 2008, 01:32 PM
tacchino is offline
tacchino's Avatar
Italy
Joined Sep 2007
Very first step
Finished (almost) my DVII , and printed plans for this one (the combat version: this will be the size I'll do, but with rounded fuse).
Discussion FunBuild 2 - Hafke GeeBee E portablevcb Scale Kit/Scratch Built 101 Nov 25, 2009 06:43 PM
Contest ***FunBuild 2 Contest ***Winner Announced*** jofrost Scale Kit/Scratch Built 75 Sep 29, 2009 04:45 PM
Contest FunBuild 2 - 30" Earl Stahl Albatros DVa...It flies!!! jofrost Scale Kit/Scratch Built 103 Aug 31, 2009 08:25 PM
Discussion Funbuild 2. 1/5 Scale Sig J3 Cub kit build RyanPSU21 Scale Kit/Scratch Built 83 Jun 23, 2009 09:28 PM
Poll Interest in a Funbuild 2***Update*** jofrost Scale Kit/Scratch Built 110 Oct 02, 2008 03:43 PM
