Old Oct 07, 2008, 05:29 PM
Ralgh is offline
Find More Posts by Ralgh
Thousand Oaks, CA
Joined Jan 2005
GY611 servo goes full travel with half stick input
My GY611 servo moves full travel with only half transmitter stick input. There is no adjustment I can make on the gyro or transmitter to correct this. I have searched the forum and internet for that matter and can't find anything on this. It is not an adjustable travel volume issue. No matter what the ATV setting, full travel is reached with half stick input. I should also note that this even occurs with the servo horn removed and no physical restriction. With power removed I can move the servo through a larger range by hand but that seems to be normal with all servos. Am I the only one seeing this behavior? Is this normal? Is there a way to correct this? Thanks for the help.
Ralgh is offline Find More Posts by Ralgh
Old Oct 07, 2008, 06:33 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Sounds like you have the gyro mode/gain wire plugged into the incorrect channel. What radio do you have?
RC Man is online now Find More Posts by RC Man
Old Oct 07, 2008, 09:11 PM
Ralgh is offline
Thousand Oaks, CA
Joined Jan 2005
I am using the Spektrum DX7. The Gain wire is plugged into Aux2 spot on an AR7000 receiver.
Old Oct 08, 2008, 09:07 AM
fritzthecat is offline
Find More Posts by fritzthecat
Send Money, Women & Guns!
fritzthecat's Avatar
Virginia Beach
Joined Sep 2002
Yes, it is normal for Heading Hold gyros.
With modern piezo HH gyros, the rudder stick does not control the servo directly. The stick input to the gyro represents a 'rotate xx degrees in xx seconds' request and the gyro will adjust the servo to meet the yaw demand. The amount of stick travel has nothing to do with the amount of servo travel. In GY401 and similar basic gyros, the yaw rate is set in the gyro and the heli yaw will vary with wind resistance encountered by the tail. The 611 and other high performance gyros will keep a steady yaw rate no matter what external influence (wind/ forward flight etc) is on the tail.
Speed of rotation is adjusted by inc/dec the rudder channel ATV. Servo travel is adjusted in the gyro. Gyro gain is adjusted by the AUX input to the gyro.
Fritz
fritzthecat is offline Find More Posts by fritzthecat
Old Oct 08, 2008, 03:52 PM
Ralgh is offline
Thousand Oaks, CA
Joined Jan 2005
There's one thing I'm not clear about in your explanation. With everything set properly will I see an increase in the pirouette rate with the stick deflected beyond the halfway point when I am actually flying the helicopter?
Old Oct 08, 2008, 04:47 PM
LaurenceGough is offline
Find More Posts by LaurenceGough
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
Does it do it in rate mode?
LaurenceGough is offline Find More Posts by LaurenceGough
Old Oct 08, 2008, 05:29 PM
Ralgh is offline
Thousand Oaks, CA
Joined Jan 2005
It stays that way in both Normal and AVCS modes.
Old Oct 08, 2008, 08:04 PM
Virginia Beach
Joined Sep 2002
Yes. For example if the gyro is set for a max 360 deg rotation per second (adjusted by the rudder channel ATV). Full stick deflection will give you 360deg/sec. No matter the wind or fwd/back/sideways flight. Moving the stick to the 1/2 deflection point will give a 180deg/sec piro rate. 90deg/sec at 1/4 deflection.
The max deflection of the tail pitch slider is set in the gyro (limits). You can up the rudder ch ATV until the piro rate doesn't increase anymore at which point the tail pitch slider is maxed out. Note that at that point you are at a very high piro speed and you better make sure your battery is held down real good.
Fritz
Old Oct 10, 2008, 11:53 PM
desert_flyer is offline
Find More Posts by desert_flyer
Volts < Amps
desert_flyer's Avatar
USA, UT, Salt Lake City
Joined Feb 2007
Fritz is right - the best way to think about it is that "the gyro owns the limits"
However, you can use the (dual) rate setting in the radio to control the yaw rate
desert_flyer is offline Find More Posts by desert_flyer
Discussion Esky Lama 3 Pitch servo goes to full travel Hans Svetty Coaxial Helicopters 3 Jun 24, 2007 01:24 AM
Sold Stevens Aero "Stick" full kit with fuselage NIB diceco Aircraft - Electric - Airplanes (FS/W) 3 Mar 20, 2007 11:11 AM
Question How do I program zero pitch at half-stick with T Rex and 7cap ? Al P Mini Helis 5 Aug 01, 2006 10:05 PM
What spare parts to order along with Lite Stick? MK Parkflyers 16 Jan 17, 2002 11:03 AM
mini ifo with lite stick gear? cheapflyr Parkflyers 3 May 17, 2001 02:47 AM
