Old Sep 28, 2012, 12:29 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Originally Posted by dag214 View Post
Yep!!!!
Last night, was going to take a pic with them and my girl and post.....
They are perfect, I had no idea they made the kind you can write on.
THANKS 110%%%%
DAG
Yeah the ones you can write on are great except for the fact that I can't read my own handwriting.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Sep 28, 2012, 08:32 PM
byrocat is offline
Find More Posts by byrocat
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
Originally Posted by ChuckA View Post
A copilot is more than a second pair of eyes as your B25 copilot demonstrated. He must understand what information you need as well as when and how to tell you. A copilot giving me information I donít need is frequently worse than no help. I learned this long ago when I first started fly pattern contest and later scale, pylon racing, and sailplane contests. Donít tell me how to fly but what maneuver is next, when the flagman signals the turn, or what lift the other sailplanes have found. My pylon caller would not be much use at a sailplane contest. I am sure you will give your usual careful planning and training to the copilot for your B36.
Spotter, copilot, whatever..... the job takes training and practice so that the right information is obtained and transferred at the right time without a lot of miscellaneous chatter (distraction).
byrocat is offline Find More Posts by byrocat
Old Sep 30, 2012, 09:39 AM
coptercptn is offline
Find More Posts by coptercptn
coptercptn's Avatar
United States, AZ, Mesa
Joined Dec 2008
I am already on the dark side.....
Clue..... T-Rex 700=S58 Electric Design!!
DAG
Not to derail... but consider Trex600 upgraded to 700 gearing/shaft.. mechs make smaller footprint (IE more room inside) but strength is just as good..
we'll talk...
coptercptn is offline Find More Posts by coptercptn
Old Oct 01, 2012, 03:09 AM
AlexanderB is offline
Find More Posts by AlexanderB
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
we'll talk...
Good point. I did this for my 700 Jet Ranger.
The S-58 manuals should arrive shortly
Cheers Alexander
AlexanderB is offline Find More Posts by AlexanderB
Old Oct 01, 2012, 01:16 PM
Eli Lipschitz is offline
Find More Posts by Eli Lipschitz
Joined Sep 2012
Has the OP thought about putting a parachute in the bomb bay doors tied to the inside fuselage? In an emergency, he could deploy the chute and let the plane come to the ground with minor damage (5 pieces instead of 300). You'd be smart to do this before the first flight. It's best to be safe with this sort of machinery.
Eli Lipschitz is offline Find More Posts by Eli Lipschitz
Old Oct 01, 2012, 01:51 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Think the bomb bay doors are spoken for...
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Oct 01, 2012, 03:10 PM
RCLurker is offline
Find More Posts by RCLurker
Joined Feb 2012
That might be the silliest suggestion I have ever heard.
(Oops, I think I just fed a troll.)
RCLurker is offline Find More Posts by RCLurker
Old Oct 01, 2012, 05:47 PM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Perhaps you are not aware that an emergency chute has been certified for some light single engine aircrart. It is likely an actual photo of one test.To call someone a troll may be in style now,but just maybe he was sincere.The suggestion could be implemented on R/C aircraft. .It works on full scale.
OBW
oldbilgewater is offline Find More Posts by oldbilgewater
Old Oct 01, 2012, 05:57 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
nvm..
SteveT. is offline Find More Posts by SteveT.
Old Oct 01, 2012, 06:28 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Hey all,
Been meaning to post, but I am traveling......
Got a bit more soldering done last week but work has me slammed again.
About a parachute recovery system, I do know a bit about it as a friend had me design a system for a drone he was playing around with 10 years a go.
There are 2 types, BRS ballistic recovery system ( a rocket motor pulls the chute out of its free bag and extends the line in less than .5 seconds. And the DRS, which we all called drag recover system. Basically a drogue chute that is spring activated will pull the free bag out that then pulls the cute and lines to full extension. Also the main chute needs a slider (this is the small chute on your lines that slow the opening depending the the speed of deployment) to maintain a constant G-load will deploying.
Sadly many think that these system are cool, but on a model adds a ton of weight, and stress on the airframe, and most BRS are for loss of control in IFR conditions, and on a model would just never work. And there is just about zero chance to get it work coming out of the bomb bay as the support lines have to live in small groves hidden in the fuse that then is attached to hard points that will support the entire airframe at about 5 G's.
Working my guts out in Dallas for a few days, then back to the shop...
DAG....
dag214 is offline Find More Posts by dag214
Old Oct 02, 2012, 01:06 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
On top of that, you'll need quite a bit of altitude, to give the main chute time to open, and slow down the descend.
However, I remember seeing a model glider a few years ago, being advertised with a chute in its' tail.
Up&Away is offline Find More Posts by Up&Away
Old Oct 02, 2012, 07:09 AM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Hey all,
DAG....
Didn't know you were in the neighborhood. Only about 250 miles away? In Texas, that's like almost right next door!
Safe travels home.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Oct 02, 2012, 10:56 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
Realize that with over 900 pages this has probably been posted before but I don't recall seeing it here (or even indeed on tv)
Discovery Wings Great Planes - Convair B 36 Peacemaker (47 min 47 sec)
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Oct 02, 2012, 11:07 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Hey all,
DAG....
no problem Dag take your Time we are all here for the Entire build!
Dallas my home town!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Oct 02, 2012, 01:15 PM
Depronicus is offline
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
...Working my guts out in Dallas for a few days, then back to the shop...
We all hate the way Real Life gets in the way of the important stuff.
Depronicus is offline Find More Posts by Depronicus
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
