Old Oct 02, 2008, 09:18 PM
jetstream is offline
Find More Posts by jetstream
Joined Dec 2003
effect of tx antenna gain on 2.4G systems
Hi, need to ask any expert on this subject. I have a corona JR 2.4g module that comes with a 5dbi gain antenna. I have on hand 2 antennas ,one a 4dbi and the other a 8dbi gain. I kinda prefer the 4dbi as it is full swivel and about the same length as the one found on futaba.
I read somewhere that a higher gain antenna gives better horizontal distance at the expense of sky distance i.e more suitable for surface use, wonder if that statement is true.
If I use the 8dbi antenna, would that give me greater range or would the 4dbi antenna give better sky range?
jetstream is offline Find More Posts by jetstream
Old Oct 03, 2008, 12:15 AM
bnrusso is offline
Find More Posts by bnrusso
early retired & loving it
USA, AZ, Kingman
Joined Aug 2005
Higher gain antennas are more directional.
If you take a circle and squeeze the sides it becomes far reaching in the longer direction and much shorter radiation at the sides. At higher gain you have to point the gained pattern toward the receiver.
Some higher gain antennas move the circle so it starts radiating just in front of the antenna and not behind.
You really have to look at the designed radiation pattern to see how it could affect communications.
And even that is just a theoretical radiation pattern.
http://en.wikipedia.org/wiki/Radiation_pattern
here are many designs and their patterns.
http://www.kyes.com/antenna/navy/rpatterns/radiapat.htm
bnrusso is offline Find More Posts by bnrusso
Old Oct 03, 2008, 06:45 PM
Joined Dec 2003
Thanks for the info.Will give the 4dbi a test run and see how it performs.
Found Now that everyone's jumping on the 2.4G craze, who has a Hitec 05S rx? Bigster Aircraft - General - Radio Equipment (FS/W) 3 Feb 22, 2007 09:15 PM
Discussion Gain of typical 72MHz Tx antenna AnthonyRC DIY Electronics 9 Jul 11, 2006 07:25 PM
Discussion Free 7db 2.4g antenna at compusa DiveBombDave Aerial Photography 4 Jan 28, 2006 05:41 AM
Rubber ducky Tx antenna on 36 Mhz? AntonL Radios 1 May 04, 2004 10:21 AM
Effect of rare earth magnets on receiver/antenna? TMO Radios 2 Dec 12, 2003 07:53 PM
