Old Feb 07, 2010, 10:05 AM
Angelo is offline
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Hey Dag, have you figured out how long it will take to get all systems up and do the preflight checks at the field? Even pressurizing the air tanks before you go out, just checking everything over, I would guess will take some time!
Angelo is offline Find More Posts by Angelo
Old Feb 07, 2010, 10:21 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Pea
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Originally Posted by dag214 View Post
Yesterdays adventure is systems stuff.
DAG
Hi Dag,
What air brake pressure regulators are you using? I've been searching and haven't found anything like what you have there.
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Feb 08, 2010, 01:42 AM
greeter896 is offline
Find More Posts by greeter896
USA, CA, San Bernardino
Joined Oct 2009
Mini Air Compressor For Retracts
Hi Dag,
I don't know if you have found a solution yet for refilling your air system but I came across this so I will pass it on. It sells for $19.99 and runs on 12v;
http://www.ejf.com/index.php?main_pa...roducts_id=662
Best Regards,
Gary
greeter896 is offline Find More Posts by greeter896
Old Feb 08, 2010, 06:17 AM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
Wow! Post #6,000 passed!
Tonystott is offline Find More Posts by Tonystott
Old Feb 08, 2010, 06:50 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Well things are slow going. The air systems are taking a bunch of time. I really wish I could get back to sheeting, that goes so much faster.
Yesterday I got my new air valve control panel cut out, built, and painted. If all goes well I will have this in the plane and being tested by Wednesday.
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Feb 08, 2010, 10:21 AM
TPfingston is offline
Find More Posts by TPfingston
Retired and Lovin' it!
TPfingston's Avatar
United States, KY, Sturgis
Joined Jul 2007
Dag, I fear that you will find that finishing this huge model is going to be similar to doing finish work on a new house. It takes much more time than it seems like it should. Keep up the good work. Like everyone else, I am patiently waiting to see the finished product but it is also great watching it all come together. I'm afraid that when its finished, it will be something of a 'let-down' because we will lose the 'suspense' of waiting for the next installment.
Tony
TPfingston is offline Find More Posts by TPfingston
Old Feb 08, 2010, 11:21 AM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Seeing this beast take to the air for the first time (even in a video some hours or days later) will be magical and thrilling. Certainly not a 'let-down'. I've been wondering how 'finished' it'll be when it first flies. I'm always torn between damaging a model before it's even finished by test flying, vs risking even more work being damaged on a 'maiden' of a finished model.
Grejen is offline Find More Posts by Grejen
Old Feb 08, 2010, 01:33 PM
ska2000 is offline
Find More Posts by ska2000
Mount Juliet, TN
Joined Feb 2008
I assume all the air tanks will be pressurized to the same pressure? I'd make a little manifold (that stays with the pump) making it possible to connect all the air tanks up to the pump simultaneously. They will all maintain the exact same pressure as they are being pumped up. You would have to have on/off valves (or check valves) on each of the manifold lines so that no air would leak out as you're disconnecting the manifold from the schrader valves on the plane. What would be even cooler would be to have an automatic cutoff on the pump when the target pressure was reached. Also, being all connected together while pressurizing would be a good way to calibrate the pressure gauges of each of the separate systems. You'd instantly know if one of the gauges was off by some signifigant amount. If the gauge itself could not be physically calibrated, you could make a tiny placard noting that gauge's deviation from true.
Tom
ska2000 is offline Find More Posts by ska2000
Old Feb 08, 2010, 01:40 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Hey Tony,
Kinda crazy, 6000+ post, almost 600,000 views.
And she still is not setting on her feet.
I have to get her done by 2012, because we all know that's the END!
DAG
Old Feb 08, 2010, 01:57 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
DAG
Yes, you and your family can fly her to safety ;-)
Jack
jfetter is offline Find More Posts by jfetter
Old Feb 08, 2010, 02:01 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Right!
There has been a bunch of talk about checklist out there.
Attached is my checklist for flight, I have one for assembly/disassemble and maintenance.
Attached is a work in progress and I have not had much time to really get it right. Slammed with work and taking a lunch break.
DAG
Old Feb 08, 2010, 02:10 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
DAG
Hi Dag,
My original questions probably fell through the cracks so here it goes again. What brake pressure regulator valve are you using. I have been searching for one but haven't found anything I like.
Regards,
- Birger
Old Feb 08, 2010, 02:38 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Originally Posted by bdelapen View Post
Hi Dag,
Regards,
- Birger
It did,
Sorry Birger.
http://www.beswick.com/products/prod...ls.php?pid=157
Very cool. I am testing soon so I will let you know how it works.
Thanks, DAG
Old Feb 08, 2010, 04:54 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nttery, NORWAY
Joined Mar 2006
Right!
DAG
Gotta love that checklist
kimhey is offline Find More Posts by kimhey
Old Feb 08, 2010, 05:55 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
That checklist puts some full size aircraft checklists to shame...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
