This thread is privately moderated by AirX, who may elect to delete unwanted replies.
Old Oct 11, 2008, 12:29 AM
marineA4 is offline
Find More Posts by marineA4
MAR
marineA4's Avatar
Houston, Tx
Joined Jun 2004
Some little mods to convince the looks can gradually be done Eric. Sometimes though its not looks that matter but reliability.
I'm sure its super reliable now with the belt driven upgrade. Glad its working out!
Let me know how that little F-86D comes along.....
I myself will be doing some templates here soon and cut out some foam for the BD-5.
Orlando
marineA4 is offline Find More Posts by marineA4
Old Oct 11, 2008, 04:25 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Orlando
Cool O, look forward to seeing the BD evolve. This F-86D is sized for the Wemo micro so it is large for the GWS40.
Eric B.
AirX is offline Find More Posts by AirX
Old Oct 23, 2008, 06:09 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Here is a picture taken from my CAD program.
Eric B.
Old Nov 02, 2008, 09:06 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Ok, started cutting the parts today. Here is a section I have completed to show you how it will be constructed. It will be on the large size for a 40mm.
Eric B.
Old Nov 04, 2008, 11:28 PM
marineA4 is offline
MAR
marineA4's Avatar
Houston, Tx
Joined Jun 2004
I see you got the hotwire going........Cool!
Starting to look pretty good
Orlando
Old Nov 05, 2008, 06:35 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Orlando
Hi O,
Yup it is going but I still need more heat for straight cuts. I am limited by the ammount of amps I can run thru the wire right now(~1mm sec).
Eric B.
Old Nov 05, 2008, 08:15 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Here is a few more foto's of the construction of the fuselage.
Eric B.
The cutout is for the 1/8 spar for the wing panels.
Old Nov 08, 2008, 06:02 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I have started to assemble the parts, I needed to get the canopy cutout finalized and make a test cut and in the picture you can see the cut is there opening the fuselage for the battery and esc compartment. the aft end will be assembled tomorrow, I have cut the last section to mount the horizontal stabilizer to assure the thrust line the the horizontal stab are correctly situated. The duct is readily visible and it looks like it gets smaller at the inlet but it actually spreads out more so the area is preserved.
More to come.
Eric B.
Old Nov 09, 2008, 08:38 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Nice Eric! The transitions in the duct from segment to segment look pretty mild, are you going to try to blend them anyway?
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Nov 09, 2008, 08:40 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Eric-- Can you show some of your templates? I'm about to start on my Viggen project and I'm spending a lot of time laboring over the ducts. I don't have or do CAD so it's worked out either in my head or pencil and paper.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Nov 10, 2008, 05:26 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
-Matt
Hi Matt,
Working thru it slowly...
The transitions probably wont hurt as much as changing area transitions. I will try a test when I get the fuselage completed and see what the little bugger puts out...
Eric B.
Old Nov 10, 2008, 05:32 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Mike,
The sections change as the duct progresses thru the fuselage. ClausXPF posted a few jpegs of good duct design and it is very similar to what I use.
Designing without CAD is fine, you know the starting shape and the ending shape so the shapes that transition thru formers can be derived thru orthographic projection techniques we all learned in the days the pencil was king. I still do the this with AutoCAD when I use it.
Eric B.
Old Nov 10, 2008, 08:09 PM
Joined Jan 2004
Thanks Eric. So simple.
Old Nov 11, 2008, 03:41 PM
Coop is offline
Find More Posts by Coop
Lawton/Fort Sill, OK
Joined Sep 2002
I want a kit!!!!
Coop is offline Find More Posts by Coop
Old Nov 11, 2008, 09:16 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Mike,
If you have any questions just pm me...
Eric B.
