Old Oct 07, 2008, 10:13 PM
PlaneCrazee is offline
Find More Posts by PlaneCrazee
Burner!!
PlaneCrazee's Avatar
United States, AR, Sherwood
Joined Jun 2005
Hoaye 5" fan test
I posted this in the scorpion thread and then realize it fits here better. Sorry for the cross post.
I got to test the HK 4035-800 in the Hoaye 5" fan today on 14S2P A123 2300s controlled by an OEM100HV. It was a learning experience to say the least. The first interesting thing I discovered is that I don't own a watt meter capable of sustained current flow above 70amps. After going the trouble of moving my desktop computer to the garage and connecting the Extrema it would not record anything but the volts. I went back to my trusty Astro and video recorder that did not record the information legibly from behind the protective 3/8' lexan. (I have serious respect for this fan setup) The Astro recorded the 88 amps for a while before starting to smoke, that is the only measurement I'm sure of but I'm pretty sure I saw the volts sag to 44 so the watts should be around 3900! The thrust I did get and at 13 lbs. 9 oz. It was pretty substantial. The back casing never got over 150 F even several minutes after running. The batteries got warm but not hot and the ESC never got warm
Sorry for such an incomplete report but it all I can get until I can get an Oracle 200a to data log it properly. The deans connectors feeding the esc get very hot and the battery wires (10GA) got warm. These power levels need a whole new approach to be reliable so changing to 6mm connectors on the ESC (that I have between the sub packs already) will be better. Changing to 14s3p may give a better indication of the performance on 12s high performance lipolys. The first taste of this setup definitely shows a lot of potential. Thanks Georges and Perry for getting this special motor to me.
I tested the motor again the nextday without the smoking watt meter just to get the rpm and thrust. I did not charge the battery or change out the deams so it can probably do better - the RPM reading was 22,700 and the thrust was 13 lbs. I cut the first part out of the video, it ran a couple of minute just before the clip but it was BORING so i cut it.
Hoaye 5" and Sorpoin HK4035- 800 (0 min 45 sec)
PlaneCrazee is offline Find More Posts by PlaneCrazee
Old Oct 07, 2008, 11:13 PM
EDDIEGIGOWATTS is offline
Find More Posts by EDDIEGIGOWATTS
1.21 gigawatts
EDDIEGIGOWATTS's Avatar
Fort.lauderdale Florida
Joined Jul 2006
that's with out intake ring,, I can tell by the sound
put a intake ring you will see more pounds
which Scorpion motor did you use PlanecraZee
Eddie
EDDIEGIGOWATTS is offline Find More Posts by EDDIEGIGOWATTS
Old Oct 08, 2008, 12:38 AM
Burner!!
Joined Jun 2005
That's with a full intake ring and 90% fsa outlet. The motor is an HK4035 custom. It has 6 poles and an 8mm shaft. I have a Medusa 200amp Oracle on the way so a better test will follow next week.
Here's a few pics of the setup.
Old Oct 08, 2008, 01:51 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I've heard the Astrofligth Wattmeter wont read higher than 88 amps so you may be pulling more than that.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Oct 08, 2008, 10:53 AM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
If you don't mind sharing, where did you find a 4035-800?
I've only found up to 4035-600 so far.
Thanks ,
John
PlumberJohn is offline Find More Posts by PlumberJohn
Old Oct 08, 2008, 12:51 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Ed, I've seen it show in the mid 90's, but it also acts like a resistor. When I took it out of the line, the rpm picked up considerably. Later I found that I was really pulling about 120 amps. Clamp meters are the only way to go in that case.
Steve C
Steve C is offline Find More Posts by Steve C
Old Oct 08, 2008, 06:27 PM
tallyho is offline
Find More Posts by tallyho
Epping, Essex
Joined Nov 2002
Hi Planecrazee,
I'm quite interested in the results of your test. I've been looking at a scorpion 4035-630 to run in a 4.5inch hoaye fan on 12s. I have on thought that your amp reading may be considerably low.
