Old Dec 31, 2009, 12:02 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
you got some space in the tail how about helium balloons
ashdec87 is offline Find More Posts by ashdec87
Old Dec 31, 2009, 12:55 AM
ramboman is offline
Find More Posts by ramboman
Waterloo, Belgium
Joined Dec 2004
Originally Posted by dag214 View Post
That is some great info, thank!
I am designing a APU cart that will have 4 parallel deep cycle marine 12 volt batteries. I will have 3 Bantam BC8DX Charger, I know there are other, I just love these chargers.
The A123 will not take much time to top off at the field, my calcs show I can get 15 flights before they are 50% down on my A123.
It looks like I can turn the plane around in about 90 minutes. Plenty of time to get my knees to stop shaking. I bet I will never fly it more then 2-3 times in a single day.
Thanks, DAG
I use regularly 12s2p a123 packs. I charge them at the field with a MasTech HY5020E at 20A 43.2V in 15min, strictly following a123 specifications. Brushless are in the 50cc category (3500W).
ramboman is offline Find More Posts by ramboman
Old Dec 31, 2009, 06:07 AM
thpppttt is offline
Find More Posts by thpppttt
USA, LA, Gretna
Joined Jan 2009
DAG, I have been following this thread for a while and now finally come forward to express my amazement and appreciation for your dedication and craftsmanship. As a former pipe organ restorer, I can appreciate the combination of fine woodworking and electronics skill you abundantly possess.
So here's my "stupid" question, and I hope it's not too derailing: Regarding Carbon Fiber, I see it used many times in strips as a lightweight reinforcement; so, why not build a plane using mostly, if not all, carbon fiber?
Anyway, congratulations on getting this project near completion. I know you are going to really enjoy flying it!
Scott
thpppttt is offline Find More Posts by thpppttt
Old Dec 31, 2009, 07:04 AM
Ebolavoodoo is online now
Find More Posts by Ebolavoodoo
Ebolavoodoo's Avatar
United States, CA, Pinole
Joined Jan 2007
Scott
My guess is that it's very expensive.
Jerry
Ebolavoodoo is online now Find More Posts by Ebolavoodoo
Old Dec 31, 2009, 12:33 PM
ska2000 is offline
Find More Posts by ska2000
Mount Juliet, TN
Joined Feb 2008
Well don't forget that wood has a lot of excellent qualities for this application too. It's very easy to work with. Easy to cut and shape and glue. Balsa is very lightweight and strong pound for pound and dollar for dollar, and the same holds true for aircraft ply. Building a mold of the entire fuselage, for instance, is very expensive and labor intensive prospect. It's a great way to go if you're going to make many copies. Building the plug for the mold is a LOT like building the entire airframe from scratch. And a fuselage of this size would still require a lot of internal structure anyway. The all wood structure might easily be lighter. It's definitely cheaper and faster to build. DAG has identified where composite materials make the most sense to accomplish his design goals, and he added the carbon fiber tow where needed. Rather than replacing the wood, the composite of wood and carbon fiber enhances the engineering properties of the wood in very beneficial ways with very little weight penalty. Wood is good!
ska2000 is offline Find More Posts by ska2000
Old Dec 31, 2009, 12:55 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Wood schmood, if it was affordable of course he'd rather have a full carbon structure, where applicable and in conjunction with other materials if needed. The US Military has a mini remote controlled flying plane, saw it at SEFF last year, about 28" wingspan, folds in half and shoves in a little tube, very slick. It's made out of 100% CF and is $3,500 just for the airframe :-o
Jack
jfetter is offline Find More Posts by jfetter
Old Dec 31, 2009, 01:08 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
One of the probelms with carbon fiber is if used for the full structure it is a completely diffrent build...Just like a making a fiberglass plane! it requires making molds and plugs most of the time..all can be done just not the same type of build...the others problems are cost and the fact it is a waist of money unless you have prepreg carbon and an auto clave to Cook it..most of the gain is lost by useing normal fiber glass constructin methods..the excess resin kills a lot of the strenght gains from carbon...it really only helps when used in tension only in this type of contruction..
turbonut is online now Find More Posts by turbonut
Old Dec 31, 2009, 01:12 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Well the question was why not 100% CF, I am sure the number one reason is price, not skill as I'm sure it could be learned. I was just agreeing with the original answer, not saying the rest isn't valid...
