Old Feb 16, 2003, 10:19 AM
DiabloKid is offline
Find More Posts by DiabloKid
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Need your thoughts on my first Brushless!
being to new to this side of the fence I'm wanting to know what you guys suggest for upgrades. I know there is a difference in picking power for example a the GWS A-10 and my little Firebat. After reading some posts I figured to toss out the stock Firebat mototr and go with a spare 400 I have and some gearing I oredered from Tower. I think once I figure it out it will fly decent over stock per your guys suggestions over in the Firebird thread.ok..now what im getting at is where I can purchase better motors and an inexpensive brushless setup. I have a Multiplex Twinjet that I wanna get more power to but dont want to spend too much. Any thoughts? Links?
thank you
may peace be with you
matt
DiabloKid is offline Find More Posts by DiabloKid
Old Feb 16, 2003, 09:38 PM
juantrinidad is offline
Find More Posts by juantrinidad
PUGZ RULE!
juantrinidad's Avatar
Joined Jun 2002
Check out www.dynamoelectrics.com...
i believe that dynamoelctrics offers the best deal on mega 1615 motors. these are speed 400 size equivalents.
for all round use, i would suggest the 3 or 4 turn. they are killer motors direct drive and are great when geared too.
there is no cheap way to put brushless motors on a twin jet. i have thought about it a lot, since i want a BL twin jet too, and two motors is a lot of money which ever BL way you go. not to say that its not worth it, i just cant get myself to plunk down that much money for a single set up.
IMHO there is really no foamie as beautifull as the twinjet. not to mention that it flies great too!
rgds, JT
juantrinidad is offline Find More Posts by juantrinidad
Old Feb 17, 2003, 07:52 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Yep, there is no such thing as an "inexpensive" brushless setup. Even from DynamoElectrics.com, you're talking $139 per motor, because you need a separate ESC for each motor. If you think about it, though, that's less than what you'd spend for a small OS or Saito 4-stroke engine, so it really isn't that out of line.
mkirsch1 is offline Find More Posts by mkirsch1
Old Feb 17, 2003, 09:06 AM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Hi Peace Loving Diablo,
I just saw Twinjet on San Diego show flying great with ONE brushless ( I think it was outrunner). So there is a different way to skin the cat ! May be somebody else have more info about this set up. BTW, I used to have a blast with just stock Twinjet on 8 cell 1500mA. What a great plane!
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Feb 17, 2003, 11:17 AM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
wow cool, I run stock motors with 8 cell 1700mah on mine
Old Feb 17, 2003, 11:32 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
Dont fool arround
I just ordered a second mega 16 15 3 from M.E.C. has a great combo with superbox any ratio you want (thats a 1 oz gearbox good for at least 500 watts)with parts avalibility.$115 this cant be beat.This will go in my HOB acro cub. 150 watta per lb on 10 cells
jmolwitz is offline Find More Posts by jmolwitz
Old Feb 17, 2003, 12:22 PM
anatak is offline
Find More Posts by anatak
living in Japan member
Belgium (Europe)
Joined Oct 2002
I ve been thinking about putting my cargo BL so that is double your pain.
but I ll buy motor after motor (all mega 16/15/4) and use them now in other planes
maybe some day I ll have a BL li poly loaded cargo
anatak is offline Find More Posts by anatak
Old Feb 18, 2003, 04:33 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Why do you need a separate ESC for each motor? I deliberately put three 4mm connectors on the output of my JETI 30-3P controller so that I can swap it between plane/helis with different brushless motors fitted. I bought the 30A ESC, even though I didn't need that current handling in the first application as a bit of "future proofing". It's very easy to unplug the ESC from one aircraft and plug it into another. Now that you can get brushless motors such as the MPJet 25/35 for less than $50 it means that you can easily put a brushless in most applications.
Cliff
LATER: DOH! Sorry guys, I hadn't realised that we were talking about a twin motored plane here. Obviously for that mkirsch is absolutely right, you do need two ESCs! (sorry)
Wright Flyer is offline Find More Posts by Wright Flyer
Old Feb 18, 2003, 10:15 AM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
>>Why do you need a separate ESC for each motor? I deliberately put three 4mm connectors on the output of my JETI 30-3P controller so that I can swap it between plane/helis with different brushless motors fitted. <<
You can run one brushless motor at a time with a brushless ESC. You'll be fine switching between motors. You may have to spend some time reprogramming your ESC for each motor's maximum efficiency settings, but that's fairly simple.
What they were talking about is running two motors simultaneously with one controller. Brushed applications do this all the time. But Brushless ESC's like to monitor the motor. It's hard to monitor two motors at the same time
I've seen this tried and it usually results in chaos between motors and ESC.
Darren Hintze is offline Find More Posts by Darren Hintze
Idea need some help on my first heli irust Micro Helis 6 Oct 18, 2004 12:06 AM
Cool Need advice on my first 'wood' plane: Miniflash temp_oct Parkflyers 15 Oct 11, 2003 01:03 PM
Your Thoughts on My Wild Idea Craig Logan Power Systems 1 Mar 06, 2002 07:35 PM
Need your advice on my FMS House Fly model JStory Electric Heli Talk 4 Dec 29, 2001 05:44 PM
