Old May 18, 2012, 07:14 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Originally Posted by dag214 View Post
Right now I work 95% for a company based in Rome, 50% I work for myself, and about 75% I contract for a few other companies. Wait, that's more than 100%
But..... I plan on selling off about 4K worth of stuff over the next 5 months to off-set my new radio gear.
Rock ON!!!!
DAG
Missed the radio switch what did you decide to go with?
mike2663 is offline Find More Posts by mike2663
Old May 18, 2012, 08:48 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Hey buddy,
First PM my a link for the E-scooter you guys had at SEFF
I am having my ideas run down many paths right now.
If the OB-wing has its own (2) RX's that will require 3 batteries. 2 batteries for the RX that runs the 2 flaps, 2 motors, and aileron. The other RX is for the jet and lights. If the battery were to fail on the #2 RX all I would lose is jet power and the lights, no big deal.
If I lay it out as my original design I would have connections for these systems:
Option #1
Motor #1 (ESC)
Motor #2 (ESC)
Flap #1
Flap #2
Aileron Servo#1
Aileron Servo #2
Jet ESC's
Lights.
That is 8 connection.
OR!!!!
Option #2
Place RX#1 for flight systems in OB wing
Place RX#2 for Jets and lights in OB wing
Place 3 flight pack batteries in OB wing
And may have CG issues....
OR!!!!!!
Option #3Which I am liking more and more as I look at it
I could put all the RX's in the wings and run 3 wires back to the 3 OB wing batteries in the nose and only have 3 connections and keep my CG safe.
Just a designing fool right now.
DAG!!
Hi DAG,
Let me ask you, what drives your lights (power and voltage) and what turns them on and off?
There may be an option #4 & #5
#4: Two outboard Receiver Packs for Primary Flight Systems 1 & 2.
#5: Two power wires for Primary Flight Systems 1 & 2.
As the auxiliary elements (JetPods and lights) will draw very little signal power you can reliably run them on the built in BEC of one of the ESC's that will power the EDF units and thus only use the Power batteries, no signal batteries required (I will try to put together a quick diagram and post it in a while but it means a completely standalone system).
Additionally, to help with CG issues, have you considered the following receiver packs for the outboard wings instead of the original ones you were going to use in the nose?
http://www3.towerhobbies.com/cgi-bin...P?&C=MCD&V=HCA
Or if you prefer to stick with your existing A123 manufacturer you can go down from the 4600mAh to the 2300mAh, again to save weight. Since you are driving smaller load now (less servos in the outboard wing) you may be able to get away with smaller packs and thus creating less of a CG issues. With some thorough testing you can determine your draw and then pick the corresponding size pack. On the 30% Camel we are driving 4 standard servos and two ultra high torque servos and we tested and found that we could get about 40 minutes out of a single 1100 LiFe pack (so we threw in two, of course) but you see that there is potentially some weight savings (and thus CG benefit) to be had.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old May 18, 2012, 09:38 AM
RiBell is offline
Find More Posts by RiBell
RiBell's Avatar
Canada, BC, Abbotsford
Joined Jan 2003
DAG!!
My vote is for option #3. With the EDF's battery powering the #2 receiver; through a BEC (the ESC's or a seperate one wired in)
Then all that gets connected is the power wires for the #1 receiver.
What I like about doing it this way is All the on/off power switched are in the same location with your air servicing panel.
This way the power up before flight can be simplified. As the greater the complexity involved in field assembly the greater the chance for something to go wrong.
Keeping the pre-flight check short and simple will help.
All batteries are charged and ready to go.
Transmitter /s on
Receiver switches on.
Wiggle everything.(on the plane that is)
Connect all motor batteries.
Arm ESC's wiggle everything again.
Deep breath to get ready; and remember to breathe. As I can't imagine any flight being a non event.
Rick
RiBell is offline Find More Posts by RiBell
Old May 18, 2012, 02:23 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Outboard Wings First Officer System Diagram
Hi DAG,
OK, it took me a while to get this put together but this is what I was referring to when I stated that your outboard wing panels can be completely self contained for all your first officer operations. Since a picture is worth a 1000 words here is the diagram. For now, since I only have a vague idea of how the nav lights are wired I have just put something in for reference. These can be controlled by the first officer using a receiver controlled switch, I have a vague recollection that you may already have something but here is an example just in case:
http://www.dimensionengineering.com/products/picoswitch
Also, as we do in our night planes you can tap your LED lights straight from a flight pack, if you use a balance tap connector you can get all kinds of voltage combos by taping into the correct wire (1S, 2S, 3S or 4S) whatever matches your LED's voltage requirements (I drew the diagram assuming 3S which is what we run in our night planes). In addition, if you need 5V for your LED's you can tap into the BEC of the second ESC.
