This thread is privately moderated by DriveWRX, who may elect to delete unwanted replies.
Old Dec 10, 2008, 04:29 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
when you do the 'tear' effect, how do you get both sides to match up? By using a stencil?
How would you make a stencil that would work on the curve of a canopy? Trial and error?
sneasle is offline Find More Posts by sneasle
Old Dec 10, 2008, 04:37 PM
JustinMoore12 is offline
Find More Posts by JustinMoore12
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
What I did with my first was use the negative image (Microsoft paint) and print it out in a suitable size, lay some 2" painters tape down on glass and either cut the tear out on the glass and then apply (can be very tricky) or draw it on the tape and apply it to the canopy and then very gently use an exacto to cut just the tape and try not to cut too deep into the canopy. You can use one of our images for reference or something you find on the internet. You can also get rolls of frisket or transfer paper from most craft stores that work pretty well on curved surfaces but the low tack has a tendancy to lift up on a sharp edge.
Im sure the OP will have some thoughts as well.
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Dec 10, 2008, 07:09 PM
DriveWRX is offline
Find More Posts by DriveWRX
...A Better Way to Fly
DriveWRX's Avatar
USA, IL, Palos Heights
Joined Oct 2006
I do exactly what Justin describes in the first method.
Here's the steps:
- Take a profile (from the side) picture of the canopy on the heli
- Open that picture in a paint/photo editing program
- Draw a pattern on the canopy
- Print the pattern out to test size/fit on the real canopy and adjust as needed
- Once the size/fit is to your liking, use the paint/photo program and "flip" the pattern to get a mirror image
- Print 2 patterns, one for each side
- Put tape (I use blue painters tape) down on glass or a cutting mat, over lapping the edges to make a piece of tape big enough for the pattern
- Lay a print on top of the tape and tape that down so it doesn't move
- Using a very sharp X-acto knife, cut out the pattern. Make sure to use enough pressure to cut thru both the print and the tape underneath
- Carefully lift off the cut out tape pattern from the glass or mat
- Transfer it to the canopy
- Repeat for the other side
DriveWRX is offline Find More Posts by DriveWRX
FS: Lots of Micro Heli Canopies Hooters Driver Aircraft - Electric - Helis (FS/W) 11 Oct 25, 2004 09:16 PM
Question Cheap source of heli canopies??? 14U2NV Micro Helis 5 May 03, 2004 12:56 PM
Micro Heli Canopies darthdrk Aircraft - Electric - Airplanes (FS/W) 1 Nov 27, 2003 12:50 AM
Subject: New Canopy Decals for Micro Heli Canopies... born2net Electric Heli Talk 1 Sep 26, 2002 12:45 PM
