Old Feb 07, 2011, 04:40 PM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Originally Posted by Jhabhobho12 View Post
Nev, pardon me, I mean is how to disassemble the motor? I can't pull it out.
They are a tight fit, just use a small screw driver & carefully pry it out on each side a bit at a time it should come out.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Feb 07, 2011, 05:34 PM
Nevped67 is offline
Find More Posts by Nevped67
Nevped67's Avatar
Australia Qld
Joined Jun 2010
throttle is the man as his pics are great ! And explanations are better !
Also don't forget the spare parts for your silverlit's here >>>
http://www.extremenitrohobbies.com.a...age=categories
Nevped67 is offline Find More Posts by Nevped67
Old Feb 07, 2011, 05:41 PM
Nevped67 is offline
Nevped67's Avatar
Australia Qld
Joined Jun 2010
Hey jake man , Once u have finished can u put up ur design of frame so we can try to replicate? Also spur gear, and front forks !
Altho i do have paypal LOL that be much easier hehe , I can make an offer only if you would have free time etc bita extra cash is always great right I am patient as well ! I just don't have the tools to try to make'
regards nev
Old Feb 07, 2011, 07:36 PM
Sydney, Australia
Joined Mar 2010
I have been thinking about making a TVP chassis for the silverlit & just use the original front forks & rear swing arm set up i took some measurements the other day i just need to get some alloy plate.
I wonder what the belt & pulley's are off, the rear pulley dos'nt seem to have a guide face to stop belt run off, i hope he can get it up & running it would be good to see.
Old Feb 07, 2011, 10:37 PM
RC flight is offline
Find More Posts by RC flight
RC flight's Avatar
Mississauga Ontario Canada
Joined Jan 2006
Thanks guys.
This is the shaft and pulley that I am using.
http://www.allerc.com/t-rex-tail-dri...ew-p-2168.html
The gear I have is 66T. You can find them at the bottom of this page.
http://www.allerc.com/advanced_searc...sort=3a&page=5
Once I finish it I will take many pics and measurements for you dont you worry lol. I really dont love doing this stuff but I cant help it once I have an idea stuck in my head, I force myself to make it. If you have not seen the "Micro custom bikes" thread I suggest you check it out! It has a few builds on it and lots of info too on what parts to use.
Throttle;
The rear pulley is home made. I molded it and is made of epoxy resin. The belt is from a T-rex 450se heli and has obviously been shortened (I can make around 5 belts for my bike from the one t-rex belt). Today I got the motor mounted on and have tested out the drive system and it all works mint the way it is. The belt has no chance of coming off on its own and if it ever does I would simply make a guide/fence.
Once I finish I will take many pics including the fork disassembled.
Jake
RC flight is offline Find More Posts by RC flight
Old Feb 08, 2011, 01:01 AM
Sydney, Australia
Joined Mar 2010
That's awesome Jake very clever im in awe, i love making & modding stuff as well but like Nev i don't have access to lathes or cnc, just the basic tools at home, yeah i would like to see those forks disassembled were they made on a lathe?
Keep us posted on your progress & can't wait to see it in action.
Cheers Mate.
Old Feb 08, 2011, 01:39 AM
ado1974 is offline
Find More Posts by ado1974
ado1974's Avatar
melbourne, australia
Joined Jun 2009
nice work jake
i think i will have to keep tabs on this thread.
i have done alot of micro helis, but have only just got into rc bikes.
looks like there is alot that can be done ... might have to get a few other projects finished before i start anymore
and i might have some other motor/esc combos that are worth thrying if you need more power
some of the micro heli stuff is the same size as the losi setup... but the losi wont get a heli off the ground. and the good heli setups can do 3D aerobatics
cheers
a
ado1974 is offline Find More Posts by ado1974
Old Feb 08, 2011, 01:41 AM
Nevped67 is offline
Nevped67's Avatar
Australia Qld
Joined Jun 2010
Yes jake that is soo awesome man thanks for sharing , A masterpiece in the making
Old Feb 08, 2011, 10:32 AM
RC flight's Avatar
Joined Jan 2006
Throttle
I don't have access to lathes or cnc either. I just use hand drills, many files, and a very accurate ruler.
1974
Yes there are many micro BL motors out now which is awesome. The 5800kv I have in the bike now seems to have plenty power for the bike on 2s. The losi motor I have was once mounted in my 4#3 heli and worked well. The Helimax BL motors look like they would be perfect for 1:12 bikes but are $40 at my LHS.
Thanks Nevped. Ill take a few more pics some time today. Ill take the fork apart too
Jake
Old Feb 08, 2011, 11:43 AM
RC flight's Avatar
Joined Jan 2006
Here are a few more pics
http://img842.imageshack.us/g/dsc03865x.jpg/
You will see that the fork is simple. The blue on the top of the fork legs is just a locknut that has been mounted on a dremel and filed round and then drilled out. One of them didnt turnout very well for me so I will be making another some time.
Old Feb 08, 2011, 11:50 AM
RC flight's Avatar
Joined Jan 2006
I will soon start my own thread since my bike doesn't use a single part from the silverlit bike..
Old Feb 08, 2011, 04:22 PM
Nevped67 is offline
Nevped67's Avatar
Australia Qld
Joined Jun 2010
We all shall watch that 1 for sure . Looks a bit like M1
Old Feb 08, 2011, 09:07 PM
Jhabhobho12 is offline
Find More Posts by Jhabhobho12
Joined Feb 2011
Hello Nev, good morning.... How are you?
I just want to clear that, if I remove the engine from my bike, can I still use it back or totally garbage? Thanks man.
God bless you.......
Jhabhobho12 is offline Find More Posts by Jhabhobho12
Old Feb 08, 2011, 10:06 PM
Joined Feb 2011
Hi ThrottleJunlie, How's your bike? The Repsol. did you modified it? What modification did you do?
Old Feb 08, 2011, 10:15 PM
Sydney, Australia
Joined Mar 2010
Casey Stoner 2011 One Heart Repsol Honda.
Seeing as how Casey is going to show them how to do it on a honda this year i could'nt resist.
1/3 scale Tyco r/c motorcycle! Kmot Motorcycles 158 Dec 05, 2005 07:31 PM
Am I the Only 1/8th R/C Driver? NitroEvolution Large Scale Cars 17 Mar 17, 2005 05:33 AM
Cheap 25mph R/C motorcycle Setup! sithos Cars - Cars and Parts (FS/W) 2 Dec 04, 2003 07:19 AM
Installing brushless on normal 1:10 R/C car. Any experience? risto Electric Power Cars 3 Mar 20, 2002 11:45 AM
Sceince for kids, sub 1 oz R/C planes aeronutz Scratchbuilt Indoor and Micro Models 3 Dec 17, 2001 04:23 PM
