Old Feb 13, 2009, 07:58 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Originally Posted by dag214
Ok,
I know I can put a stop to the confusion.
Do you all think I could convert this to electric ????
DAG
Ha!
Damon, that kicks a$$
As for all the stranded vs solid mumbo-jumbo, there is a good reason that we use stranded/braided wire in motors and power systems, especially the larger ones - and it applies to full scale aviation as well - it is about controlling the side effect of current flow through the wire - which is known as EMF (electro-magnetic-field). How this radiates from the wire, as well as how it affects things around it (such as other wiring, the magnet-poles of the motor, or sensitive electronics) is critical in it's application. Flexability of it is also a main mechanical feature.
I'm not going to argue about how you guys wired your house, factory, or welder - because we aren't trying to fly those applications
(Well, maybe some of us ARE trying to make flying welders!)
PS - Happy 100th Page DAG!
FL62 is offline Find More Posts by FL62
Old Feb 13, 2009, 09:27 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi Guys....
Quite truthfully, I'm sorry I said anything asI wasn't trying to start and arguement, but I will stand by my opinion that the wire shouldn't be "zip" cable or something of that nature. It needs to be high quality multi-strand wire...now as I said...I'll shut up...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 14, 2009, 02:12 AM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
No worries Steve, but some more numbers for your enjoyment:
Wire Type .......................Gauge .................Strand Count/Strand Size
PTFE Hi-temp wire:........... 14................................19/27
Stranded Hook-up 300v:.....14................................41/30
"Zip" Cable:......................14.................... ............41/30
As you can see, the 'Zip' wire is pretty high up there on strand count. I like the Zip wire because usually I need to run a positive and negative line, and having the Zip allows me to run equal lengths easily. The Zip really just refers to being able to pull apart the 2 conductors easily if you need to.
No need to be quiet Steve, these discussions are what makes life fun. Gotta get that grey matter working .
sneasle is offline Find More Posts by sneasle
Old Feb 14, 2009, 06:43 AM
Tseres is offline
Find More Posts by Tseres
Tseres's Avatar
Joined Feb 2009
Ok,
DAG
I'm the guy who isn't an engineer.Don't know abouth the electrical stuff.
Going back a little and the aplication of aluminum skin could be acomplished.The aplication around the curves could be a bit fidly and time consuming,but I think it could be accomplised and worth it.
As for the plane? Eh.
Old Tom
PS: Dag this is a great thread and I'm learning a lot.Thanks and keep it up.
Tseres is offline Find More Posts by Tseres
Old Feb 14, 2009, 06:47 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Wow, a 100 pages, I hope on the 200th, there will be pics of her flying.
I really like the input about all things, even if it is about the size of your wire or the size of the tool you use. In the end this is a really great place to share what we all know. I left another forum because there was a situation where people were trying to add input just to sell product, or make them look like they are an expert at everything. So far on this forum everyone has said what they think in the heart, what they really believe, and that is just fine with me.
I love all debates because that is how we learn.
But really only on thing counts, will she be 220, or 221, I think it will be what ever she can take .
Rock on everyone.
Here is a mock up of what will be a plug for my engine cowl molds.
DAG
dag214 is offline Find More Posts by dag214
Old Feb 14, 2009, 06:48 AM
N99JH is offline
Find More Posts by N99JH
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
Ok,
DAG
The top half is already electric! the bottom half is an individual choice
N99JH is offline Find More Posts by N99JH
Old Feb 14, 2009, 01:26 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by Angelo
Owen, you may be great, but if you're going to quote sources, Wikipedia is not the way to go. ANYONE can go in and edit a listing, hell, I could go in right now and re-write it to say that depth is what matters. Some one else might see that and fix it. Then again, maybe not.
"Wikipedia, the triumph of democracy over truth."
While you are certainly entitled to your opinion, the Wiki articles in my field of study are correct and accurate, so far (Geology, PhD).
Wiki is like any other "information." Verify with independent sources.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Feb 14, 2009, 01:28 PM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Ok,
DAG
Sorry, Dag. Maybe you should come out of your workshop occasionally.
That is electric.
Rick
Old Feb 14, 2009, 02:43 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
I'm no engineer (just a broken-down old chain saw mechanic) so I have no knowledge here, but I'm curious as to the efficiency of a thin wall copper tube as a conductor vs. stranded vs solid. Impractical, perhaps, but I'd think both resistance and weight would benefit.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Feb 14, 2009, 02:47 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
Depends on what you are sending through it. If you are sending DC, then no (assuming diameter and alloy being equal).
If you are sending a higher freq signal (100's khz), then they would be equal in their load capacity.
But, try and bend the tube around a corner and see what happens.
Old Feb 14, 2009, 02:56 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Originally Posted by Geoffinpdx
... (just a broken-down old chain saw mechanic) ...
Geoff
Well, I guess that beats being a broken-down old chain saw massacre-er -er?
James
Deuce is offline Find More Posts by Deuce
Old Feb 14, 2009, 02:58 PM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Usually, I kink the tube
Rick
Old Feb 14, 2009, 10:05 PM
sml is offline
sml
Find More Posts by sml
sml
United States, MD, Lusby
Joined Jan 2007
Rock on everyone.
DAG
It is REALLY coming together!! With that mock-up you get a really good sense of the clean lines. Have given any thought as to what giant scale fly-ins you may want to take her to? Would you ever take her to the Joe Nall? The main runway is 7000ft by 400ft smooth grass. Plus it is a lot of fun!! Been 5 times myself.
Saul
sml is offline Find More Posts by sml
Old Feb 14, 2009, 10:28 PM
sml is offline
sml
sml
Joined Jan 2007
Dag,
I found a charger that might help with charging all of those batteries for the B-36. It's called the Power Peak Eternity Charger. It is made by Robbe Modellsport. Here are the specs according to their website:
"The following battery types and cell counts can be charged:
1 - 36 NC cells
1 - 36 NiMH cells
1 - 12 PB / lead-acid cells (2 - 24 Volt)
1 - 14 LiIo (3.6 V), LiPo (3.7 V), LiFe (3.3 V) cells, plus special voltage."
In addition to the Charge, Discharge and Cycle modes the charger also provides different charge processes to suit the various battery types."
The website says it also has 2 outputs for charging.
Here is the link:
http://at.robbe-online.net/rims_at.s.../View/1&2D8471
BTW, I'm not selling anything. I just thought maybe you might need a charger that would be able to handle all those batteries.
Saul
Old Feb 14, 2009, 10:56 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
The hyperion duo also has 2 outputs. I charge my 6S 5,000 packs 2 at a time.
feathermerchant is offline Find More Posts by feathermerchant
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
