Old Oct 06, 2008, 11:31 PM
CClark is offline
Find More Posts by CClark
XMarinE
CClark's Avatar
Ohio
Joined Jun 2005
Can I put a prop on this motor? What size?
I have a Thunder Tiger Ripper Outrunner Heli OBL 43/11-30H (TTR2379) be used as direct drive in a plane? I was wondering what prop range would be safe and what glow is it comperable to? I also want to know if there is a weight range on plane sizes to use this motor with? I have a few 4-6 lbs. planes that I was thinking on using it on if I can? The specs on the motor are are at http://www.tiger.com.tw/product/2379.html
Another question is battery and esc.....do I need the 75 amp or higher if using a prop? I am new to the conversion and am going to use it in a 30 size Raptor heli if a plane won't work. The plane is a OUYA 40 size F3A here http://www.texasrcplanes.com/ouya40.html
Thanks...
CClark is offline Find More Posts by CClark
Old Oct 06, 2008, 11:42 PM
rcozstyle is offline
Find More Posts by rcozstyle
rcozstyle's Avatar
gawler, South Australia
Joined Jul 2006
Hi CClark
The prop size would be determined by the battery cell count, on 5s I would think about 10x5 -10x7 maybe, which should make it pull much like a 40 glow.
rcozstyle is offline Find More Posts by rcozstyle
Old Oct 07, 2008, 02:33 AM
CClark is offline
XMarinE
CClark's Avatar
Ohio
Joined Jun 2005
I was thinking a123's but...I have 2 Thunder Power 2100 3 cells I could run together for testing...although I know I wouldn't get much flight time. What would you recommend...anything would help....Nicad, Lipo or a123's I would use any to get about 10 - 20 minutes of flight time as long as the cost is reasonable.
Old Oct 07, 2008, 03:41 PM
CClark is offline
XMarinE
CClark's Avatar
Ohio
Joined Jun 2005
Any Help?
Old Oct 07, 2008, 04:41 PM
rcozstyle's Avatar
Joined Jul 2006
Hi CClark
Pm sent
Discussion can this motor be saved? istandalone Power Systems 7 Jun 10, 2008 11:18 PM
Question Will this motor work on a 550 size heli? siryan Electric Heli Talk 7 Jul 23, 2007 01:10 PM
Question can this motor install in this Cessna ? ROSS OS Electric Plane Talk 6 Jul 10, 2006 10:42 PM
Yippee! Boy, can this Slow-V Loop or What !!!!!!! Cal Beginner Training Area (Aircraft-Electric) 33 Sep 23, 2004 09:03 PM
How long can this motor combination last? Magna Power Systems 19 Nov 23, 2001 06:43 PM
