Old Oct 08, 2008, 12:35 PM
rc-conk is offline
Find More Posts by rc-conk
free iphone check my blog
Joined Sep 2008
which type of engine is better high kv or low kv
hi
i was wondering what the difference between 2 motors are
say i had a low kv electric motor turning a big prop
and a high kv motor turning a small prop
which would be best for a helicopter and plane
if i was using 2
thanks
rc-conk is offline Find More Posts by rc-conk
Old Oct 08, 2008, 12:37 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Heli's are geared so folks use higher Kv motors for smaller heli's up to say 450 class. As you get into larger heli's you will start using lower and lower Kv because of the gearing.
Planes can go either way, low Kv for 3D types and high Kv for faster planes.
Hope that helps,
B
fly_boy99 is offline Find More Posts by fly_boy99
Old Oct 08, 2008, 12:38 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
High Kv for helicopter since you are going to gear it very low.
For a plane it depends on the type of aircraft: low Kv/big prop for 3D, kigh Kv/small prop for fast pusher jet.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 08, 2008, 01:39 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most of my fixed-wing models are e-conversions of glow models, from about 5lbs to about 9lbs flying weight. In these I use motors with kv of around 800 or less, which results in a prop size roughly the same as I was using with the glow engines. Motor power, of course, depends on plane weight and the type of flying you want to do.
abenn is offline Find More Posts by abenn
Old Oct 08, 2008, 03:14 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Originally Posted by rc-conk
hi
if i was using 2
thanks
For the plane it doesn't matter. With a low kV motor, choose a high cell count pack, and for the high kV motor use a low cell count pack. In these cases you can use the same size prop.
So for example, 1500kV motor, use 2s pack, for 1000kV motor use 3s pack. Prop size (same for both) needs to be chosen in this example to give a static rpm in the 8-9000 rpm range if you want either to run reasonable efficiently. Efficiency is the same, assuming both motors are wound with the same total weight of copper.
The 2s system will draw more amps and may need a bigger ESC for that reason, but motor efficiencies will be the same (this is about the 5'th time I have typed this, and I am only one of many who try to point this out.)
Alan Hahn is offline Find More Posts by Alan Hahn
Old Oct 08, 2008, 03:15 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Nope. You'll use lower Kv because you will use higher cell count batteries to drive the voltage up keeping the amp draw down.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Oct 08, 2008, 03:19 PM
fly_boy99's Avatar
Depending on your gearing.....
Can't run higher cell counts on a higher Kv motor because your gearing is 1.2 to 1.
Show me a Large Heli which is not geared...
mw
Discussion Pinch Test for High end or Low end settings ?? MITUL Engines 17 Sep 03, 2008 10:08 PM
Discussion High $$$ 20C or low $$$ 12C batteries Milton Batteries and Chargers 11 Jan 08, 2006 05:46 PM
Himaxx 2025 -4200 High Pole or Low Pole Count Baracus Castle Creations 2 Dec 02, 2004 07:28 AM
which one do you like better, the Zero or ME109? jeff262 GWS (Grand Wing Servo) 14 Feb 22, 2004 10:08 PM
