This thread is privately moderated by Etonic, who may elect to delete unwanted replies.
Old Feb 16, 2003, 11:09 AM
Etonic is offline
Find More Posts by Etonic
Trader Rating: 147
United States, VA, Chesterfield
Joined Jul 2002
Trader Rating: 147
FS- BEST Ultrabright LED's - 8000MCD plus --Final thread!
INSTRUCTIONS/PICS link:
http://www.rcgroups.com/forums/showt...threadid=95101
Ok Everyone,
This is what I have..
Aircraft sets
-2 whites, 2 reds, 2 greens, strobe, switch, resitors, and torroid -$17.50
Individual LED's
30 - White (6000 MCD 30 degree) - $2.50 ea w/ resistor
3 - Blue ( 5000 MCD 35 degree) - 2.50 ea with resistor
3- Aqua ( 5000 MCD 35 degree) - 2.50 ea with resistor
30 - Green(8000 MCD 45 degree) - $2.50 ea w/ resistor
30 - Red (8000 MCD 30 degree)- $1.50 ea w/ resistor
8- Yellow (6000 MCD 35 degree)- $1.00 ea w/resistor
4 - Orange (6000 MCD 35 degree) - $1.00 ea w/resistor
15 - strobe boards with toroid(sold only with LED's) - $3.00 ea
80 - Rx universal connector (JWT type)- $1.00 ea
80 - micro slide switches (Very Small!) - .50 ea
ALL ABOVE IS IN STOCK NOW!
If anyone want to use paypal - Email me first -Paypal now lets you carry 2 accounts - one basic(no fees) and one premier(for credit cards=fees)
email: etonic@cox.net
Mark
- Finally got the best in one package!
Etonic is offline Find More Posts by Etonic
Old Feb 16, 2003, 11:12 AM
Etonic is offline
Trader Rating: 147
Joined Jul 2002
Trader Rating: 147
Another Pic
Heres the blue and aqua LED's...........
Old Feb 16, 2003, 11:42 AM
Steven D is offline
Find More Posts by Steven D
Trader Rating: 2
This space for rent
Steven D's Avatar
Peachtree City, Ga USA
Joined Apr 2000
Trader Rating: 2
Great work, just as I was warming up the search engine What are the voltages on these units? Have you measured the actual draw?
PMed you to get a couple of the greens on my order.
Steven
Steven D is offline Find More Posts by Steven D
Old Feb 16, 2003, 11:48 AM
dmccoach is offline
Find More Posts by dmccoach
Trader Rating: 1
Kutztown, PA
Joined Feb 2001
Trader Rating: 1
LED's
Hello:
I will take 2 aircraft packages...
I would like 2 strobe boards...
Let me know paypal.
Thank you, Dan
dmccoach is offline Find More Posts by dmccoach
Old Feb 16, 2003, 11:50 AM
Etonic is offline
Trader Rating: 147
Joined Jul 2002
Trader Rating: 147
LED Current
Steven,
Your all set!
The current draw and voltages are as follows:
Red - 20 mA @ 2.2V
Yellow 20 mA @ 2.4V
Green 20 mA @ 3.5V
Orange 20 mA @ 2.4V
White 20 mA @3.4V
I will includes 1/8watt resitors with every LED to drop the BEC 5V to the correct LED voltage
As you can see, you can run quite a few LED's before it even has an effect on the battery or BEC!
-Mark
BTW- I was also told you can pump the current to 30 mA and the output is even bighter - you may lose run time though. At 20mA, runtime is 20,000 hours!
Old Feb 16, 2003, 11:58 AM
wildbill95823 is offline
Find More Posts by wildbill95823
Trader Rating: 49
NON PayPal Member
Sacramento Metro, California, United States
Joined Nov 2001
Trader Rating: 49
I will take 2 aircraft sets,2 extra white and 2 strbe boards.
PAYPAL Thanks,Bill
wildbill95823 is offline Find More Posts by wildbill95823
Old Feb 16, 2003, 12:08 PM
Tigger is offline
Find More Posts by Tigger
Trader Rating: 23
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Trader Rating: 23
I'll take the Standard Package
Etonic,
I'll take the Standard Aircraft package.
