Old Feb 15, 2009, 01:17 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Originally Posted by Rickn816
That is not necessarily correct. You can build an effective Faraday cage from aluminum window screen.
You might look for a way to get part of antenna external to the fuse.
Rick
You can see one of the test here:
http://004edc4.netsolhost.com/FM_and_2.4_Radios.htm
Not in the test mentioned, but in some test the RX worked better when inside the foil skin. My foil is thinner than Flight Metal and about a quarter the price.
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Feb 15, 2009, 01:48 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by dag214
Rick,
Not going to get into much of a debate on this one. There has been over 6 known test with 2.4 systems to test this foil with no problems. And there is a huge difference in EMP and distorting or blocking a radio wave. Just look up all the other radio systems that have worked just fine with these foil systems. One test used the JR device that was looking for lost frames (at least that is what I think you call them) and at 200' with a bocked cover with 2 mil foil it lost none. And guys would not be flying 20k+ jets if these foil systems had any problems at all.
Thanks, DAG
I'm not an expert on 2.4 GHz. I am not always willing to accept "tests" by someone who is trying to sell me something, however.
Having see the way you test everything, I know you will conduct extensive range checking before it ever leaves the ground.
Thanks.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Feb 15, 2009, 05:07 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Thanks.
Rick
I totally agree with test where things are being sold. And I have done a ton of research on this subject. And there is a ton of info on what type things block what type of signals. The cool thing is that if I do have any problems at all range checking I could make my antennas look like the ECM antennas on the real B-36, and in the end may do that.
Thanks, DAG
Old Feb 15, 2009, 05:21 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Where? The rest of us could sure use that info!
Great idea! Functional scale antenna!
Angelo is online now Find More Posts by Angelo
Old Feb 15, 2009, 05:27 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
[QUOTE=Angelo]Where? The rest of us could sure use that info!
Just type in:
what materials can block radio frequencies.
It is all out there.
Thanks, DAG
Old Feb 15, 2009, 05:28 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I have been playing with the BC8DX and the Xtrema. The BC8DX simply Rocks, it is the best and easiest charge I have ever seen, I can charge 2 8C 5000 mah at once, but only at 3 amps each. But still for a plane with 6 each 8C that makes it easy. I will have 3 of them, or the Xtrema, it can also do about the same, just in a different way.
Thanks, DAG
The BC8DX is a great charger, a semi-clone of the Hyperion (which beat it to market) but with some cool graphing added. The one drawback is the lower wattage though, I would have liked to see 250 - 300 watts per port rather than the 160 watts per port for the BC8DX, which is a tad lower than the Hyperion at 180 watts per port...
Jack
jfetter is offline Find More Posts by jfetter
Old Feb 15, 2009, 07:21 PM
Demented is offline
Find More Posts by Demented
Demented's Avatar
Singapore
Joined Sep 2004
Ok,
I know I can put a stop to the confusion.
Do you all think I could convert this to electric ????
DAG
YES of-course! I just got a electric shock from the two round batts...
Demented is offline Find More Posts by Demented
Old Feb 15, 2009, 08:14 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
I got all 6 cowling done today.
DAG
Old Feb 15, 2009, 08:26 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Looks great X 6
feathermerchant is offline Find More Posts by feathermerchant
Old Feb 15, 2009, 11:21 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
Very nice Dag.
sneasle is offline Find More Posts by sneasle
Old Feb 16, 2009, 07:49 AM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Every time I visit this build I'm more impressed. Again my compliments. Mike
mike2663 is online now Find More Posts by mike2663
Old Feb 16, 2009, 08:38 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Hi DAG
Are you going to skin those nacelles, or use them as a plug for fiberglass?
Old Feb 16, 2009, 11:26 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Thanks all,
At this time I am going to skin and glass the cowls to become plugs for molds, but, and that is a big but, they come in light enough, they might be the cowling's I use.
Thanks all,
DAG
Old Feb 16, 2009, 11:44 AM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Thanks all,
Thanks all,
DAG
Unless they are all the same and you can get 6 molds from 1 plug I'm not sure you get any benefit. Might as well skin 'em, glass 'em and call it done!
Nice work!
Jack
Old Feb 16, 2009, 12:06 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Nice work!
Jack
You are right Jack,
They are all 6 different, I bet in the end they are my cowls.
DAG
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
