Old Feb 12, 2009, 05:19 PM
mech9 is offline
Find More Posts by mech9
Dragon
mech9's Avatar
Vancouver B.C. Canada
Joined Sep 2004
Dag,
That drawing of your air tanks in the fuse looks great, brings to mind putting fins on them and mounting them in the bomb bay.
Cheers.
mech9 is offline Find More Posts by mech9
Old Feb 12, 2009, 06:04 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi Chickenthief...
That theory only applies for AC Just look at the transformer in Your welder, it's solid wires! Wireing in houses are also solid. The sole reason for mulitstrand wires is flexibility
Sorry...not true... I was an electrician for more than 25 years. Most houses are wired with solid wire due to ease of "make-up". But you also must understand, when you pull AWG 14 or AWG 12 gauge wire in a home, you are only pulling up to 15 or 20 amps, while in our models, you are pulling much more amperage over the same size of wire. If you try pulling 65 amps with AWG 12 wire (especially solid), you will melt it, yet we do this all the time with the multi-strand wire we use for our planes.
As to the welder, yes the coils are solid copper, but they are also very large diameter copper, and a larger diameter also has more surface area...
Besides....current is current, whether AC or DC, the only difference is that one flows only in one direction,(DC) while one changes direction at 60 cycles (U.S.). It;s all coulombs flowing ON the surface of the wire, not through.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 12, 2009, 07:09 PM
DavidB. is offline
Find More Posts by DavidB.
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Originally Posted by Draknkep
Dag, I`m sure you know this, but for those that don't, electrical current does not actually flow "through" the conductor, but rather on the surface of the conductor, this is why multi-strand cable is able to carry more current than solid wire can.
Only in super high frequency AC applications is this true. DC couldn't care less how many strands are there. Welding cable is high strand because the welder needs complete control over the weld bead..and stiff cable doesn't help.
DavidB. is offline Find More Posts by DavidB.
Old Feb 12, 2009, 07:17 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
Thank you for stopping that before it got any further.
"Skin affect" Applies to only higher frequency signals.
Dag:
Let em know the weight when you can. If if is light enough and if you end up with some extra I might take it off your hands.
sneasle is offline Find More Posts by sneasle
Old Feb 12, 2009, 07:20 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
To clear this up once and for all, the AWG table for wire sizes:
http://www.powerstream.com/Wire_Size.htm
Old Feb 12, 2009, 07:50 PM
SteveT.'s Avatar
San Jose, CA
Not to argue this any farther....but try using a piece of "romex" type house wire, and pull 65 amps (I.E. a mid range electric plane motor) and see how long it lasts...
Ok... I'll shut up now...
SteveT
Old Feb 12, 2009, 08:26 PM
DavidB. is offline
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Wire resistance is a function of cross sectional area, you can look at the link below. Skin depth is only applicable in VERY high frequency AC systems.
http://en.wikipedia.org/wiki/Electrical_resistance
http://physics.bu.edu/~duffy/PY106/Resistance.html
http://hypertextbook.com/physics/ele...ty/resistance/
http://knowledgerush.com/kr/encyclop...al_resistance/
http://www.blurtit.com/q331026.html
http://hyperphysics.phy-astr.gsu.edu...ric/resis.html
These are solid copper.
http://en.wikipedia.org/wiki/File:Busbars.jpg
Old Feb 13, 2009, 01:43 AM
SteveT.'s Avatar
San Jose, CA
Hmmmm....
So, do you really think that the many 1000's of feet of 250mcm, 500mcm, 750mcm, 1000mcm (better known as 1 mil), and even 2000mcm (better known as 2 mil) stranded cable that I have pulled in 25 years as and electrician working on power houses, foundries, and other large factories such as the Boeing plant in Everett, Washington where they build the 747s, and 767s, would have worked just as well if they were solid soft drawn copper??? I doooooonnnn't tink so.....
And...those busbars that you are referencing are only 1/4" to 3/8" thick by about 3" to 4" wide...so just how much surface area do you think they have?? And you notice that they have multiple layers for each bus..gee....more surface area... The Caterpillar Foundries in Mapleton Il.(which I helped build), also have busbars (which I helped to install), carrying 13,800 volts to their induction furnaces....they aren't big honking thick bars, they are 1/2" thick by 12" wide....again, for more surface area...
But....this is not my thread, and I'm sorry for thaking it off track, so... back to Dag's wonderful plane...
Dag, your aluminum sheeting is looking great, as I have said before, this will be and amazing plane when finished..
SteveT
Old Feb 13, 2009, 01:58 AM
DavidB. is offline
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Updated my post with more links. If you still think somethings fishy we can talk about it in emails. No point muddying this up further.
Old Feb 13, 2009, 02:12 AM
SteveT.'s Avatar
San Jose, CA
The majority of the threads you have listed are all talking about resistance, this has nothing to do with surface theory, there can still be resistance on the "skin" of a material...Sorry, you're not going to convince me otherwise, so as you said, lets not continue this here...
SteveT
Old Feb 13, 2009, 07:50 AM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
Guys, get a room eh?
Tonystott is offline Find More Posts by Tonystott
Old Feb 13, 2009, 01:55 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
High frequency AC.
Rickn816 is offline Find More Posts by Rickn816
Old Feb 13, 2009, 02:26 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
On the bright side, at least it is a technical argument?
Old Feb 13, 2009, 03:07 PM
Owen Hedger is online now
Find More Posts by Owen Hedger
Crafter of flying plugs
Owen Hedger's Avatar
Australia, NSW, Armidale
Joined Feb 2007
http://en.wikipedia.org/wiki/Skin_effect
In copper, the skin depth at various frequencies is shown below.
frequency d
60 Hz 8.47 mm
10 kHz 0.66 mm
100 kHz 0.21 mm
1 MHz 66 Ám
10 MHz 21 Ám
So as the frequency goes up the skin depth get shallower. So even at 60Hz skin effect depth is 8.47mm.
"In Engineering Electromagnetics, Hayt points out that in a power station a bus bar for alternating current at 60 Hz with a radius larger than 1/3rd of an inch (8 mm) is a waste of copper, and in practice bus bars for heavy AC current are rarely more than 1/2 inch (12 mm) thick except for mechanical reasons."
Does the touching surfaces in a multistrand cable still count as 'skin'?
Brushless ESC's are switched 10's of KHz but are they switched to produce AC?
Owen Hedger is online now Find More Posts by Owen Hedger
Old Feb 13, 2009, 04:05 PM
Angelo is offline
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Owen, you may be great, but if you're going to quote sources, Wikipedia is not the way to go. ANYONE can go in and edit a listing, hell, I could go in right now and re-write it to say that depth is what matters. Some one else might see that and fix it. Then again, maybe not.
"Wikipedia, the triumph of democracy over truth."
Angelo is offline Find More Posts by Angelo
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
