Old Oct 06, 2008, 02:59 PM
Guest
n/a Posts
FA (UK Only) 2 off Saito FA-62a GK + ASM P61 Black Widow + ScaleOleos
Hi,
I have currently got 3 eBay auctions on as follows :
1. Auction ID 250304993410
This is an auction for a Saito FA-62a Gold Knight 4-stroke RC
aeroplane engine in new unrun and boxed condition.
This engine is absolutely new and unrun.. It has never been mounted
and is complete with the original box and all original accessories,
decals and instructions. In addition there is supplied a right-angle
exhaust adaptor which can lead to a better in-cowl exhaust
orientation. I am selling the engine because I bought it for a
project I have decided not to proceed with. The project was a twin so
I have another identical engine for auction - see my other items for
sale for this and the twin model
The FA-62a has the following characteristics
* .62 cubic inches of power in a .56-size case
* Unitized cylinder and head
* Integrated head transfers heat more easily and evenly
* Turns an APC 13 x 6 prop at 9900 rpm
* Installs easily in all .40-.72 models
* True chrome AAC cylinder lining
* 1-piece cylinder head allows engine to run cooler
Overview
The Saito FA-62A is a lightweight 4-stroke glow engine brought to the
market to bridge the gap between the .56 and the .72 displacement
sizes. The FA-62A engine is only 5 grams heavier than the .56,
offering a better power-to-weight ratio for modelers interested in
glow engine power systems. This engine is the popular Golden Knight
version with a black and gold finish.
Specs
* Type:4 Stroke
* Displacement:.62 cu in. (10.21cc)
* Bore:26.2 mm
* Stroke:19.0 mm
* Cylinders:Single
* Total Weight:464 grams 16.4 oz
* Engine (Only) Weight:418 grams 14.7 oz
* Muffler Weight:46 grams 1.7 oz
* Crankshaft Threads:M7 x 1 mm
* Prop Range:11x7 thru 13x7
* Fuel:10% - 30% nitro - Synthetic Oil
* Mounting Dimensions:137mm x 53mm x 102mm
* Muffler Type:Cast
* Cylinder Type:AAC
* Carb Type:Barrel - Two needle
* Crank Type:Dual Ball Bearing
No reserve, and low £25 initial bid for this fabulous model engine so
bid now and pick up an bargain !
Postage will be £8.25 by special delivery next day, £5.20 by standard
parcels or can collect from Brighton, East Sussex f.o.c. Note I am
not willing to ship this outside of mainland UK + NI. Paypal, heques,
cash or postal order in payment please.
2. Auction ID 250304993081
This is an auction for an RC model kit for a Northrop P-61 Black
Widow. It is in unstarted condition and complete with all original
accessories including the wheels for fixed gear operation, decals and
instructions. I have the optional scale oleos available as a seperate
ebay auction as well as a pair of suitable 4 stroke engines - see my
other auction items for these. I have decided not to proceed with the
build and I need the space so unfortunately this model has to go.
Characteristics and specifications as follows :
● Wing Span: 79.5 Inches (2019mm)
● Wing Area: 1010 Square Inches (65.42dm2)
● Length: 59.5 Inches (1511mm)
● Weight RTF: 13.75 Pounds (6.2kg) with Retractable Landing Gear and
Doors (not supplied)
● Wing Loading: 31 Ounces Per Square Foot (95gr/dm2)
● Functions: Ailerons, Elevator, Rudders, Flaps, and Throttles
(Retracts Optional)
● Radio Required: 5-6 Channel or More
● Engines Required: 2 x .52-.61 4-Strokes or 2 x .45-.52 2-Strokes
● Advanced Lightweight Construction and Scale Outline
● Parts Prepainted and Precovered in Scale Color Scheme
● Large Size, Yet Easy to Fly
● Strong, Prebent Wire Landing Gear and Lightweight Stand-Off Scale
Wheels
● Includes a Generous Hardware Package
● Easy Assembly - Over 50 High-Resolution Digital Photos to Guide You
No reserve, and low £25 initial bid for this fabulous model kit so bid
now and pick up a bargain.
Postage will be £17.76 standard parcels or can collect from Brighton,
East Sussex f.o.c. Note I am not willing to ship this outside of
mainland UK + NI. Paypal, cash or postal order in payment please.
3 Auction ID 250304993534
This is an auction for a set of scale oleo legs and wheels to fit the
79 inch span ASM Kit of the Northrop p-61 Kit which I also have
available on eBay - see my other auctions. This optional extra for
the original kit allows the use of retracts (not supplied) to give a
very scale like undercarriage operation with retracting doors
controlled by the included mechanical linkages.
No reserve, and low £15 initial bid for this fabulous U/C set so bid
now and pick up a bargain !
Postage will be £6.40 by special delivery next day, £5.20 by standard
cheques, cash or postal order in payment please.
Thanks for your attention,
