Old Feb 16, 2003, 07:52 AM
Carl Farrington
Carl Farrington
Guest
n/a Posts
using GV1 with 7-ch JR-X378 TX
I'm hopefully going to be having a GV1 soon, but I think I might run into
problems setting it up with my 7-channel JR X-378.
I've read the GV1 manual, and it talks of using a switch for changing
between speeds. I don't want to do this, I want the speed to be set when I
select a flight mode (N, I1, I2)
Any tips on how to achieve this? GV-1 specs say minimum of 8 channel, and
they imply that headspeed won't be switchable without a spare channel.
thanks,
Carl
Old Feb 16, 2003, 10:32 AM
Siam Heli
Siam Heli
Guest
n/a Posts
Re: using GV1 with 7-ch JR-X378 TX
I don't know the JR X-378. But you got 7 channels - so there is one to
spare, right? If you can map this one to your flight mode switch you should
be fine.
GV on-off = stick mode (setup on GV-1), leaves you with just one channel for
the different speeds.
Martin
"Carl Farrington" <carl@000compsup000.net> wrote in message
news:b2nv8d$emu$1$830fa7b3@news.demon.co.uk...
> thanks,
> Carl
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.455 / Virus Database: 255 - Release Date: 13/02/03
Old Feb 16, 2003, 06:45 PM
ArnS
ArnS
Guest
n/a Posts
"Carl Farrington" <carl@000compsup000.net> wrote in message news:<b2nv8d$emu$1$830fa7b3@news.demon.co.uk>...
> thanks,
> Carl
You can follow the example in the manual where you set N to below
minimun RPM which effectivley turns the GV-1 off. Set I1 to 1550 or
whatever and I2 for something higher. I have a Futaba F8 and this
works very well.
Good luck.
Arn
Old Feb 17, 2003, 07:02 PM
crouisk
crouisk
Guest
n/a Posts
aschmid3@tampabay.rr.com (ArnS) wrote in message news:<e72c3cba.0302161132.7b5be597@posting.google. com>...
> > thanks,
> > Carl
> works very well.
> Good luck.
> Arn
Any chance I can setup the GV-1 on a "lowly" Futaba FF6 or am I going
to have to buy a decent Tx. I was hoping setting up a GV-1 would mean
I would not have to upgrade to a set with pitch curves etc.
Scott.
Old Feb 17, 2003, 08:22 PM
Carl Farrington
Carl Farrington
Guest
n/a Posts
"crouisk" <scottwil5on@hotmail.com> wrote in message
news:1f42ecb0.0302171542.3c2911d7@posting.google.c om...
> Scott.
You'll be able to us he governor with your set, but you wont be able to
change speeds in flight - it'll only have 1 speed (rpm) setting. You would
have to use the Throttle-stick switching, whereby the GV1 turns itself on
when you bring the throttle stick up to 17% (and the engine is at 70% of the
desired rpm already)
This, however, has absolutely nothing to do with pitch curves. It would
allow you to disregard throttle curve settings (dangerous though!, if the GV
fails), but pitch curves are a totally different thing all together
Carl
Old Feb 18, 2003, 08:12 AM
crouisk
crouisk
Guest
n/a Posts
"Carl Farrington" <carl@000compsup000.net> wrote in message news:<b2rvud$a7k$1$8300dec7@news.demon.co.uk>...
> > Scott.
> Carl
OK , thanks. Would it be a worthwhile thing to do given the
limitations of the Tx ?
Now I'm only a few months into this game but I was under the
(mis?)impression that pitch curves were pitch vs throttle , using a
GV-1 significantly reduces throttle variations so I could run the FF6
with Normal and Idle1 giving me two pitch ranges. I figured this was
a good enough step forward to reduce the need for me to get a better
Tx.
Old Feb 18, 2003, 10:32 AM
Steve Simpson
Steve Simpson
Guest
n/a Posts
While you may eventually want to upgrade to a better TX for whatever reason,
adding a GV-1 governor does not require it.
Zero extra channels are needed to add a GV-1.
Changing head speed in flight would require an additional channel . . . but
changing head speed in flight is not required (nor beneficial, in my
opinion).
Pitch curves set the maximum pitch of the rotor blades and the linearity
with which pitch-changes follow stick movement.
Throttle curves are for the purpose of attempting to create a synthetic
governor by matching throttle to load . . . . but a real governor eliminates
that need.
