Old Jan 05, 2009, 09:07 AM
RiBell is offline
Find More Posts by RiBell
RiBell's Avatar
Canada, BC, Abbotsford
Joined Jan 2003
Originally Posted by Tim Farrar
Dag, excuse me for messing your thread up a little here but I just know you would like to see this video of a 19th Scale C-17 Globmaster !!
http://vids.myspace.com/index.cfm?fu...deoid=49746235
Seeya, Tim
First thing I noticed was the pilot's name.
I remember seeing a video of him flying a 12ish oz 3D machine in a gymnasium; a couple of years ago.
It was the first 3D video that I found interesting to watch. Not just a bunch of hovering; it was set to music, and the airplane had a pair of streamers from the wingtips.
Rick
RiBell is offline Find More Posts by RiBell
Old Jan 05, 2009, 10:16 AM
coptercptn is offline
Find More Posts by coptercptn
coptercptn's Avatar
United States, AZ, Mesa
Joined Dec 2008
I sent you a PM regarding Chargers the Newly released Bantam BC8DX will do you just fine...take a look...:
http://www.rcaccessory.com/index.asp...ROD&ProdID=386
coptercptn is offline Find More Posts by coptercptn
Old Jan 05, 2009, 10:27 AM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Dumb suggestion by a dumb guy. I have been using carbon tubes for axles on an AP ship and I found that if I slide a smaller piece a carbon tube inside the main tube and then wrap it with strapping tape that even when it breaks it is still very usable. Now I know that once the shaft breaks on your motors you will not want to continue flying but something like the tube in a tube and wrapped may keep it from detonating and ripping other things to shreds once it goes.
OK back to smart people talk.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Jan 05, 2009, 11:05 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
You get more bang for the buck with the Hyperion. The Bantam is limited to 160 watts/port while the Hyperion DUO does 180 watts/port...
Jack
jfetter is offline Find More Posts by jfetter
Old Jan 05, 2009, 11:21 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Originally Posted by JONBOYLEMON
Dumb segestion by a dumb guy. I have been using carbon tubes for axles on an AP ship and I found that if I slide a smaller piece a carbon tube inside the main tube and then wrap it with strapping tape that even when it breaks it is still very usable. Now I know that once the shaft breaks on your motors you will not want to continue flying but something like the tube in a tube and wrapped may keep it from detonating and ripping other things to shreds once it goes.
Does the inner tube fit perfect, I am looking at RPM's about 4200. If it does not fit perfect it may cause a balance problem.
Also a dumb question, what is a AP ship?
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Jan 05, 2009, 11:29 AM
Joined May 2002
Yes its a tight squeeze. I dont have the sizes but it is very tight. Not so tight that you can't slide it in but its soo close that its like it was meant to be.
I know I have had several pieces of carbon tube & rod that were seemingly made to be sleeved.
While my axles never do 4200 RPM, unless I am taxing at 476 mph, I think the idea is worthy. It adds a ton of strength as when the tube tries to break there is resistance to caving in as well as blowing out. I broke the axle 6 month ago but I have been too lazy to change out as it still is working just fine.
AP = Aerial Photography
Old Jan 05, 2009, 12:14 PM
Lynxman is offline
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
The problem with regulat carbon tubes and rods is that they have unidirectional fibers. This makes them unsuitable for transmitting high torque. A tube with unidirectional diagonal fibres with layers in alternating directions would be perfect and would not fail. Even a woven tube would be better I think. I attached a picture of a woven tube I have. Still, 10 mm, thick walled unidirectional tubing might be enough for the job though, but with such a high power level and low rpm as 4200 rpm the torque will be immense.
Lynxman is offline Find More Posts by Lynxman
Old Jan 05, 2009, 12:23 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
With such a high power level and low rpm as 4200 the torque will be immense.
Thanks Lynxman,
Here is some info.
So far I am seeing with a 20/14 3blade setup about 45-47 amps on ecalc. That is at about 4400rpm. Very late last night I took a 12" CF tube and epoxied a grade 8 bolt in each end, then with it in the vise I put my torque wrench and turned it off the scale (I am guessing about 280 pounds) and the tube did not even deform.
Tonight I am setting up a test nacelle and by Friday hope to do some full power test. Keep in mind my low RPM is not limited by the power of the motor but by my design and target performance and speed that I want.
Comments welcome.
DAG
Old Jan 05, 2009, 12:26 PM
Lynxman is offline
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
Cool! Sounds like it's some very strong tubing. I'll look forward to your test results.
Old Jan 05, 2009, 12:48 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
I hope it works, if not I will find some tubes with unidirectional diagonal fibers.
Thanks, and be safe.
DAG
Old Jan 05, 2009, 01:49 PM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
what liPos whill you use and how many
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old Jan 05, 2009, 01:56 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
I have been looking at Thunderpower, Zippy, and lately airpower. There will be 2 each 4C@5000mah wired is series to each Hacker motor, so each motor will see 8 cells. Soooo this plane will have 6 sets of 2 pair 4 cell 5000mah batteries. Thats 12 4 cell packs $$$$$$$ .
Thanks, DAG
Old Jan 05, 2009, 02:08 PM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
Not to mention the six chargers
Carl Petersen is offline Find More Posts by Carl Petersen
Old Jan 05, 2009, 02:17 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Nope
3 dual chargers. $$$$$$
Like I said I am not made of money, but boy this is adding up. But it is cheaper than a girl friend .
Thanks.
DAG
Old Jan 05, 2009, 03:56 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by dag214
Nope
Thanks.
DAG
Dag,
I don't want to start the power debate again but I'm having a hard time finding the Hacker motors you ended up going with, I can only find the post about them helping you size the motors and picking the right one. Can you please post the exact motor, ESC, battery and prop one more time?
Jack
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
