Old Nov 14, 2008, 08:29 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Oh, i figured the length was the problem...
Have you ever emailed them and told them what you're doing? They may be so inclined to sponser you perhaps?
Thekid3418 is offline Find More Posts by Thekid3418
Old Nov 14, 2008, 10:46 AM
It only takes one good idea
dag214's Avatar
Fishers, Indiana
I really havent found anyone that has longer than 60", except aircarft spruce. They have 10' lengths but the are $550.00 each .
I have thought about taking a thick walled 12" 6061 tube and truning it down to a OD of 1.2" then epoxying it into the 2 tubes and see if I could join them that way.
DAG
dag214 is offline Find More Posts by dag214
Old Nov 14, 2008, 04:26 PM
dag214's Avatar
Fishers, Indiana
Here is a rendering of my main gear, the strut is 1" carbon fiber tube. I will start next week on making the parts, but first I have to pay the bills, work will have me hammered all next week. The entire right main gear should weigh 1.75 pounds.
DAG
Old Nov 15, 2008, 07:10 AM
dag214's Avatar
Fishers, Indiana
The fuse is going well. I am going to get 2 48" carbon fiber tubes and see if I can take a 6061 1.5" X12" tube with a wall thickness of .25 (or a little thinner) and see if I can turn down the OD to fit the ID of the CF tube. Also I had a e-mail asking about the main gear parts, so I expoded the gear rendering.
DAG
Old Nov 15, 2008, 07:45 AM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
I borrowed a 6S battery from my neighbour today and am charging it now.
Lynxman is offline Find More Posts by Lynxman
Old Nov 15, 2008, 08:07 AM
dag214's Avatar
Fishers, Indiana
Here is how I could belt drive (with top spar and some ribs removed). Both AXI (Hobby Lobby) and Hacker are giving me great info and telling me what other people have found that works not just what a calculator says. Hacker has a huge choice of KV on their motors. If I can direct drive and keep weight and CG good I will go that way, but a smaller and lighter motor with a belt drive turning a 20" prop would be just as good if I get the RPM and amps I need.
Can't wait to see what you get with the 6cell.
DAG
Old Nov 15, 2008, 08:35 AM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
With a 6S 2600 mAh 25C battery.
18x14" - Way too much.
68 A
20.5 V
18x10"
58 A
20.7 V
4900 rpm - That's a pitch speed of 21 m/s, or 47 mph with a 10" pitch prop.
I think the motor would be hot after landing if it was propped this heavilly in flight. The Soloprop is a much heavier prop to drive than an APC with the same diametre/pitch/number of blades though.
Old Nov 15, 2008, 08:58 AM
dag214's Avatar
Fishers, Indiana
68 A
20.5 V
18x10"
58 A
20.7 V
Thanks, that is great info. That was direct drive correct?
I have done some testing (in math) and if I belt drive with a ratio of 1.6 the AXI should be able to turn a 20-14 3blade at 4000 rpm that is a prop speed of 52mph, that is at 7 cells and the amps should be 35ish. The motor speed would be 6300 rpm. Hacker is looking at which of their motors will turn this prop set-up, but I am 95% sure that the axi with a belt drive will do the trick also. All my calcs show I need a pitch speed of arond 52-55mph.
Thanks, DAG
Old Nov 15, 2008, 09:13 AM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
Yes, direct drive.
I used to fly the P-40 with this motor, a 1:1.6 gear ratio on 8S and a 20x14 Soloprop. The batteries back then didn't hold voltage as well as today but it drew ~45 A at full throttle static on 8S. I agree, on 7S the current will probably be around 35 A. I recommend you design it for a shaft diametre of at least 8 mm. I used 6 mm which works as long as you never bump into it or strike anything, but it's noticeably flexible. I'm upgrading my system to a 10 mm hollow shaft.
I buy pulleys and belts from sdp-si.com
Old Nov 15, 2008, 10:28 AM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
DAG
Dag,
Are you familiar with Aeropoxy? I know CA holds carbon quite nicely but I suggest to you if you get a carbon pin sized right and glue 2 carbon sleeves together (and glue them together with Aeropoxy), they would be the last things still fastened in the event of a catestrophic event, the stuff doesn't let go, ever...
Jack
jfetter is offline Find More Posts by jfetter
Old Nov 15, 2008, 10:37 AM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Thanks, DAG
High amperage and very low efficiency (heat) is exactly what I was saying a few pages back, that motor is simply not the correct choice. I'm not trying to tell you I am the expert, only that I have quiote a bit of experience with 6S setups and the Axi/Hacker options, in this case, the KV rating is all wrong for what you want. If you want to design a belt drive I am sure that will work but it really shouldn't be much more than an excercise in electric fundamentals to size the motors appropriately here...
Jack
Old Nov 15, 2008, 11:45 AM
dag214's Avatar
Fishers, Indiana
Jack
Thanks Jack and you are most likely more an expert than I, The AXI info shows the 4130/20 with an 18-10 prop. That is where I was going with attempting an 18-10. I am now starting to understand the whole amp/KV rating thing. The reason I am trying to be careful of the actual motor size is weight. Hacker has some motor with really low KV that could easily turn an 18", or 20" prop well, but they are heavy motors, and lots of $$$$. Hacker does have some very cool inrunners with planetary drives that are a lot lighter and can turn a 20" prop, but again lots of $$$, but I may end up going that way. In the end with all your help and Hacker/HobbyLobby I will find what will work. But the P-40 with a 3blade 20" prop has the power I need, especially when I would take 6 set-ups like the P-40.
The big battle is:
1st-Weight
2nd-Scale prop 20" or 18"
3rd-$$$$
Or should I say $$$$ is what will making me belt drive 305Kv type motor if all other options are just to expensive.
Thanks for your input and keep it coming.
DAG
Old Nov 15, 2008, 11:52 AM
dag214's Avatar
Fishers, Indiana
Dag,
Jack
Aeropoxy-Yes it GODS glue.
Just finding a CF OD to fit the 1.5" ID is the hard part, but I am going to get some 48"X1.5" CF tubes and turn a 1.5 6061-T6 tube down to the ID of the CF tube the Aeropoxy the tubes together. After messing around this morning with some scrap CF tube I bet it will work, but boy is it going to get expensive. First I need 4-48"X1.5" for the fuse, then 5-36"X1" for the wing spars, and 2-36"X1" for the H-stab. About $600.00 worth of CF.
Thanks, DAG
Old Nov 15, 2008, 11:54 AM
dag214's Avatar
Fishers, Indiana
Yes, direct drive.
Thanks Lynxman, what does the P-40 weigh????
DAG
Old Nov 15, 2008, 01:58 PM
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
It weighs 6 kg (13.22 lbs) with a 4270 mAh 8S battery and has a wingspan of 73".
A benefit of belt drive is that you can adjust the gear ratio to get the rpm/torque you need. That was one of the things that made me try it on my P-40 instead of rewinding another motor as I often had to rewind over and over to get the desired result. I recommend using a idler pulley on the belt to wrap the belt around the pulleys on the slack side of the belt. It isn't showing in the picture I posted because I added it later. I made it from two ball bearings.
I'm sure Hacker or MM or Scorpion can supply a suitable custom wound motor though.
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Electric Planes 26 Oct 11, 2011 09:14 PM
B-36 B-52 kgmorris Scale Electric Planes 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Electric Planes 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