There are those who claim to have refined the 'art' of throttle curve
setting to the point of perfection . . . . but only through the proper
'special knowledge' attained from years of experience together with
'secret' linkage theory.
This delusion relies on physics being alterable by a model helicopter . . .
.. and that is pretty unlikely. The load imposed by 5 degrees of pitch, for
example, is not always the same and there is no mechanism by which a static
curve can compensate for this.
The throttle curve specifies 'x' throttle for that pitch amount regardless
of whether the heli is in a lazy hover or reversing momentum in a aerobatics
maneuver. Some amount of compensation is available though multiple flight
modes (i.e. multiple curves), but the curve is still static and has no
ability to sense current load as does a real governor.
Adding a GV-1 is a great move! Most users look back on it as their best
addition (short of a HH gyro). There were two things that made heli set-up a
pain in the butt. Revo mixing and Throttle curves. Revo mixing went away
with modern gyros and Throttle curves went away with governors.
Avoid both only if you enjoy screwing around with your heli set-up for two
hours for every 10 minutes of flight time. Not to mention enduring endless
debates about the 'best' way to set-up your curves . . . and then trying to
decide which of the diametrically opposed opinions is correct.
Governors are not likely to suddenly disappear from the earth so there is no
need to fear 'relying' on them. The now antiquated skill of throttle curve
setting is simply no longer needed . . . much to the chagrin of the
'experts' at same.
On the other hand, a reason you might want more than one pitch curve is to
have more positive collective for autorotations.
You might benefit from a 'learning' curve (no pun intended) with less
negative pitch so that you will be less likely to slam the heli down in an
instant of over-control brought on by the Natural Newbie Thumb Reflex to
having your underwear suddenly sucked up your butt when the heli
unexpectedly blooms up from a wind gust.
Personally, I do not subscribe to that method. I think that it is better to
set the pitch curve to the maximum the heli can tolerate and use a simulator
to learn to resist NNTR rather than impose a mechanically enforced limit.
Setting up multiple 'special use' curves only creates a habit that you must
then un-learn at some future point. Different flight modes with their
various head speeds, throttle curves, pitch limits, etc. are really a hold
over from the pre-governor, pre-simulator days when such things were
actually beneficial . . . . and perhaps even necessary.
There have always been various arguments against governors and simulators
and single flight modes and so forth, but then again there are still
arguments against the automobile . . . . after all, horses worked fine for
thousands of years . . . .:-)
Old Feb 18, 2003, 03:12 PM
Beav
Beav
Guest
n/a Posts
"Steve Simpson" <simpsons34@NIXcox.net> wrote in message
news:bgs4a.63733$QU2.1761736@news2.west.cox.net...
reason,
but
> opinion).
eliminates
> that need.
Steve, as a long time "secret linkager" I thought I could "build" a good
relationship between throttle and collective, and so I can, but it's nowhere
near what a gov can do. As an experiment I tach'd my Futura on the pitch
cirves and we saw a rev variation of 150rpm during a single flight. With the
gov switched on (A robbe CSC 2200 not the GV-1) I had a variation of TEN
revs for a similar flight. That's not easy to better.
for
static
aerobatics
a
to
no
> 'experts' at same.
I don't know a single modeller who's pissed off at the benefits a gov
brings.
to
simulator
Well that's a "horses for courses" opinion but it relies heavily (wholly) on
the FNG having a sim. Not all do and not all will buy one as some feel that
the 200 "whatevers" are better spent on a better radio/gyro/governor/woman.
The top flyers in FAI don't use a full 20 degree pitch curve when they fly
the hovering manoeuvres in comps either, because they find it more
comfortable to "restrict" the collective throw for this mode of flight.
must
For the majority of flyers, they're still as much a necessity as they ever
were too. Not everyone wants to fly 3D and that's where the plus/minus
everything comes into it's own. Making the throttle stick as sensitive as it
NEEDS to be for 3D flying all the time doesn't help. But that's just my
opinion.
for
And cars are still having a hard time jumping fences and fording rivers :-)
There's more cars been pulled out of the shit by horses than there's been
horses pulled out of the shit by cars:-)
Beav
Please note my E-mail address is "beavis dot original at ntlworld dot com"
(with the obvious changes)
Beavisland now lives at
www.beavisoriginal.co.uk
Old Feb 18, 2003, 05:52 PM
crouisk
crouisk
Guest
n/a Posts
"Steve Simpson" <simpsons34@NIXcox.net> wrote in message news:<bgs4a.63733$QU2.1761736@news2.west.cox.net>. ..
