Now I know how the Godzilla movies are made too...lol lol lol... Your little girl is prettier every year !!!! Thats what is good about making your own model's for your model planes !!! She just keeps getting prettier and if you hired one they would get older and want to much money...lol lol lol... Seeya, Tim |
I'm a little confused by picture "Fuse Canopy 010.jpg" from post #330, it seems to show a central member running top-to-bottom (to form the initial nose cone curve), and then 4 members on each lower side yet there is room for a 5TH member on the left side only (when looking at the nose cone like in the picture). Did something not line up correctly or did you design it to actually have 5 curved members on one half of the lower nose cone? Looking darned good! Jack |
Also in that pic the canopy is not setting square to the fuse. Thanks, DAG |
You are certainly on point in regards to detail! Jack |
Fantastic thread, Dag, I'm enjoying it immensely! That B-36 is looking great. I really envy your design and workmanship talents. If I weren't so lazy and old, I would try to learn CAD, just so I could design and build things better!
As to your concerns about flying this this thing for the first time, and your tendency to land too far away, I must admit that I have the same problem. The larger the plane, the faster the plane, and the harder to fly, the farther away it tends to be when it touches down. I've found that it helps to move down the field a bit, so the angle of approach is more head-on. That way you can see the field at the spot you want to land, and the plane at the same time. Also you should pick a time when the wind isn't gusty, crossways to the field, or too strong for that first flight. Nice smooth air will do wonders for your ability to put the plane close to where you want for touchdown. Thanks for sharing this with all of us, it's facinating to watch this beast come together! AmpAce |
Hey AmpAce it is great to hear from you. Hope as is well.
I had about 100 flights on my 50% Pitts before tearing it a part to build it lighter, which the tearing apart happened but the re-building has not yet. It flew great and slowed down and had a nice wing level stall, but the perspective of where the plane was and it's distance from me was hard. I had a guy say that he was looking for a model rocket in a field and love see my Pitts fly over them he was at least a half mile away! I like your idea about standing down the field more; I guess I am a creature of habit standing at the flight boxes. And their can't be much cross-wind with this beast because you can only have 8 degrees of roll before hitting on of the jet engines on the ground. Thanks, DAG |
I can hardly wait until it's finished.
![]() If you get the chance I recommend building a CNC router. It's awesome for making landing gear parts, prop hubs and stuff like that from aluminium, and you can mill complex 3D shapes as well, like the prop blades I made. I built mine early last year and it's the best investment I have made. I bought Discreet Plasma formy modelling. I used to use Max but found Plasma on Ebay and it's almost the same thing. |
I have never heard of Discreet Plasma for modelling, I will look into it. Can you router both wood and aluminium? What info does the CNC need? Can you take a AutoCad dwg and input it into the CNC? Thanks, and be safe. DAG |
Plasma isn't available any more, unfortunately. I was lucky to find one on ebay. I had hoped Discreet would release something similar again soon.
Mine is built from a combination of MDF and aluminium profiles and is quite rigid. A router like this can mill aluminium, plastic, composites and wood with no difficulties. It can even work with soft steel, just very slowly. I have made helicopter rotor systems and even rotor blades with it. The way it works is that you design the things you need in 2D or 3D CAD or both, then you move the models into a CAM software and prepare a toolpath for the machine to follow and finally transfer the toolpath to the machine and cut. The software I use can take DXF, 3DS, AI and some other 2D and 3D formats. The best resource for info on how to build a machine is cnczone.com EDIT: I almost forgot. It's possible to add a laser to the machine. I've thought a lot about doing it, but it's kind of dangerous. |
| Thread Tools | |
| Good B-36 site (drawing with cross sections, too!) | Thomas B | Scale Electric Planes | 26 | Oct 11, 2011 09:14 PM |
| B-36 B-52 | kgmorris | Scale Electric Planes | 20 | Jan 02, 2009 06:27 AM |
| b-36 | dorysch1 | Scale Electric Planes | 32 | Feb 01, 2004 08:33 PM |
| Questions about my wally B-36...I'm new to foam. | Boba_Fett | Foamies (Kits) | 8 | Jun 11, 2002 03:36 PM |
| B 36 | Trobber | Parkflyers | 3 | Dec 30, 2001 12:33 PM |
