Old Feb 16, 2003, 07:30 AM
neonbutterfly is offline
Find More Posts by neonbutterfly
LSF186
neonbutterfly's Avatar
Wayne, NJ
Joined Jan 2003
How do I stop the prop parallel to the fuselage sides?
Me Again !! Thanks for all your help so far. Real newbie ???? here.
How do I stop the folding prop so that it is parallel to the fuselage sides, like I see in all the photos of electric sailplanes.
My thought is that when the motor (AXI 2820/10) is stopped after the first start up, simply loosen the prop and rotate it so that it is lined up where you want it.
Will the motor stop in the same position every time? You may want to also look at my post regarding settin up my TMM speed control.
Bob
neonbutterfly is offline Find More Posts by neonbutterfly
Old Feb 16, 2003, 08:38 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
It won't stop in the same place each time. Why does it matter where it stops?
DaveSawers is offline Find More Posts by DaveSawers
Old Feb 16, 2003, 09:28 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Makes no difference. Go fly instead of worrying.
..a
Old Feb 16, 2003, 10:07 AM
Ron Daniels is offline
Find More Posts by Ron Daniels
Ron Daniels's Avatar
Kitchener, Ontario, Canada
Joined Jan 2001
I use a prop-stopper on my Tempest MK II. My Mk V has been using the same prop for 3 years, as the chin scoop allow it to land with the prop turning with no damage.
It is just a micro-servo in the cowling, with a length of nyrod that projects out into the prop's arc to stop it where I want it. It saves me props on belly-landing.
You have to make sure that the motor is turned off before you kit the retracts switch, though!
Ron Daniels
Ron Daniels is offline Find More Posts by Ron Daniels
Old Feb 16, 2003, 11:28 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Bob,
It doesn't matter where the prop stops initially.
I have a theory that if the prop stops with the blades vertical, then the bottom blade will tend to hang down, and then get moved by the passing air until it can fold easily ie., when horizontal.
Then again, I could be talking nonsense.
tim
tim hooper is offline Find More Posts by tim hooper
Prop windmilling: How do I stop it? CloudyBright Aerial Photography 33 Nov 13, 2004 11:03 AM
How do I stop the wiggles airorv Electric Plane Talk 18 Aug 04, 2003 09:10 AM
