south shore MA.
Joined Oct 2008
the motor is attached to a crossbeam with Aviation ty-raps and connected to the 3/16 shaft with a product i use to mount/insulate Marine electronics, it is called a well-nut. the motor is out of a cordless drill, the battery packs are custom made by me from "lowes clearance rack" 12 volt ni-cad battery packs ($1.50 each if I recall...I bought all of them) the radio is actually a Futaba from one of my airplanes (I know I am not sussposed to use it..its all I have) when I get some more cash Ill get a new transmitter and reciver. the rudder is home made balsa, I need to cut an acess hatch in the trunk cabin to show the electronics so Ill post some more pics later on today/
Boston, MA
Joined Jan 2007
south shore MA.
Joined Oct 2008
also I mean the ty raps on the motor side of the coupler, mabye i can use metal ty raps on the motor it self if it causes a problem, but then the wooden motor mount would need to be changed, I am more worried about the SC heat sink in the cabin getting to hot.
Boston, MA
Joined Jan 2007
Just my two cents.
CMEboston, Let me pitch in and list the set up you are running so that other members can pitch in as well. You have the following and you don't wanna dump any more $ into RC's, so you wanna work with what you already have. 26" boat 7.2 volt, 380 size high rpm rc car motor Tamiya mechanical speed controller 2" graupner 4 blade plastic prop or 3 blade prop Battery: NiCd 8 1200 Mah cells or 9.6 volt |
south shore MA.
Joined Oct 2008
thank you HoaRC !!
here is a copy of the sea trial post brought the model to the pond today for the first time. scale speed is pretty good, she sits way to high on the water line, and battery performance is very dissapointing. as stated in my other thread my packs are custom made to fit under the deck and are made from clearance rack cordless tool batteries(scored a 24 volt pack, 20 1.2 volt cells for $2 today ) and the ones I ran today were 8 1200 Mah cells or 9.6 volts. I think she is over propped though, I am running a 2" graupner 4 blade plastic prop and she needs more RPM's(I think) and can run wide out for about 5 min. then the Pack gets pretty warm. ill try the 3 blade prop tomorrow and hopefully that will give me some longer run times. also I have no idea as to what the motor is, I got it out of an old r.c car that had 7.2 packs, would this give me issues? also just realized my Dynamite mega 2 instructions say it will charge 6 or 7 cells.......oops I have 8. do you think this is critical? also was thinking of wiring 2 9.6 packs(8 cells) in parallel to double my amperage, if I do this will I have to charge one pack at a time? or can I charge them together, essentially making them one battery? ill keep everyone posted as to my progress thanks in advance. |
south shore MA.
Joined Oct 2008
trialed again with the 3 blade prop and I dropped 2 cells ( again thank's HoaRC!!)
and got a few more minutes out of her. then I put 2 packs in paralell and she ran for almost ten minutes. it's not that money is an issue i really just wanted to get her together before the freeze with what I have. ill probably build another one over the winter, also want to make tooling for a cap deck and wheelhouse as my goal is to sell the boat as a kit. |
south shore MA.
Joined Oct 2008
well iv'e lost my camera so we will have to wait for pics
but I have built a new cabin roof and intergrated a new muffler/stack and mast with a crows nest to help align the detachable cabin top. iv'e also started constructing a folding tuna pulpit. I put a coat of black bottom paint on her. ill post pics when I find our camera
| Thread Tools | |
| Discussion Check Out New Video Of My Scale Rc Glider !!! | Huston | Sailplane Talk | 8 | Oct 04, 2007 09:42 AM |
| Discussion Check Out New Video Of My Scale Rc Glider !!! | Huston | Scale Sailplanes | 10 | Oct 04, 2007 05:42 AM |
| Help! Trying to scale down my markings | I'm Rick James | The Builders Workshop | 6 | Jun 12, 2007 07:15 AM |
| Discussion My Curtis flying boat project....a fun scale indoor/parkflyer | Thomas B | Waterplanes | 11 | Apr 21, 2006 12:57 PM |
| Alert Looking for a new canopy for my HB (not scale)?! (And a few Related Qs...) | Minimole | Micro Helis | 23 | Mar 10, 2005 01:59 AM |
