Old Oct 06, 2008, 02:56 PM
roballoba is offline
Find More Posts by roballoba
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
Build Log
Presenting.... For-Macchi GW-72 (GWS Formosa built as Macchi MC-72 racer)
This has long been my favorite float plane. It's red, it's Italian, it floats, it has contra-rotating propellers, and it holds a world record for fastest float plane.
The Macchi-Castoldi MC-72
I have been wanting to build this forever....
and here it is!
The GWS Formosa was the ideal candidate for this build and it worked great!
Powered by a Vision Hobbies contra-rotating motor tested at about 350 watts, my Macchi should fly nicely.
Enjoy!
Roballoba
roballoba is offline Find More Posts by roballoba
Old Oct 06, 2008, 04:07 PM
Vasy is offline
Find More Posts by Vasy
Vancouver, Canada
Joined May 2007
cool. I like the floats and wheel combo. Nice build!
Vasy is offline Find More Posts by Vasy
Old Oct 06, 2008, 04:17 PM
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
motor install
Motor from Vision hobbies....
http://visionhobbies.com/1637131.html
motors installed on bent aluminum stock.
Fuse hogged out to allow for dual esc's, battery, and CF tubing.
Carbon fiber rods entire length of fuse - both sides.
Plywood battery tray attached to CF tubes.
Old Oct 06, 2008, 05:00 PM
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
Beginning to take shape...
All the lines are straightening out and we are starting to have something other than a formosa.
I filled in the dents with light weight filler then covered the entire plane with .5 oz fiberglass cloth and waterbased poly-urethane. Next came the paint. H2O spray paint (doesn't eat foam) and acrylics brushed on for details.
The floats for GWS planes tend to rip from the plane rather quickly when flying on or off ground, so I used welding rod to form the bracing. This is AMAZINGLY strong!!!! The wire is attached by wrapping thread around the place where the two wire join and the soaking in CA glue. The Fairings will be made from blue fan fold foam as well.
Old Oct 06, 2008, 05:15 PM
planekiller is offline
Find More Posts by planekiller
Midnight Maniac
planekiller's Avatar
USA, NE, Lincoln
Joined Dec 2006
WOW! Nice work!
planekiller is offline Find More Posts by planekiller
Old Oct 06, 2008, 05:16 PM
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
finishing up the For-Macchi
Paint goes a long way for details and it's starting to look like the real thing....
The windshield was bent from plastic I saved from the recycle bin. Try making one from paper first, then transfer your shape to the plastic - it's easier.
Although I have salt water in front of my house, I am not close to a fresh water lake to fly from. I have wasted too many pieces of electronics to fly off the lagoon again.... So, I attached wheels! The largest GWS wheels were mounted with rods through tubes through the floats and secured with wheel collars... (makes sense?)
Old Oct 06, 2008, 05:34 PM
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
power setup
I planned to run a 2100mah 3s lipo, but I just got the new Thunder Power 2600 prolite. it fits just as well!
The props go in opposite directions, and there are supposed to be tricky efficiency balancing dynamics involved because the rear prop does not have to work as hard as the front one...
here's what I ended up with...
Front APC 9x6p
Rear APC 8x8
tests ran about 350 watts combined and about 17 amps each tested individually (while running together)
ESC's are 30 amp Suppos, and a separate BEC was added for constant power to the radio.
Old Oct 06, 2008, 05:47 PM
damn you tree!
roballoba's Avatar
Foster City, CA
Joined Dec 2005
weight...
980ish grams without battery
1160ish grams with prolite 3s2600
Old Oct 06, 2008, 06:14 PM
BladeRex is offline
Find More Posts by BladeRex
Bladerex700
Joined Jul 2007
that's sooooooo coooool
I want one of those where did you get the twin motor?
BladeRex is offline Find More Posts by BladeRex
Old Oct 06, 2008, 06:37 PM
Cephas2000 is offline
Find More Posts by Cephas2000
Uh, I meant to do that!
Cephas2000's Avatar
Foster City, CA
Joined Aug 2006
Bee-a-utiful!
Bet it was hard keeping it on the ground during those taxi sessions.
Can't wait to see her in the air, R. She's got really nice lines.
Cephas2000 is offline Find More Posts by Cephas2000
Old Oct 06, 2008, 07:14 PM
DBear is offline
Find More Posts by DBear
Santa Cruz CA
Joined Jan 2006
Macchi maiden
So when is the maiden. Call me when you plan. Hell I'll take the day off to see that. May have to finish off my H-1 and have a race
DBear is offline Find More Posts by DBear
Old Oct 06, 2008, 07:34 PM
ppatron is offline
Find More Posts by ppatron
Got the Fever
ppatron's Avatar
Foster City, California USA
Joined Mar 2006
Nice one
Wow! Great job Rob! She looks mighty perty! Let me know when you will maiden that baby.
ppatron is offline Find More Posts by ppatron
Macchi M-72 pittslover Scale Kit/Scratch Built 5 Oct 06, 2008 06:06 PM
Wing kit for Sig 231 (72") Jayhawker1976 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 18, 2004 06:28 PM
Wanted: Wing for my Electro 72 Power Glider rocketman Aircraft - Electric - Airplanes (FS/W) 1 Mar 13, 2003 03:58 PM
Yippee! Wanted: Wing for an Electro 72 power Glider rocketman Aircraft - Sailplanes (FS/W) 2 Mar 02, 2003 12:48 PM
Presenting, for your amusement, The Wingo Stick pfm Parkflyers 18 Jan 03, 2003 11:15 AM
