Old Oct 02, 2008, 02:53 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
foam cutting highly tapered tips
I've been trying to cut some highly tapered foam cores on a new hlg. The tip panel is 2" wide, inner airfoil is 3.5, tip is 2".
Can't get it to work well with my gravity cutter. Anyone have any techniques that might work?
GaryO is offline Find More Posts by GaryO
Old Oct 02, 2008, 03:53 PM
Tony Hallo is offline
Find More Posts by Tony Hallo
Springdale, PA
Joined Mar 2008
Here's some information that I posted some time ago on another site, might be helpful.
http://www.rcuniverse.com/forum/m_39...tm.htm#3951812
Tony Hallo is offline Find More Posts by Tony Hallo
Old Oct 03, 2008, 12:04 AM
blewis01 is offline
Find More Posts by blewis01
that's gonna hurt...
USA, CA, San Jose
Joined May 2005
Gary - if you have a Feathercut, look in the instructions for the pivot method. Basically, one end of the wire is fixed, and the 2nd end is attached to the drop arm. PM me an email address if you need a scan of the instructions. I use this method to cut DLG tails.
Bruce
blewis01 is offline Find More Posts by blewis01
Old Oct 03, 2008, 03:13 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
The burn effect depends on the Mateial you want to cut ( for EPP there is an recommended spline length ratio of about 2 - the shorter spline is minimum the half of the longer! Of course you might expand this a bit but results go worse...
I did several tapered parts but used EPP for material which had been cut very slowly with low current ( and is also more resistand against heat) but you also could include folds in the spline you have to grind away afterwards or another posibility is that you cut not tapered but dual spline ... which lowers the precision of your cut!! ( what you may compensate when designing the endplates you cut on...
Mine is truely tapered but cnc ... - I also had this problem many times ... dont give up
EPS 40 styrofoam prototype
RG30 EPP Final
Harpye is offline Find More Posts by Harpye
Old Oct 03, 2008, 06:18 AM
Harpye is offline
Harpye's Avatar
Germany
Hot Wire Cut Video of Tapered And Straight Cut Combination
I attached a little video which is to show how it works...
DIY Hot Wire Cut (1 min 13 sec)
Hansjoerg
Old Oct 03, 2008, 10:47 AM
ThermalThief is offline
Find More Posts by ThermalThief
Do it AGAIN! This time BETTER!
ThermalThief's Avatar
WA
Joined Jan 2005
Gary,
I would guess you will radius the corner on the tip. I would hand craft the entire tip section...or cut with much less taper as you will modify the leading edge when you radius anyways.
Ken
ThermalThief is offline Find More Posts by ThermalThief
Old Oct 04, 2008, 03:34 PM
GaryO is offline
Joined Sep 2001
Ken,
You might recall at Pasco both Tim and Jonathan and maybe Phil has versions of Jonathans "Dolly".
The purpose of the highly raked tip is to get an accurate airfoil and it seems to work well. Anyhow, that is what I'm trying to do. They are cutting it with the wire pivot method and that's what I'll try.
Another question for anyone:
When cutting a panel with both LE and TE sweep with a Feather Cut type cutter, how are you positioning the blank on the table?
TE paralled with the table edge
Blank adjusted so the middle of the blank (span wise) is parallel to the table edge
Or something else?
foam cutting tapered tips GaryO Composites Fabrication 5 Aug 10, 2005 11:24 PM
Foam cutting tapered wings splatman The Builders Workshop 14 Jul 15, 2005 07:17 AM
Foam cutting tips!!! Martijn Kaandorp Foamies (Kits) 7 Feb 24, 2005 05:11 PM
Need help cnc foam cutting tapered wings RobDog The Builders Workshop 3 Jun 01, 2004 01:16 PM
Pink Foam cutting tips microflyer77 Foamies (Kits) 1 Mar 05, 2002 11:42 AM