Sending PayPal.
tIgGeR
Tigger is offline Find More Posts by Tigger
Old Feb 16, 2003, 12:14 PM
Etonic is offline
Trader Rating: 147
Joined Jul 2002
Trader Rating: 147
Strobes
Hi guys,
THE STROBE board will now work with ALL LED's!!!!
If you want them I have 1 or 2 left, but I can rustle up a few more.
BTW- The new greens will be in on Friday.
-Mark
Old Feb 16, 2003, 12:16 PM
Steven D is offline
Trader Rating: 2
This space for rent
Steven D's Avatar
Joined Apr 2000
Trader Rating: 2
Can you run a yellow and a green in series without a resistor??
Steven
Old Feb 16, 2003, 12:23 PM
Etonic is offline
Trader Rating: 147
Joined Jul 2002
Trader Rating: 147
Resistor
Stephen,
Without getting too much into electronics ---use a resitor for EVERY led and run in parallel-- a 1/8 resistor is basically weightless
There was an answer in the 'DIY lighting' thread in the parkflyer forum... its got to do with the fact that the voltage drop accross each LED is only .7V, so in effect you WAY over amp the LED's.
Here's a copy from the thread:
It's all about the current. LED's are spcified by their maximum current. A LED has a .7V drop from anode (+) to cathode. Two in series = 1.4V drop with negligable resistance. Therefore, your current I = was 3.6A....did they glow then blow
Most LEDs are speced at 20mA (.020A). To get there from here you would need a (R=V/I R=3.6/.020 R=180ohm) 180ohm resistor . Of course adding in some safty factor and maybe standardizing on a resistor of 220 ohms (Red Red Black) would be good too.
-Mark
Old Feb 16, 2003, 10:07 PM
newguy is offline
Find More Posts by newguy
Trader Rating: 52
No retreat no surrender
newguy's Avatar
USA, WI, Milwaukee
Joined Apr 1999
Trader Rating: 52
LED's
Mark, I answered your other thread and got your reply. I would like to order two standard sets, and I would like a few of the dimmer greens as well (please?) Please e-mail or PM me and send me your address so I can get out a money order as I am not set up for PayPal. Thanks! Jim
newguy is offline Find More Posts by newguy
Old Feb 16, 2003, 10:32 PM
William A is online now
Find More Posts by William A
Trader Rating: 38
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Trader Rating: 38
Mark,
I'll take 1 Aircraft kit if they're still available.
Sent you a email also.
William A is online now Find More Posts by William A
Old Feb 16, 2003, 10:48 PM
Hydroman is offline
Find More Posts by Hydroman
Trader Rating: 10
Sunny California
Joined Sep 2002
Trader Rating: 10
led w/strobe board
I would like a kit also with strobe board if available, pleas advise
Hydroman is offline Find More Posts by Hydroman
Old Feb 17, 2003, 01:20 AM
ElectriFan is offline
Find More Posts by ElectriFan
Trader Rating: 0
Redmond, WA
Joined Apr 2002
Trader Rating: 0
Mark - I'm interested in 2 std kits w/ 2 strobe boards. I'll pay with Paypal, sent you an email.
ElectriFan is offline Find More Posts by ElectriFan
Old Feb 17, 2003, 11:15 AM
hopsterguy is offline
Find More Posts by hopsterguy
Trader Rating: 0
hopsterguy's Avatar
Westerly, RI, USA
Joined Oct 2002
Trader Rating: 0
Sent you an e-mail
hopsterguy is offline Find More Posts by hopsterguy
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
FS:Bantum Bipe W/LED's LJH Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2003 08:59 AM
FS- Superbright LED's - 8000MCD-- SUPER Price!!! Etonic Aircraft - Electric - Airplanes (FS/W) 41 Dec 21, 2003 11:51 AM
FS- Superbright LED Night Flying KITS!!! (6) 5mm standard LED's with Strobe board! Etonic Aircraft - Electric - Airplanes (FS/W) 48 Jun 22, 2003 09:56 PM
FS- Ultrabright LED package w/ Rx connector Etonic Aircraft - Electric - Airplanes (FS/W) 25 Feb 16, 2003 09:40 AM