> opinion).
> that need.
> 'experts' at same.
Thanks for that. From what you say I don't see me needing to shell
out 1K for a F9Z type Tx or anything for that matter.
What could really justify it other than .....what ? Anyone ?
The simplicity of your approach appeals. The less 'magic' and 'darks
arts' the better.
So is this the way to go now that I can hover and have started basic
circuits : throttle -> GV-1 single speed.
Maximum mechanical pitch range
Different max and mins for Normal (-2 0 7) , Idle 1 (-9 0 9) and
Throttle Hold (-2 0 12).
Centre on 0 pitch and learn to hover at 3/4 stick.
Or what would be the best settings to cover most options with minimum
fuss ?
Scott.
Scott.
Old Feb 19, 2003, 09:42 AM
Steve Simpson
Steve Simpson
Guest
n/a Posts
> arts' the better.
Presuming that like most pilots, you intend to eventualy progress to
aerobatics, I'd say you have a winner.
I learned to hover with the then recommended 'hover' setup and after all
the time I had spent getting comfortable with 1/2 stick over, I had to
un-learn that and re-learn 3/4 stick hovering . . . . not the most
efficient approach and one that can plant a heli when you stop a fast decent
with only half stick . . . only to find out that now you need 3/4 . . .
hopefully in time to keep the bird out of the dirt.
Once you become a good pilot, the 'normal' mode will be of no use . . . .
except to startle you when you do that first roll of your flight and only
then realise you are in the wrong fligt mode . . . . as the heli rolls on
it's back and tried to maintain altitude with only 2 degrees of collective .
Another disadvantage is that on a windy day, -2 may not be enough negative
to get the bird down without literally pushing the nose over and flying it
down . . this creates an abrupt 'mood' change in the heli which can be
unnerving for a newbie.
If you feel safer at first with a 'normal' mode, you can still work your way
out of it by adding a degree at a time to the negative as you become more
confident in your ability to not panic slam the stick.
In any event, most of this stuff just boils down to personal preference.
Collect as many opinions as you can and then do what seems best to you.
BTW, the ultra adjustibility and ultra mixability of the ultra-fancy (and
ultra expensive) Tx's are far less usefull in these days of superb on-board
electronics (gyros, governors, etc) . . . . I wouldn't waste the money on
top-of-the-line Tx because with a good grro and governor, you simply have no
use for the miriad of fine adjustments and mixes available.
That said, I would strongly suggest you get a Tx/Rx set that utilizes PCM.
Arguments against PCM are without merit. Unfortunately, some of the worst
advice still being handed out is that FM is somehow 'better' because it will
'warn' you of problems so that you can then land and fix them. This bit of
stupidity ignores the fact that more often than not, the heli will save you
that trouble by 'landing' itself without your help . . . . particularly if
the 'warning' comes in the form of full left aileron when the heli is 2 feet
off the ground.
Old Feb 20, 2003, 03:22 PM
crouisk
crouisk
Guest
n/a Posts
"Steve Simpson" <simpsons34@NIXcox.net> wrote in message news:<MzM4a.2672$ub.328490@news2.west.cox.net>...
> > arts' the better.
> off the ground.
I've read through a few of the threads for PCM vs PPM so I won't go
there. Needless to say upgrading my radio gear in 50-80 chunks
(servo's,Rx,gv-1) is a much more appealing option than ditching my Tx.
Thanks for the advice. :-)
Discussion 9252 with JR460T gyro... JR XP652 TX... SERVO TRAVEL LIMIT xADRYANx Fuel Heli Talk 5 Jan 31, 2006 02:27 PM
JR X378 TX any good? GuyP Beginner Training Area (Aircraft-Electric) 0 Nov 19, 2005 02:34 AM
FS: JR Quattro TX on ch 27 with JR grey cap ch 27 RX crystal Dukester Aircraft - Electric - Airplanes (FS/W) 7 Jun 28, 2004 07:59 PM
Rave For Sale! Expert 7 Ch. Tx With Mixing tnt Aircraft - Fuel - Airplanes (FS/W) 1 Mar 26, 2004 10:10 PM
FS: JR Quattro TX CH 26 with warranty (4 months old) temp_oct Aircraft - Electric - Airplanes (FS/W) 7 Nov 04, 2003 05:07 PM
