Old Jan 23, 2012, 10:43 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Originally Posted by pkoury View Post
Nobody BARREL ROLLED a 707 or 367-80..... there is a big difference between barrel rolling and aileron rolling.
....I was taught that half way through a barrel roll you were inverted and the your nose was 90 degrees off of your starting heading.
Not really a helical path then
sparks59 is offline Find More Posts by sparks59
Old Jan 23, 2012, 10:52 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
I agree with your explanation of the differences between barrel and aileron rolls, but I do think that Tex Johnston's roll in the 367-80 was the former rather than the latter. An aileron roll would have subjected the airframe to greater negative G-load than it could handle, so a barrel roll with positive loading throughout would have been the way to go. Here's a video with Johnston's explanation of the event. You can see the helical path that the airplane follows. http://www.youtube.com/watch?v=6z_fg...eature=related
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Jan 23, 2012, 11:05 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
A barrel roll is a maneuver in which an airplane makes a complete rotation on its longitudinal axis while following a helical path, approximately maintaining its original direction. It is sometimes described as "a combination of a loop and a roll". The G-force is kept positive (but not constant) on the object throughout the maneuver, commonly between 2-3 G, and no less than 0.5 G.
The Aileron Roll is a maneuver in which the aircraft does a full 360 revolution about its longitudinal axis. When executed properly, there is no appreciable change in altitude and the aircraft exits the maneuver on the same heading as it entered. This is commonly one of the first maneuvers taught in basic aerobatics courses. This maneuver is sometimes incorrectly referred to as a barrel roll.
Strange,
When I learn rolls in a T6 I was taught that a barrel roll was a constant G-maneuver and that is what the 367-80 did as it needed to always maintain a positive-G. I would put the nose down, go up to about 180, pull up to about 40-50 degrees and while not unloading the stick crank in aileron..... When I learn an aileron roll I would pull up to about 3-5 degrees then un-load the stick and crank in full aileron until I was back to wings level. When I was at Oshkosh in the 80's a Boeing guy told me the 367-80 was done with a positive-g and he called it a barrel roll......
We may be talking about the same thing...... But if you watch the Bob Hoover tea trick that is done with a positive-G.
Now with all that said you can perform a barrel roll with just a bit of pull up and not unloading the stick and doing the roll, you will lose a bit of altitude as the 367-80 did, but you will still maintain a positive-g and it is still a barrel roll.
DAG
dag214 is offline Find More Posts by dag214
Old Jan 23, 2012, 11:07 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
You beat me to it.......
DAG
Old Jan 24, 2012, 12:13 AM
charlie11niner is offline
Find More Posts by charlie11niner
Charlie11Niner
charlie11niner's Avatar
St. Albans,WVa
Joined Feb 2009
C-130e
Several years ago someone in our unit did a positive rate G barrel roll in one of our 62' "E" model C-130's. I wasn't on it but, several of my buddies were !!!
charlie11niner is offline Find More Posts by charlie11niner
Old Jan 24, 2012, 07:59 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
I went with Tex Johnston's description of the maneuver he did in the dash 80 prototype and that is what I typed. He did it to a single constant positive G and was supposed to be impossible for a large aircraft like that!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jan 24, 2012, 08:18 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
It doesn't matter what your flight instructor told you he still rolled a big plane.
IMO it wasn't an aileron roll so take your pick...
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Jan 24, 2012, 08:45 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Here are a few pics from late last night.
The right wing nacelles are just about ready for final sanding then glassing
I hope to have the left wing intakes don by Sunday (I am very busy this week with work).
And about the barrel roll, it was a barrel roll and not an aileron roll. If you want to take a Wikipedia definition of a barrel roll it may not by definition be a perfect one. A true barrel roll done as a maneuver will see the plane go about 90% off heading, but is on heading as you exit. BUT, any roll that hold a positive-g is a barrel roll. If you enter it from wings level and just crank in aileron and do not unload the stick you will roll but lose a ton of altitude. I have done a ton of these in T-6's and a true barrel roll is not easy if you want to nail heading and altitude. A aileron roll, hell.... just pitch up, unload, and crank in the aileron until you see wings level.
Go to 4:08 and you will see me do 2 aileron rolls and we did not hold a positive-G
AT-6 Flight (9 min 54 sec)
And this was kind of a crappy flight as the night before I had hit a few pubs with my British mates and was still feeling it.
Rock ON!!!
DAG
Old Jan 24, 2012, 09:33 AM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Rock ON!!!
DAG
Us Brits can do that! Nacelles look great Dag. Keep rocking!
Luke
Lberry.88 is offline Find More Posts by Lberry.88
Old Jan 24, 2012, 09:43 AM
dwood75 is offline
Find More Posts by dwood75
soaring guy
USA, AZ, Mesa
Joined Oct 2009
Hi Dag,
What is the white material you using to fair the inlets to the wing?
Dee
dwood75 is offline Find More Posts by dwood75
Old Jan 24, 2012, 10:20 AM
coptercptn is offline
Find More Posts by coptercptn
coptercptn's Avatar
United States, AZ, Mesa
Joined Dec 2008
Strange,
DAG
That was how we accomplished it in a CH-53a Helicopter @ Pax... Sikorsky said it "could" be done so we had to try it.... Having a fully articulated head, you HAVE to keep positive G's or the whole deal folds up on you!!!!!
coptercptn is offline Find More Posts by coptercptn
Old Jan 24, 2012, 10:21 AM
spiragui is offline
Find More Posts by spiragui
Seattle
Joined Dec 2006
Brilliant!
I'm a little late to the party here, but I've just seen the drop test videos. I'm a landing gear dynamics engineer by trade (I was involved in the drop testing of the newest airliner to come out of the Seattle area, among numerous other airplanes) so I'd just like to say kudos to you! Great vids, keep up the good work. I only wish I had the time and patience to accomplish something like this.
Cheers
Chris
spiragui is offline Find More Posts by spiragui
Old Jan 24, 2012, 02:16 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by dwood75 View Post
Hi Dag,
Dee
I'm not Dag, but I would bet it is light weight "spackle"... If so, you can buy it at any hardware store. I use the stuff that is pink in the container but turns white when dry. It's easy to sand, and you can wet your finger, and smooth it out very nicely... However, it adds no strength. For a light weight filler that does add a small amount of strength, you can use "microballoons" or even milled fiberglass mixed with polyester resin. Both of these fillers are usually available at any good LHS.
SteveT
SteveT. is offline Find More Posts by SteveT.
Old Jan 24, 2012, 02:42 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Originally Posted by spiragui View Post
Brilliant!
Cheers
Chris
Thanks!!!
DAG
Old Jan 24, 2012, 02:43 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Hi Dag,
Dee
It is light weight spackle with micro balloons, and some times saw dust.....
Thanks, DAG
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
