Old Nov 12, 2008, 01:49 PM
N99JH is offline
Find More Posts by N99JH
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
Originally Posted by Lynxman
Here are a few pics. I'm going to make a new reduction system with a more advanced propeller soon. I'm mostly into jets at the moment though.
Lynxman
I don't mean to hijack your webpage but was curious about your system. I ran the numbers through Motocalc and it shows very low efficiency for you drive system, something like 52%. The video clip shows very impressive flight performance though. Can you tell me at what RPM your 21.5-14.5, 3 blades prop turned at motor wide open please?
Joshua
N99JH is offline Find More Posts by N99JH
Old Nov 12, 2008, 01:55 PM
Lynxman is offline
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
Motocalc does not calculate Axi motors accurately based on the numbers from Model Motors. The wide open static prop rpm is ~4000-4100 rpm, which gives about 7000 motor rpm and a current draw of 48-49 A.
To more accurately estimate performance at 8S I use the following motor constants:
kv: 285
No-load Current: 1,6 A
Resistance: 0,045
Lynxman is offline Find More Posts by Lynxman
Old Nov 12, 2008, 02:00 PM
N99JH is offline
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
kv: 285
Resistance: 0,045
Thanks. I appreciate the quick response and will run the numbers again. I am building a belt reduction with 2.5:1 ratio to drive a 31.5 X 31 scale prop with a Hacker A60 18L on 12S 5000 mAh.
Old Nov 12, 2008, 03:35 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Very VERY cool.
The prop looks great also.
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Nov 12, 2008, 03:44 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
kv: 285
Resistance: 0,045
I thought anytime you used a belt drive that you would lose at least 20% efficiency. Your design looks very clean though. Are you turning that 20" 3 blade at 4500rpm??? Because I had written of having the true scall size prop of 20" on this plane. Your set up X6 for my B-36 would fly it fine.
Thanks, DAG
Old Nov 12, 2008, 04:31 PM
N99JH is offline
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
Thanks, DAG
Properly designed belt reduction system will provide AT LEAST 90% efficiency, usually even better than that!
Old Nov 12, 2008, 05:41 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Hi Jack,
I am not trying to turn a 20" prop, I am cutting a 20" down to a 18" to get the preformance I need.
Attached is what I will be putting on the motor.
Am am at about 52 amps, and that's at 100 power. I will be running at about 2/3 throttle.
Thanks, DAG
Just trying to be helpful, I've had 4 planes running Axi 4130/16 setups and they routinely draw more than 75 amps (on 6S @ 7,450 RPM) turning a 17 x 10 or 18 x 8. I know you're looking at a 4130/20 but it's pretty easy to see even with the different KV you're loading that motor up too much. I'm rooting for you no matter what, nice build so far...
Jack
jfetter is offline Find More Posts by jfetter
Old Nov 12, 2008, 05:46 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Jack
Jack you are 100% correct that I will be getting close to the 55 amps, I just need to do some testing and see what happens. Every electric that I have built has been over powered. I never use full throttle, but that is just me. I like a long ground roll and a scale climb-out. I still feel that a 18-10 will fly this plane all day even with a prop pitch speed of 49mph. And everyone's input is very welcome.
Thanks, DAG
Old Nov 12, 2008, 06:11 PM
pvtzemerak is offline
Find More Posts by pvtzemerak
JR > Futaba
pvtzemerak's Avatar
Green Lane, PA
Joined Mar 2008
SUBSCRIBED!!!
man, nice looking plane, goodluck!
--pvt
pvtzemerak is offline Find More Posts by pvtzemerak
Old Nov 12, 2008, 06:50 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Originally Posted by pvtzemerak
SUBSCRIBED!!!
--pvt
DAG
Old Nov 12, 2008, 06:52 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
More fuse pics. Been working a bunch and not much more done, just a few bulkheads. Will try to get more cut out tonight.
DAG
Old Nov 12, 2008, 07:24 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
I've been lurking since the start of this thread, and have been most impressed! I have to second the sentiment about the long, scale takeoff runs, with a graceful climb-out! I've watched too many videos of nice scale models that are flown like toys...
One question that's been on my mind about this: Will the motors/props really produce the incredible sound that could only come from the B36? Hehe!
Deuce is offline Find More Posts by Deuce
Old Nov 12, 2008, 08:27 PM
Tim Farrar is offline
Find More Posts by Tim Farrar
Bi-Planes
Tim Farrar's Avatar
Houston Texas
Joined Apr 2006
Looking better and better Dag !!!
That P-40 is awsome Lynxman !!!!
Seeya, Tim
Tim Farrar is offline Find More Posts by Tim Farrar
Old Nov 12, 2008, 10:11 PM
Ercoupe Ed is offline
Find More Posts by Ercoupe Ed
Vintage Flyer
Indiana
Joined Jan 2005
Nice P-40 Lynxman
Tim and Dag and Lynxman
Here's a picture of great piece of aviation by artist John Shaw.
I have a copy of it signed by many of the Flying Tigers.
Great investment!
It has went up in price 250% since I purchased it.
I have another one called The Warrior and the Wolfpack,
and this one is called
"Tigers In The Gorge" when in 1942 the Flying Tigers with just 8 airplanes and led by "Tex Hill" stopped the Japanese cold from crossing the Salween River at the Salween River Gorge.
had the Japanese got across, they would have easily conquered China.
So you can say the Flying Tigers changed the course of the war and the course of history.
The last picture is of a B-29 at Iwo Jima.
All three paintings are by artist John D. Shaw
My painting of The Warrior and The Wolf Pack is signmed by Gunther Rall ( German Luftwaffe ace, Bud Mahurin, American fighter ace from my hometown of Ft Wayne Indana, and also signed by Francis "Gabby" Gabrieski.
Ed
Ercoupe Ed is offline Find More Posts by Ercoupe Ed
Old Nov 12, 2008, 10:23 PM
Bi-Planes
Tim Farrar's Avatar
Houston Texas
Joined Apr 2006
Very nice Ed !!!
Thanks for shareing it with us !!!
Seeya, Tim
Good B-36 site (drawing with cross sections, too!) Thomas B Scale Kit/Scratch Built 26 Oct 11, 2011 09:14 PM
Discussion B-36 B-52 kgmorris Scale Kit/Scratch Built 20 Jan 02, 2009 06:27 AM
b-36 dorysch1 Scale Kit/Scratch Built 32 Feb 01, 2004 08:33 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
B 36 Trobber Parkflyers 3 Dec 30, 2001 12:33 PM
