Old Jul 06, 2011, 11:36 AM
mucwendel is offline
Find More Posts by mucwendel
mucwendel's Avatar
Deutschland, Nordrhein-Westfalen, Wuppertal
Joined Jun 2009
And here an "On Wing" Video. Check out the feet of the dog during loop :-)
Condor Magic EVO4 Flying DOG Bitburg (3 min 4 sec)
mucwendel is offline Find More Posts by mucwendel
Old Jul 06, 2011, 04:46 PM
WhyNot is offline
Find More Posts by WhyNot
Irvine, CA
Joined Jan 2005
What is the total weight of your Condor and the brand of your 4250 / 800kv motor?
I am trying to determine if my set up will fly as mine feels very heavy. I have the weight of mine recorded somewhere but have moved on to other projects.
Regards, Charlie
WhyNot is offline Find More Posts by WhyNot
Old Jul 07, 2011, 01:04 AM
mucwendel's Avatar
Joined Jun 2009
@Charlie
The total weight is 2950g incl. a Zippy 4S-4000mAh 40C Lipo from HK.
This is the Motor I use:
http://cgi.ebay.de/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
Kv (rpm/v) 800
Weight (g) 210
Current (A) 50 - 60
13x8 - 14x10
Max Voltage (V) 11,1 - 14,8
Power(W) 850 - 1050
Shaft A (mm) 5,0
Length B (mm) 50
Diameter C (mm) 42
Shaft Length (mm) 20
Total Length E (mm) 70
I've try to measure the thrust with a suitcase scale while the bird was sitting on the table. It shows 3.3 Kg at 66A.
Old Jul 07, 2011, 02:08 AM
WhyNot is offline
Irvine, CA
Joined Jan 2005
Thank you mucwendel, that data and info helps me very much. I can now see that I must replace my Turnigy 35-48 with a larger motor and modify the nose to accept it. That added weight plus the larger battery to support it should do the trick. As it was I needed to add unwanted lead to reach the CG and it was underpowered.
This aircraft is shaping up to be a good looking and fast crusing bird that will just about ignore all but the strongest thermals. Charlie
Old Jul 07, 2011, 02:35 AM
mucwendel's Avatar
Joined Jun 2009
So good luck :-)
Actually I carry 80g lead inside the nose. But a larger LiPo will not fit under the canopy without modifying it.
As I got the bird as electric version I just had to cut of 10mm from the nose in order to get the motor inside.
I also moved the rudder servo behind the main frame in order to have more space for the lipo.
I've cancelled the first idea to mount the rudder servo into the tail, as I want to prevent carrying more lead in order to keep the CG.
Lets see if I find some more pictures.
Old Jul 07, 2011, 02:42 AM
mucwendel's Avatar
Joined Jun 2009
Close-up of the guide pin area and a happy pilot.
Old Aug 01, 2011, 03:13 PM
geives1 is offline
Find More Posts by geives1
United States, IL, Hinckley
Joined Jan 2011
A little help
Hi all! I have ordered up an Condor EVO 4 Electric version & have a question as I try to piece together everything for the build. What size prop spinner does the electric version require? Is it 45mm?
Thanks!
-Brandon
geives1 is offline Find More Posts by geives1
Old Aug 29, 2011, 04:26 AM
singlin is offline
Find More Posts by singlin
singlin's Avatar
Cervinia-Italy
Joined Nov 2005
Will this out runner be sufficient?
Multiplex 3522-0700
http://aeromicro.com/Catalog/himax_3...or_4556753.htm
singlin is offline Find More Posts by singlin
Old Oct 04, 2011, 05:30 PM
Mac_Flyer is offline
Find More Posts by Mac_Flyer
I was born to FLY
Poland
Joined Jan 2007
hi,
im looking for perfect setup for my condor, could you help me a little bit ?
up to now i was thinking about that eq :
Turnigy MG930 servos
Flightmax 4s 4000mAh
tgy plush 60a
kD 36-12XL 770Kv
http://www.hobbyking.com/hobbyking/s...Q_2826_12.html
Im waiting for your advices
thanks
Mac_Flyer is offline Find More Posts by Mac_Flyer
Old Feb 23, 2012, 04:46 AM
layer is offline
Find More Posts by layer
layer's Avatar
Joined Apr 2007
I have finished my CONDOR at last!!!
Is anyone using the recommended FLY-FLY 83-85mm?
Need to know the CGs U guys are at, on the glider version only.
LAYER
layer is offline Find More Posts by layer
Old Feb 23, 2012, 04:59 AM
Damian Couzoff is offline
Find More Posts by Damian Couzoff
Damian Couzoff's Avatar
Melbourne,Victoria,Australia
Joined Apr 2010
LAYER
Hi layer,l have flown my condor primarily slope(glider-version only) at 85mm,and found it needed down elevator, more often than not to maintain level flight.I have added extra lead and it flies better at 80mm,without using down elevator.At 85mm, mine was slightly tail heavy.You will like the condor,its one of my favourites,flys well,and is easy to land,and it has had fifteen flights already,in 15 to 22 plus mph winds.regards damian
Damian Couzoff is offline Find More Posts by Damian Couzoff
Old Mar 26, 2012, 01:51 PM
olivergottlieb is offline
Find More Posts by olivergottlieb
Brazil, RJ, Rio de Janeiro
Joined Oct 2006
Guys,
Maiden flight with de Condor this weekend, weak thermals but good flight.
It's a Eletric version with a Hyperion GS3025-08 on 4S and a Aeronault 12X6,5 folding, very strong set up, capable of vertical climbing. As it was necessary 160g of ballast in the nose 60% climbing power give a good cool climbing perforrmance.
I am using the 83-85 CG point, with good result.
At the third flight the model was allready trimmed I tried some loopings rolls and stall turns, with good results.
Landing was easy and smooth, only using the flaps, as soon as a good landing circuit high was found. Buterfly not yet set up, with it will be easier.
Abs
olivergottlieb is offline Find More Posts by olivergottlieb
Old May 15, 2012, 08:18 AM
_Richard is offline
Find More Posts by _Richard
Joined May 2012
Hello everybody!
I'm new to the forum and... new to the Condor Magic Evo 4.
I've been enjoying myself for a couple of month with the EasyGlider Pro then I've found the Condor Magic Evo 4 in my shop (electric version with motor), so... I bought it.
I think it's challenging for me but... I think I can do it. :-)
I would ask some questions about components/preparation of the model since I would like to do things in the right way.
First questions is concerning the servos:
- are the HS65MG good for ailerons and flaps?
- is the HS81 good for elevator (in the tail)?
And... does the Condor Magic Evo flights in a proper way even without inverting the flaps?
Thanks in advance!
_Richard is offline Find More Posts by _Richard
Old May 15, 2012, 08:40 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I assume you mean turning the flaps over, being a common modification for more "down" travel? The glider will fly fine with the stock arrangement. The only purpose in trying to get more "down" travel on the flaps is to make them more effective as brakes for landing purposes. If you have a nice level grass field to land on, then you don't really need such good braking: it's needed more for slope flying where there is usually limited space to land.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 15, 2012, 02:52 PM
_Richard is offline
Joined May 2012
Thanks for your answer. Actually, I would start to fly on grass flat field but my goal is to fly on the slopes, so... definitively I would need to "brake" the beast.
I just fear I'll not be able to modify the flap... I have to think twice... mumble mumble...
Any info about the servo?
Thanks in advance,
regards!
