Old Jun 03, 2010, 03:46 PM
oldcoot88 is offline
Find More Posts by oldcoot88
Joined Dec 2002
Originally Posted by rccardude04 View Post
...Most awesomest sounding radial in r/c
-Eric
Indeed. Here's another 'Big Iron' subject running the Moki. Sound gives ya goose bumps.
Giant Scale RC Sea Fury - Huge Power (2 min 46 sec)
oldcoot88 is offline Find More Posts by oldcoot88
Old Jun 03, 2010, 04:44 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Sheeesh, this thread has moved in the last day or so....
It is amazing how dumb these oil people are. To stop the leak is easy, but no one wants to think outside the box. If you take a Kevlar Balloon pack it tight like a airbag on a car, then push it down about 500 yards into the well, then set off a couple of nitrogen cartages at let’s say 200PSI, and BAMB! Leaked stopped.
And my wife had an idea to absorb the oil, that I "upgraded" a bit. She had the idea of spreading straw on the water (yes it would take a lot) to attract the oil to it, then use surface nets to pull it all in. My "upgrade" to it, was to use brush shredders (like they feed tree branches through to shred them), mount them on ships and feed straw, wood, tree branches (anything that is a non-pollutant and would float), to again, attract the oil, and then drag it in. Maybe it wouldn't work on the open ocean, but it could certainly be done in near the land.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jun 03, 2010, 08:39 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
accessory for your hummer (in case of trolls)
Damon,
I found this pic on a different website but since you have a new hummer I thought this might apeal to you (in case of troll attacks).
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jun 03, 2010, 09:38 PM
Turbs is offline
Find More Posts by Turbs
Foam bounces...
Turbs's Avatar
SA, Australia
Joined Aug 2007
Originally Posted by dag214 View Post
Forgot to respond to this. Are you referring to my 3 bl ade20-14's on my 36??? I have found that I get worse low frequency vibration using rubber motor mounts. I have tried rubber isolated motor mounts on everything up to 300Cc gas engines, and I have had no luck at all with them. On the really big stuff it just saves the welds on the motor mounts.
Thanks, Dag
More of a generic inquiry than a specific prop reference.
I did find with my PZ corsair that my motor mounts were lasting longer with the rubber washers than without.
Turbs is offline Find More Posts by Turbs
Old Jun 03, 2010, 10:12 PM
ErcoupeEd is offline
Find More Posts by ErcoupeEd
ErcoupeEd's Avatar
United States, IN, Grabill
Joined May 2004
http://www.youtube.com/watch?v=ylCtXK0z9us
AWESOME!!!!
Sounds like the real thing!
ErcoupeEd is offline Find More Posts by ErcoupeEd
Old Jun 03, 2010, 10:33 PM
ErcoupeEd's Avatar
Joined May 2004
http://www.youtube.com/watch?v=SeSDahp3Okk
-Eric
Just plane awesome!
Old Jun 04, 2010, 02:36 AM
AlexanderB is offline
Find More Posts by AlexanderB
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
Hey all,
And just an FYI, I see a bunch about resistor, I am only fly 6 cells on this bird, do I really care, I could see if it was my 1919 with 10 or 12 cells, but 6 cells??
Dag, the resistor brings no weight at all but it will prevent the flash when plugging in the battery. When you use extra caps the flash will be even naughtier and will damage the plugs.
Cheers Alexander
AlexanderB is offline Find More Posts by AlexanderB
Old Jun 04, 2010, 02:44 AM
RCBlackSheep is offline
Find More Posts by RCBlackSheep
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
I like electrics, I truely love the sound of a turbine, but I gotta say the sound of a well tuned piston engine (especially a hotrod radial) really tickles the senses. Ohhhh... yea.....
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old Jun 04, 2010, 06:33 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
A guy here at RCG e-mailed me this:
B 24 Liberator Crash - Goes Walk About (1 min 52 sec)
Looks to be bad pre-flight and controls check, at least IMHO
Dag
dag214 is offline Find More Posts by dag214
Old Jun 04, 2010, 08:44 AM
Dwhart24 is offline
Find More Posts by Dwhart24
Warbird junkie
Dwhart24's Avatar
Oviedo, FL.
Joined Feb 2009
Aww man that sucks. It looked like he didn't have enough air speed and stalled it.
Dwhart24 is offline Find More Posts by Dwhart24
Old Jun 04, 2010, 09:16 AM
Rickn816 is online now
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Wow.
Nobody was hurt from that.
Rick
Rickn816 is online now Find More Posts by Rickn816
Old Jun 04, 2010, 09:24 AM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
that's exactly what I was thinking. The left wing dropped a bit and then it started to bank hard to the left. Looks like the pilot saw the slight left bank and tried to correct but just wasn't quick enough to realize what was going on and just kept feeding in left stick.
I think that if it were a stall, you would have seen a much more abrupt bank and more 'snap'.
I'm curious if the builder used a scale airfoil section. The B-24 was not known for being a forgiving airplane to fly due to the wing design.
Won2Race is offline Find More Posts by Won2Race
Old Jun 04, 2010, 10:09 AM
LBJ is offline
LBJ
Find More Posts by LBJ
LBJ
Fort Worth, Texas
Joined Nov 2007
I'd say his airspeed was not enough for that turn, if the turn was a commanded turn. It takes a minute or two to "get on the step" and really get rolling on a big bird like that one. If an uncommanded turn, his left engine(s) were not pulling hard as the right ones and dragged him into a "drag-induced" left turn. Didn't appear to snap, so prolly his engines not performing at full power. Gosh, think of the time and $$$ invested in that baby!
Looking at it again, his left wing was low from the moment he lifted off. Engines not pulling hard enough on the left. Also, possibly not shown, I didn't see anyone taching those engines! Man, that would be the last thing I checked before taxiing out!
LBJ is offline Find More Posts by LBJ
Old Jun 04, 2010, 10:16 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
This is mostly idle speculation as we are not sure what happened. I think DAG alluded to something that I have seen countless times and that is reversed ailerons (failed pre-flight check). I'm not sure if this is the case or not but the one thing I will add is that I really doubt that this was a commanded turn to the left since based on the footage the pattern should be to the right as the flight line was to the left.
Either way, that is definitely a lot of $$$ down the proverbial drain
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Jun 04, 2010, 10:23 AM
rccardude04 is offline
Find More Posts by rccardude04
3.14159265358979323846264
rccardude04's Avatar
Wichita, Ks
Joined Jun 2005
Looked like a bad range check followed by the words "Nahhhhh it'll be alright!"
-Eric
rccardude04 is offline Find More Posts by rccardude04
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 10:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 07:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 09:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 04:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 01:33 PM
