And when you say pivot point you may be meaning their bearings, and not geometry. Real ones are not 100% smooth (the last one is funny):
http://www.youtube.com/watch?v=TZNjrQfTP5s
Thanks, DAG |
Wow, interesting! I see what you mean about full-scale not being smooth either, I guess in the end physics is physics and the scale of the object doesn't change the rules. The "jerk" when the gear is both initially started moving down as well as initially started moving up seems more due to the pivot point rotating from neutral point and causing motion...
Jack |
Smaller actuators are used to unlock the gear, so it can retract. you also don't want the gear retracting through closed gear doors. The jerky-ness that you are seeing occurs as hydraulic press is applied and removed from different actuators during the cycle. Remember that although all three landing gear are retracting simultaneity; they are not synchronized. to happen at exactly the same time. Rick |
Joined Jan 2007
Dag, this might be the solution to your cycling problem with your gears: http://www.wingspanmodels.com/Produc...ronics/LG.html Saul |
I was looking at that yesterday. I think I am going with the ultra precision valve system. Thanks, DAG |
Jack |
Here is a small update,
Work has me slammed, but I did get my 3D drawing exported to see if it can be CNC. Gary at Morganmill is helping me with importing my 3D CAD into his CAM, if it work the parts will look like this. Also last night I test fitted my new firewall and it fit perfect. DAG |
If all goes as planned this is what version 7 will look like after the parts are CNC.
The reason for 4 air cylinders is that a great retract expert from up north said that if you can not cycle the gear at 50 psi keep adding air cylinders until you can. With 4 she goes up at 48 psi, with 3 it took 65 psi. Rock On! DAG |
Yes that 3rd one is wild, I guess they would just have to have some one fly up with a Stearman and pull the door out of the way DAG |
Interesting to follow along.
Now I have to ask, if you need 4 air cylinders per main gear (8) and 2 (?) for the nose (total 10?), how big is the air tank to power all this and how many cycles can you do before no air left? I've never had the pleasure to play with air retracts. |
Thanks, DAG |
I guess there is no shortage of real estate to put all this stuff though eh
I will post a 3D of the air cylinder layout later tonight. Thanks, DAG |
| Thread Tools | |
| Good B-36 site (drawing with cross sections, too!) | Thomas B | Scale Electric Planes | 26 | Oct 11, 2011 09:14 PM |
| B-36 B-52 | kgmorris | Scale Electric Planes | 20 | Jan 02, 2009 06:27 AM |
| b-36 | dorysch1 | Scale Electric Planes | 32 | Feb 01, 2004 08:33 PM |
| Questions about my wally B-36...I'm new to foam. | Boba_Fett | Foamies (Kits) | 8 | Jun 11, 2002 03:36 PM |
| B 36 | Trobber | Parkflyers | 3 | Dec 30, 2001 12:33 PM |
