Old Aug 05, 2009, 11:01 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
The car park visit went well, until the dog walkers started turning up in their 4x4s, spoiling the mood and threatening the life of small motorcyclists.
By the end of four batteries (one stock, three made to fit), I was able to drive it fairly well and do tight figure of eight patterns in the space for parking one car. Like any sort of driving, the trick for turning tight corners is to ease off the throttle as you approach it, then accellerate as you go round it.
The 210mAh batteries I made fit worked well, although they didn't run as long as the Silverlit 220mAh. I guess a slightly smaller battery will always discharge a bit faster than you'd expect, because it will lose voltage quicker trying to drive the same load, plus it has less capacity to begin with.
They may just need some more cycling too. I discharged and charged each one two or three times, but I lost track of where I'd got to in the end. They were plenty good enough, anyway.
Here's the pictures of the extra batteries I folded and taped up to make fit, that I was too lazy to upload last time.
Andy2No is offline Find More Posts by Andy2No
Old Sep 05, 2009, 02:42 PM
Akura2 is online now
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
you did all that paintwork and they actually came out with a Repsol bike
http://cgi.ebay.com/Air-Hogs-Silverl...d=p3286.c0.m14
Akura2 is online now Find More Posts by Akura2
Old Sep 05, 2009, 03:54 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Now that looks nice, will go well with my Ducati, you just got to love these little bikes, if only they did not have that kick when they start up and we could run them with a stick radio.
steve bisco is offline Find More Posts by steve bisco
Old Sep 05, 2009, 05:24 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Akura2,
The Repsol one looks nice. My Ducati is just stock though - no painting. All I've done is make up some spare batteries.... I see, it was Sasori28 who made a Repsol one.
steve bisco,
Getting it started is definitely the hard bit. I don't like the little stand, it's too floppy. I had trouble getting the bike on it because it kept bending wider. I thought of stiffening it somehow but in the end I just held the back wheel off the ground while it spun up then gave the bike a gentle push.
Old Dec 16, 2009, 07:37 AM
canvey island
Joined Jul 2002
Hi just got back into this little bike, bought the Honda now they look so nice, I am happy with the speed on a 2 cell lipo and handling is ok, I just need to get rid of that surge of power when you come off the power on to the brakes then back on the power and you get a massive power surge on a 2 cell and normally a high side Cant find any other transmitter that will work with the bike, kind of dont want to pull the bike apart too much, is there another rx or esc that would fit?
Thanks.
Old Dec 16, 2009, 09:51 AM
Swilson50 is offline
Find More Posts by Swilson50
Dodge City, Kansas
Joined Oct 2003
Where can I get the Repsol
I've got the Ducati and it's great on the patio. Can someone point me to the Repsol. I have not seen it advertised.
Stan in Dodge City (Kansas)
Swilson50 is offline Find More Posts by Swilson50
Old Dec 16, 2009, 12:27 PM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
I've been looking for the honda aswell... found some on ebay... search "silverlit" under "toys and hobbies"... and you should find a couple there...
...Luke...
Lukey B is offline Find More Posts by Lukey B
Old Dec 19, 2009, 08:11 PM
xXJackXx is offline
Find More Posts by xXJackXx
^_^
Geelong, Australia
Joined Mar 2007
I got the Honda from play-asia.com
xXJackXx is offline Find More Posts by xXJackXx
Old Dec 20, 2009, 11:14 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Steve,
I guess you could make a hack with a largish value electrolytic capacitor across the motor terminals. It wouldn't fit inside the bike but could be hidden in a top box or paniers - one capacitor each side, wired in parallel, for example.
That would average out the pulsed output from the ESC and smooth out sharp changes in the voltage. You'd need a pretty big value capacitor to have a noticeable effect though. I expect it would affect braking too (somehow or other).
I tried that with a brushed ESC I was thinking of putting in a boat once. The capacitor got a bit warm - so you need a fairly chunky one, probably rated for twice the battery voltage. It actually boosted the power to the motor... I'm still not sure why, and I guess that effect would depend on the design of the ESC.
Old Dec 20, 2009, 12:08 PM
Maylord is offline
Find More Posts by Maylord
Joined Sep 2008
Thanks.
Hi steve bisco, the original tx is the problem, the customer of silverlit take me some info, and the bike run only with your transmitter, i suggest to change all
put esc and micro receiver for indoor airplane, (any for max5-6gr is good)
The silverlit electronic is bad, the servo have only 16 position and the control not is precise
A good compromise is the mini-z electronic, choise for your run style
Maylord is offline Find More Posts by Maylord
Old Dec 20, 2009, 01:18 PM
canvey island
Joined Jul 2002
Thanks for the reply, but airplane esc have no brakes, I must have smooth brakes and power, can you just buy the mini z electronics on there own.
Old Dec 20, 2009, 01:56 PM
Maylord is offline
Joined Sep 2008
Hi capirex! wow good job!
which is the brand of the body? is by 1:12 new ray?
How to fixed the body in the bike? which esc you use?
congratulations for the sidebar, i thinks run good
Old Dec 20, 2009, 02:04 PM
capirex is offline
Find More Posts by capirex
capirex's Avatar
Joined Jan 2006
Thank you
I use a electronic mini-z + Body NEWRAY
capirex is offline Find More Posts by capirex
Old Dec 20, 2009, 02:11 PM
Maylord is offline
Joined Sep 2008
How to fixed? with screws?
1/3 scale Tyco r/c motorcycle! Kmot Motorcycles 158 Dec 05, 2005 07:31 PM
Am I the Only 1/8th R/C Driver? NitroEvolution Large Scale Cars 17 Mar 17, 2005 05:33 AM
Cheap 25mph R/C motorcycle Setup! sithos Cars - Cars and Parts (FS/W) 2 Dec 04, 2003 07:19 AM
Installing brushless on normal 1:10 R/C car. Any experience? risto Electric Power Cars 3 Mar 20, 2002 11:45 AM
Sceince for kids, sub 1 oz R/C planes aeronutz Scratchbuilt Indoor and Micro Models 3 Dec 17, 2001 04:23 PM
