| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Turnigy Sponsored Pilot
Another Electric Conversion of the Hangar 9 Sukhoi
I decided to buy the Hangar 9 Sukhoi SU-26MM for my next project. I managed to get it just before the price went up by $200.00
(http://www.hangar-9.com/Products/Def...ProdID=HAN1225) Because I am an electric flyer I decided do do this as an electric conversion. I thought I would try the low end (price) motor and ESC first to see if they are up to the task. I purchased the HXT 80-100-130 motor and the Turnigy Sentilon 100A speed controller ( http://www.hobby-city.com). Total investment was about $250.00. I wanted to make sure that this combination would work running using 12S lipos. I will likely run 4-6S packs in a 12S-2P configuration. In order to test the motor I built a test stand that would allow me to also measure thrust using a digital fish scale. HXT 80-100-130 motor Turnigy Sentilon 100A speed controller Xoar 27x10 propeller 4- 6S Hyperion LVX 5000 batteries 12S-2P 40 lbs 11 oz thrust 116 Amps 5215 Watts The bad new is speed controller loses timing with the motor when I moved the throttle too quickly. I tried the timing settings on the speed controller. I already had it on the high timing setting which was definately the best. It will however work fine if I am gentle on the throttle but this will not likely work too well when hovering, so I guess I am in the market for a better speed controller. Anybody have any ideas! I am using the same Turnigy Speed Controller on my Hyperion YAK 180 (Hyperion motor) and it works just fine. I guess that the programming was not designed for the mass of the big HXT motor. More details later on the build of the plane. Last edited by Geoff Dryer; Oct 04, 2008 at 05:07 PM. |
#2 |
Hi Geoff: Have You Looked Into the Castle Creations HV 110 Speed Controller? The Specs Do Not List the Maximum Burst Current, But Will Run @ 110 Amps Continuous.
Cheers: Joe |
#3 | |
More is better, always!
What are you seeing for RPM's? Jack |
#4 |
Fly DW foamies!
cool, im doing a similar conversion here:
http://www.rcgroups.com/forums/showthread.php?t=901041 i would like to see how this one is going turn out. Last edited by appleflyer; Oct 01, 2009 at 02:18 PM. |
#5 |
Fly DW foamies!
what watt meter are you using for that?
#6 |
AppleFlyer - I was already following your thread with interest. I was trying to avoid purchasing an expensive (but probably really great) Jeti ESC.
I just found a fellow club member who can lend me a Castle 110HV for testing. We have not had too much luck with the Castle HV controllers in our club though. I am using a Watt's Up meter that did not smoke at 115 Amps so I am impressed. JFetter - I don;t have an RPM meter but If I can borrow one I will send you the numbers. |
#7 |
hey Geoff Dryer
I'm glad to se you started your project. I would see what type of performance you get out of using 12s 1p 5000mah. I think you can get the same performance with a lot less weight. I have been flying my suk on 12s 2p 4200mah and the flying weight is 23.5lb. if you can save 3.lb on li-po's and 1-2 lb. on the motor / esc that will bet you in the 19lb. range. the guys at 3D hobby are flying a 35% close to that weight on 12s1p 5000mah. If I were to to redo my suk I would look in to a lighter motor than the Hacker A100 it is 4.5lb and it needs a lot of mah. you will need to add wieght to the nose of the plane if you have a light motor. mine was right on CG but the motor and ESC is the same weight as the DA85 you should be in good shape if you keep the RX batterys up front and the lipos on the fuel tank mount let me know if you have any questions i will be following your build Ron |
#8 |
Hello BSIPRO;
I contemplated a Neu geared motor and Steve Neu sugggested a 1527 1.5Y. The issue is that this light motor would likely require weight in the nose of the plane even if I pushed the batteries as far forward as possible. I have ordered the Flightpower Evolite 6s 4270 packs. They are only 580 grams each. At a 100 amps I came to the conclusion that a 2P configuration would be necessary. |
#9 | |
Jack |
#10 |
My Neu powered 30% yak came out way tail heavy. So I took the 2 elevator servos out of the tail and moved only 1 of them into the fuse and made a double pull pull system. I had to add 2 lbs of lead to get my plane to ballance before and it weighed over 20 lbs. Since my mod it now weighs in at 18.7 lbs. It took a little work to do but was worth it to save all that weight.
Mark |
#11 |
MarkF - Which Yak is that?
#12 |
It's the 30% magichand yak from TBM.
Mark |
#13 |
The Build
Here are the components (other than the motor and ESC) that I have sourced for this project:
4 - FlightPower Evolite 6S-4270 batteries (580g each) JR-790 PCM Receiver Smart-Fly Power Expander Pro with failsafe switch Duralite 2 cell A123 receiver pack (2300 mah) 3 - Hitec HS-5955TG servos 2 - Hitec HS-5985 servos 4 - MPI 1.25" aluminum servo arms (MXKA1251 www.maxxprod.com) 1 - MPI 1.5" aluminum servo arm (MXKA1501 www.maxxprod.com) 3 - 36" Hitec heavy duty twisted servo extensions 1 - 24" Hitec heavy duty twisted servo extensions 4 - 12" Hitec heavy duty twisted servo extensions M5 x 60mm bolt to attach the spinner to the HXT motor MPI 3.75" aluminum spinner 5" aluminum hub main wheels (grass fields) 1.75" tail wheel The plane comes with all surfaces hinged and sealed (except the rudder). The only real work so far is installing the pilot, dash and gluing the windscreen to the canopy. Gluing the canopy turned out to be a real pain as it is difficult to hold the windscreen in place while the glue dries. I used lots of masking tape. With the big servos running at 6V I decided to use a Smart-Fly Power Expander. This provides power for the servos rather than running power through the receiver. The failsafe switch is electronic so no worries about a mechanical switch failure. The Power Expander also provides regulated 5V for the receiver. The Duralite A123 pack has a built in balancer. Last edited by Geoff Dryer; Oct 05, 2008 at 10:13 PM. |
#14 |
Fly DW foamies!
nice. so you are building a sukhoi in this thread, and the cap 580 in you're other thread?
#15 |
FlyRobert is building the Cap. We just happen to be using the same HXT motor.
| Thread Tools | |
| Wanted Hangar 9 Sukhoi SU-31 (1/3 Scale) Cowl needed | Steve H. | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 24, 2006 07:22 PM |
| For Sale Hangar 9 Sukhoi SU-31 1/3 scale | fockewulf37 | Aircraft - Fuel - Airplanes (FS/W) | 1 | Dec 02, 2005 07:00 AM |
| For Sale 1/3 Scale Hangar 9 Sukhoi SU-31 | fockewulf37 | Aircraft - Fuel - Airplanes (FS/W) | 6 | Oct 26, 2005 06:34 AM |
| Hangar 9 Sukhoi SU-31 NIB | Festus1567 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 14, 2003 05:47 PM |
| Hangar 9 Sukhoi CG update | dsnyder | Fuel Plane Talk | 0 | Dec 30, 2002 12:16 PM |