For this setup simplicity is king, as few moving parts and components as possible and as few things to plug in as possible.
- Birger
Last edited by bdelapen; May 18, 2012 at 04:04 PM. Reason: Small mistake in diagram, new diagram uploaded.
Old May 18, 2012, 02:52 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Orbit Power Jack
Hi DAG,
One more note, I know that you posted about the Orbit Power Jack which allows your receiver pack current to go straight to the servos without having to pass through the power traces of the receivers. As we discussed, not only is there the 14CH version but there is also an 8CH version:
http://xtcm.evojets.de/product_info.php?products_id=2
Now, based on the number of servos you are driving through the receiver this may or may not be necessary; specially for the primary flight systems in the outboard wings; but it's good to know that it's out there in case you do want to use it.
- Birger
Old May 21, 2012, 06:45 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Thanks Birger,
Great info, and great talking with you as always...........
I am now getting my head more around this.
Rock ON!
DAG
dag214 is offline Find More Posts by dag214
Old May 21, 2012, 06:53 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Well..... not much done this weekend.
Saturday I took the Emmaselle to a RC fly-in fund raiser so a small town that had their pool closed 3 years ago could re-open it. The club I belong to put it on from 11-3 on Saturday. Its a very small town, but got to shake the hand of the Mayor and Judge..... As hot as it is here the kids should love having their pool open again.
Sunday was family day and got to meet one of my RCG B36 followers from down under. What a great guy.......... Wish he lived here and was one of my neighbors..... He was here in the states for business and had some family here in Indy.........
I hope I can get back to my nacelle bottoms on #3 and #4 this week. But work is very crazy. But this weekend is a 3 day weekend.....
Thanks, DAG
Old May 21, 2012, 06:53 PM
Dogsbd is offline
Find More Posts by Dogsbd
South Carolina
Joined May 2003
Originally Posted by kingconsulting View Post
Tried searching this thread but not sure you guys have seen this:
http://www.youtube.com/watch?v=VmG5uTVvS2c
All about the B-36. 47 minutes.
Robert
A note about the numerous full length aviation related videos to be found on YouTube.
Are you tired of watching them on your computer monitor? Would you prefer to watch them on your TV while sitting on the couch relaxing drinking a cold beverage?
If so, I have found a solution. First you need a Roku box attached to your TV, you can get one for about $50. Then search the Roku channel store for the "Plex Channel" install that and follow the instructions. You will end up with the ability to save YouTube videos (as well as Vimeo and others around the net) to your Plex queue which you can then watch on your TV.
I've been doing this for several weeks now and rediscovering the wings programs on my 56" HDTV is just wonderful.
Dogsbd is offline Find More Posts by Dogsbd
Old May 22, 2012, 01:59 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by Dogsbd View Post
A note about the numerous full length aviation related videos to be found on YouTube......you need a Roku box attached to your TV, you can get one for about $50. Then search the Roku channel store for the "Plex Channel" install that and follow the instructions. You will end up with the ability to save YouTube videos (as well as Vimeo and others around the net) to your Plex queue which you can then watch on your TV. I've been doing this for several weeks now and rediscovering the wings programs on my 56" HDTV is just wonderful.
A simpler solution is to use the kids' Wii...............??
Colonel Blink is offline Find More Posts by Colonel Blink
Old May 22, 2012, 02:05 AM
RCBlackSheep is offline
Find More Posts by RCBlackSheep
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
Originally Posted by colonel blink View Post
a simpler solution is to use the kids' wii...............??
ps3?
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old May 22, 2012, 05:30 AM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Or just hdmi from a laptop to the tv....
Endlesslag is offline Find More Posts by Endlesslag
Old May 22, 2012, 06:24 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Or Apple TV or many of the new TV's or BluRay Disk players have software for that too.
Old May 22, 2012, 06:46 AM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
or just the youtube app already on my samsung plasma.
Won2Race is offline Find More Posts by Won2Race
Old May 22, 2012, 07:59 AM
bigbobed is online now
Find More Posts by bigbobed
Awsome 2.5D Pilot.
bigbobed's Avatar
United States, NC, Jackson Springs
Joined Nov 2003
No good deed goes unpunished.
bigbobed is online now Find More Posts by bigbobed
Old May 22, 2012, 08:20 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Or.... Maybe it's just lots of people being helpful and chiming in to provide additional options that you may be able to implement with your existing devices and without the need to purchase an additional one such as a Roku Box.
I tend to look for the good in people first
- Birger
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