Using the data that Miljenko gave from his tests on that fan, what I've been looking would give 80ish amps for 3300watts (+/-10%).
A very quick bash through motoguess actually gave over 120amps on 10s lipos using your setup. I love to see the results with a clamp meter.
Scorpion seem pretty cool with doing custom winds. I've exchanged quite a few e-mails with them and have been impressed with their helpfullness.
cheers
Matthew
tallyho is offline Find More Posts by tallyho
Old Oct 08, 2008, 08:47 PM
Sniper.308 is offline
Find More Posts by Sniper.308
I'm a lead farmer Mother ^%$^%
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
Yeah, I too am impressed with their motors but when will they release that motor (800kV) to the public? No one has any motors out that they promised months ago. Medusa with their 70 and 80mm 36V2 series and Light Flight with their 80mm. Argh More powa!!!!
Sniper.308 is offline Find More Posts by Sniper.308
Old Oct 13, 2008, 04:00 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
its great to see 6kg coming out of the Hoaye fan i have be trying to get a f18 in the air with one of the 4.5 fans with 10s 5000ma 25c the air frame come in at 3.4kg with radio and retracts and the fun and lipos 2.3kg so if i can get 6kg + i should be OK thank for the info
dpot is offline Find More Posts by dpot
Old Oct 16, 2008, 10:14 PM
Burner!!
Joined Jun 2005
Steve C
I don't have a clamp meter any more, the one I did have was an AC job do they make inductive pickup DC ammeters?
The Oracle has arrived and it is rated for 200 amp burts and 30s @100 amps so it should get the job done. It came with a phase sensor and throttle position sensor along with a temp prob that I'll forego for these test.
John, Mattew and sniper .308
The motor is indeed a custom wind that they are considering releasing. In addition to the hot wind the shaft is 8mm that seems to aid the smoothness - just feeling from running it with a 6mm shaft on the 4020-8 and this motor turning considerably faster so far it isounds much soother. The Hk ius the only way to goo too since the bearings are larger and the fan helps with the cooling.
Old Oct 17, 2008, 07:49 PM
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
Well I hope that they make that wind. Cause my next plane may be a custom built A-10 and I'm going to use 2 of these or a 120mm BAe Hawk
Old Oct 18, 2008, 08:14 PM
Burner!!
Joined Jun 2005
well... It smoked the Oracle anyone know where to get a DC clamp meter?
Old Oct 18, 2008, 08:22 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Interesting.
I have an old Fluke AC/DC clamp-on that I may part with....if I can find it .
Ahh... never mind my, my old one is the best one Fluke 337...(not cheap)
But I am very interested in your testing!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 18, 2008, 10:08 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Too bad Sears stopped selling theirs. I got one when it was on sale for $39 a few years back.
After a short web search I found this. Here's a good price on one that does DCA: 40m/100m +/- 2.0% 400/1000A +/- 1.5%
GregG is offline Find More Posts by GregG
Old Oct 19, 2008, 12:04 AM
Burner!!
Joined Jun 2005
That looks like the one I just bought Here. As soon as it gets here I'll try again.
Just for kicks I tried it with 10s2p to see what kind of thrust it would deliver, it measured 10 lbs 8 oz.
Cool Looking for a 1/5 MotoGP test pilot.... Jena67 Motorcycles 5 Feb 07, 2006 02:08 PM
GWS S400 fan test bed frankenfoamy Electric Ducted Fan Jet Talk 3 Mar 03, 2003 10:35 AM
Comparison between Mega 16/15/5 and 22/10/5 flight test Megowcoupe Power Systems 4 Jan 31, 2003 09:25 AM
Vasa fan test bed flight report steve neill Electric Ducted Fan Jet Talk 10 Mar 13, 2002 12:09 AM
Vasa fan test bed steve neill Electric Ducted Fan Jet Talk 8 Mar 12, 2002 03:03 AM