Jack
Old Dec 31, 2009, 02:12 PM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Jack
There's another issue with radio equipment in a full CF airframe. Seems to me cost would be a major issue as well.
mike2663 is offline Find More Posts by mike2663
Old Dec 31, 2009, 05:30 PM
VF-Alpha is offline
Find More Posts by VF-Alpha
Fly Hard or Fly Home!!!
VF-Alpha's Avatar
United States, CA, West Sacramento
Joined Jul 2007
if this plane was made of CF i would have little interest in it , even if it is my second favourite plane .1. Tigermoth
2. b-36
3 . predator b aka reaper
woodworking is a skill moulding not so much even i can do it , woodworking is much more difficult ,its an art , that I thing Dag has pretty much perfected .
VF-Alpha is offline Find More Posts by VF-Alpha
Old Dec 31, 2009, 05:53 PM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
That for sure, very robust and I'm sure the fact that they are a little heavier also helped in the choice as they will offset some of the excess tail weight this beauty will have.
Found this out myself when I recently converted my little (110 inch) B-36 to lipos.
The B-36 has a lot of 'junk in the trunk' & it was hard to get everything far enough forward to get the CG correct.
Still, with the almost 1 1/2 pounds I've saved (plus more horsepower) the old girl is almost sprightly! - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Dec 31, 2009, 05:57 PM
A10 man is offline
Find More Posts by A10 man
This is high school for you...
A10 man's Avatar
Longmont, CO
Joined Jan 2009
Its coming along great!
A10 man is offline Find More Posts by A10 man
Old Dec 31, 2009, 06:27 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Jack
Of course it's $3500.00 for the U.S. government....but then they pay $2500.00 for a toilet seat.... Like what was alluded to in the movie "Independence Day".... How do you think they pay for covert and black ops, and other secret projects??
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 01, 2010, 05:58 AM
pmisuinas is online now
Find More Posts by pmisuinas
United States, VA, Springfield
Joined Feb 2000
Regards,
- Birger
Based on the continuing on-going examples of Dag's superb engineering, I defy you to identify ANY "excess tail weight" in this model NO doubt every gram in it is there because it has to be....
pmisuinas is online now Find More Posts by pmisuinas
Old Jan 01, 2010, 06:18 AM
Joined Feb 2000
SteveT
As it turns out, as part of my USAF career, I got the correct info on the "$2500.00" toliet seat. First, it was not $2500, I forget just what it was, but I want to say it was about $1600, and second, what is always forgotten or never known by the folks who repeat this story, is that it was also required to be a pressure seal in the aircraft (it was on a P-3, by the way). I submit the engineering and tolerances, and required manufacturing skills, for a part that if it fails will crash the aircraft, requires a bit more than a Home Depot solution (and price).
Another intersting story--back when smoking was still very prevalent. The Navy had a requirement to install an ashtray in an aircraft, the procurement officer let the contract for $600 a copy--and promptly got called on the carpet for the cost. Again, what is not added (the rest of the story), is he checked with the government back shops and they said it would cost them $900 each to do--so he thougt he was doing great saving 33% on the cost.
The services have a program called Education with Industry where serving officers/civilians get to essentially be a contractor for a year, in order to learn the other side of doing business. It was one of the most interesting years of my career, and really gives you an understanding of just how mis-informed people are sometimes. You would be appalled at how much money is wasted just because the appearance of waste has to be avoided--not to mention the number of parts that don't get made because a company can't afford the publicity on what a small production run would cost.
Not to say there aren't some abuses out there, of course there are--but my experience indicates 99.9999% is completely aboveboard. It's just that the amount of money involved is so huge that .0001% still looks outrageous in the paper.
Anyway, apologize for going off-track from this stupendous project, but after a 30 year career in the USAF, I get a little peeved sometimes when criticism is unjustified. After all, there are enough times when it is valid--lol. But those times I won't talk about--while the guilty don't deserve the discretion, the innocents involved do...
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
