Old Oct 17, 2008, 12:10 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Originally Posted by jfetter
DAG,
You are correct about the Battery-to-ESC leads BUT you can extend the ESC-to-Motor leads considerably. I've extended them 36" in pushers before without issue (make sure they are even) and I've heard others that have extended them more...
Jack
And you can add another couple of good size capacitors at the input side of the ESC, just like the ones that are already there. I do this with large twins that have the batt in the fuse. I really don't know when they become needed, but I did it as a safety factor. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Oct 17, 2008, 03:12 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
DAG,
Jack
jfetter,
What amp ESC were you using, what size motor. I was told by Castle not to go more than 12" from battery to motor. If I can go more then I will move all my Lipo's to the front center of the wing with the ESC close by then run wire out to the motors. I may have to test to make sure it will work.
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Oct 17, 2008, 03:15 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Tex,
Castle said that I needed to add the same size capacitor that is one the ESC for every 1" that I go past 18", now others have told me that it is 1 capacitor for every 6". But if I can add on the motor size that would help a bunch.
Thanks, DAG
Old Oct 17, 2008, 03:18 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Well here is the first Rib (really Rib#2, but the first one cut).
It is only 1.5oz, which is .5 heavier than I had wanted.
I am using my V.P. of develpment (Emma) in the pic for scale.
This is really going to be a cool project.
DAG
Old Oct 17, 2008, 03:23 PM
Tim Farrar is offline
Find More Posts by Tim Farrar
Bi-Planes
Tim Farrar's Avatar
Houston Texas
Joined Apr 2006
DAG
Wow that is really huge !!!!
I cant imagin how this will look when finnished !!!
The VP there must be doing a great job because she is the same as the one for your last build !!..lol...
Seeya, Tim
Tim Farrar is offline Find More Posts by Tim Farrar
Old Oct 17, 2008, 04:01 PM
gtfreeflyer is offline
Find More Posts by gtfreeflyer
Put a bigger motor on it!
gtfreeflyer's Avatar
Costa Mesa, CA
Joined Feb 2007
How do you cut the rib? Do you print out the shape full scale and then trace it onto the rib? Do you then just carefully cut it manually with your router? What's the trick to getting it exact?
gtfreeflyer is offline Find More Posts by gtfreeflyer
Old Oct 17, 2008, 04:23 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
gtfreeflyer,
I will take some pics when I cut the next one. I was lucky enough to find a used HP plotter very cheap that prints up to 110" long, and 36" wide. Plot out the rib, then take 3M super 77 adhesive and spray just a dusting on the back of the plotted paper rib, then stick it to the wood, then cut on the lines. The whole process from plotting to a cut rib is about 20 minutes, but keep in mind that I cut the ribs in pairs so it goes a little faster than you would think.
If anyone ever has any giant scale projects in CAD that need plotting let me know, in most cases I can do as long as shipping is covered, if it takes a bunch of paper I might have to have some help with the cost of the paper.
Thanks, DAG
Old Oct 17, 2008, 05:18 PM
Ercoupe Ed is offline
Find More Posts by Ercoupe Ed
Vintage Flyer
Indiana
Joined Jan 2005
gtfreeflyer,
Thanks, DAG
Hi Dag, I have a set of plans for a 78 inch JN-4 Curtiss Jenny on a CD.
Can you print something like that out?
I am also interested in blowing up a second set of plans to 150% or 117 inches.
Ed
Ercoupe Ed is offline Find More Posts by Ercoupe Ed
Old Oct 17, 2008, 05:28 PM
Costa Mesa, CA
Joined Feb 2007
Very cool. Thanks for the explanation. What is the row of holes for? Does it serve a function other than lightening? Holes like that are pretty bad for stress as you can get a "gang chain crack" that can easily run across all the holes very quickly. I've done that on one of my designs here at work, and it got torn apart by the stress analysists. I think the rule of thumb they stuck to was two or three diameters between each hole. Lightening holes actually don't lighten as much as they weaken. When I'm trying to reduce weight of a part, it's much better to decrease the thickness rather than cut a hole in the part. Of course, this would be a big pain in the butt in your situation unless you have a planar next to that jigsaw. Sharp corners are another concern as cracks will propogate from here. Try to put corner fillets, even 1/16" radius will do, wherever you can.
Old Oct 17, 2008, 06:01 PM
B Sickels is offline
Find More Posts by B Sickels
Texas
Joined Nov 2005
B-36 Fuse
DAG, you are doing the same thing I have already been through. The mold is done. Sure would save a bunch of time.
B Sickels is offline Find More Posts by B Sickels
Old Oct 17, 2008, 06:29 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Ed
Ed,
How big is the drawing on the CD, can you e-mail me the plans, if not I bet if you copied the CD and sent it to me I could figure it out.
Thanks, DAG
Old Oct 17, 2008, 06:37 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
The big holes on the sides are for carbon fiber tubes, the fuse breaks down into 3 parts.
The other holes are both for lightening and systems, airlines, power cords.
The right angles in the fuse bulhead is where the long fuse truss lives, this is where I get 80% of my strenght from so I am not to worried about having to many holes in each bulkhead.
Keep the in put coming though I am not ever 100% sure that anything I do does not have a better and more stronger way.
Thanks, DAG
Old Oct 17, 2008, 06:39 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
This plane has a 257" span and the fuse is 182" long now. Didn't you say your molds were for a 161" fuse??
Thanks, wish you had a 182" fuse.
DAG
Old Oct 17, 2008, 10:32 PM
Vintage Flyer
Indiana
Joined Jan 2005
Ed,
Thanks, DAG
Dag I have the plans on an email attachment if you want to take a look at them.
emailed the files to you.
let me know if they came through.
I also have them on a CD.
I tried Kinkos here locally, but the gal running the place seemed totally stumped when I told her that I simply wanted the plans printed out.
She tried 3 times, and 3 times they did print but were on the paper the wrong way, and about 1/3 of the plans were cutout.
So I gave up, and after waiting for an hour also, I went home.
Obviously with no plans.
PS- Our VAA Chapter had a movie nigt tonight at the clubhouse at the airport. We watched a trilogy of three short movies "Flights of Courage" about the US Air Mail Service, very good, then the next one was "The Red Baron, also quite good, and the last short movie was "The Lindbergh Story".
My buddy Geoff got it through Netflicks.
THanks!
Ed
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
