Old Oct 12, 2012, 09:19 AM
Davie79 is offline
Find More Posts by Davie79
Joined Sep 2012
Originally Posted by Throttlejunkie View Post
Awesome mate, you will love it when it is fully modded they are a blast, i need to order some new batteries i took one of my silverlits out the other day with my mate & most of my old batteries are shot so i let him use the couple of good lipo's in his bike & i used my 1/8 bike.
Ill try and get a vid of one bike with a stock battery and one with the lipos to show the diff. I was amazed so much quicker
Davie79 is offline Find More Posts by Davie79
Old Oct 15, 2012, 03:29 AM
Davie79 is offline
Joined Sep 2012
Just went down the netball courts and set up my track. Had to change it a little was a bit to hard with the lipos. After a few little adjustments she went good. Ill try and get my mate with a good camera on the weekend coz I got a few good laps out of it. Starting to get the hang of it now
Old Oct 16, 2012, 06:25 AM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Cool mate.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Nov 26, 2012, 04:06 AM
Davie79 is offline
Joined Sep 2012
Them 45 to 90c lipos have stuffed the stock bikes! To much burst power. Could pull wheelies when I first started useing them. I would flip them if I got on the power to hard out of a corner. Now all I get is a grinding when I pull the throttle on hard.
Old May 17, 2013, 03:41 PM
Syncro is online now
Find More Posts by Syncro
United Kingdom, Walsall
Joined Mar 2013
Well, I'm way too late to the party but I've bagged me a Ducati.
After reading through these pages I'm really looking forward to getting it.
Syncro is online now Find More Posts by Syncro
Old May 18, 2013, 12:17 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Nice ... sone new life for this thread is needed
The best update that you can do, is to replace stock battert with 300mAh 2s LiPo
HK nano-tech 35-70c will fit inside perfectly ...
e_lm_70 is offline Find More Posts by e_lm_70
Old May 18, 2013, 02:36 AM
Joined Mar 2013
Yep thats one of the first things on the list. how do you get around the lack of lipo cut off though? just time your run? Sorry if I missed that in this thread.
I also want to hook it up to my spektrum tx. Pretty straightforward?
Old May 18, 2013, 03:29 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Change RX is not easy ... but possible ... look in the thread ... somebody did it ... for me it is too much work for little advantage
Old May 18, 2013, 03:30 AM
Sydney, Australia
Joined Mar 2010
Yeah it was easier for me to change all the electrics, this is what i used, Losi 1/36 scale 10250kv brushless combo, Hitec nano 35HD servo & a spektrum 3500 micro receiver out of it's case & i use rubber bands for direct steering.
Old May 18, 2013, 05:02 AM
Joined Mar 2013
If that's the case I don't think I'll bother with the RX for the time being.
It was only for convenience and to try and sort the throttle spike I've read about.
Old May 18, 2013, 08:12 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Don't forget to check the polarity of the battery connector.
Maybe they've changed it, but they were reversed from the standard way of wiring JST batteries. If you plug a normal JST plugged lipo in, it will kill it immediately.
Changing the wires over on the new battery pack is easiest, but I've been wondering if it would have been better to do it the other way round.
I haven't used mine in ages. I really must cycle all my battery packs - I stuck with NiMH to go easier on the motor.
Andy2No is offline Find More Posts by Andy2No
Old May 18, 2013, 08:16 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
The throttle spike is not a big issue. Once you get it rolling you can go fast or slow right down and it just feels quite natural after a while.
Big bikes kick when you let the clutch out too quickly anyway. I used to ride quite a small one (my biggest was a 200cc Yamaha RD) and it scared the crap out of me when I tried someone's bigger bike in a car park.
Old May 18, 2013, 08:23 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
The small NiMH packs I've used were from here:
http://www.component-shop.co.uk/html/small_packs.html
I think it was the 210mAh ones... I wrote it up, somewhere in this thread, with pictures. They're the wrong shape but you just cut the plastic and fold at one of the metal joiners between the cells, then tape them. They're a good fit.
That shop is very good for NiMH batteries, and lead acid ones. The postage rates are very reasonable too, and they're pretty quick.
EDIT:
Here you go. I used the 2x2 shaped 1/2 AAA 210mAh packs but the 4x1 shaped packs near the top of that page would probably be easier to cut.
http://www.rcgroups.com/forums/showt...9#post12816314
EDIT2:
Thinking about it, the wiring on the 2x2 packs I used is probably better for this purpose, otherwise you might have to have a wire running down the side of the pack, and you'd probably need to extend it.
Old May 22, 2013, 09:14 AM
Joined Mar 2013
Well, my Ducati turned up. Pretty pleased to say the least. Looks like new. And considering its essentially a 'toy' it's more than I expected. The moving rider is really cool too!
Haven't had chance to try it properly but I charged it up just to see if all was well and to start with the throttle was stuttering quite a bit but I let it run enough to flatten the battery again and it seems fine. Maybe it was in storage for a while? Looking forward to giving it a proper run anyway.
Old May 22, 2013, 09:54 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Yes it could be some dust or oxidation on the brushes of the motor ... so after a run you may got a more clean contact ...
1/3 scale Tyco r/c motorcycle! Kmot Motorcycles 158 Dec 05, 2005 07:31 PM
Am I the Only 1/8th R/C Driver? NitroEvolution Large Scale Cars 17 Mar 17, 2005 05:33 AM
Cheap 25mph R/C motorcycle Setup! sithos Cars - Cars and Parts (FS/W) 2 Dec 04, 2003 07:19 AM
Installing brushless on normal 1:10 R/C car. Any experience? risto Electric Power Cars 3 Mar 20, 2002 11:45 AM
Sceince for kids, sub 1 oz R/C planes aeronutz Scratchbuilt Indoor and Micro Models 3 Dec 17, 2001 04:23 PM
