This thread is privately moderated by AirX, who may elect to delete unwanted replies.
Old Oct 01, 2008, 11:10 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
F-86D for 40mm, Micro EDF Contest 2
What do you think of this?
AirX is offline Find More Posts by AirX
Old Oct 02, 2008, 01:08 AM
NorCalPilot is offline
Find More Posts by NorCalPilot
Joined Apr 2006
Sweet.... great job!
NorCalPilot is offline Find More Posts by NorCalPilot
Old Oct 03, 2008, 05:29 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Thank you for the comment. I still need to work on wings and horizontal stab/vertical stab.
Eric B.
Old Oct 03, 2008, 06:41 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Looking good Eric - shiny!
Is that a spinner on the front?! Just kidding - you don't see the "D" version done much, should be a nice build. I got my MiG-17 roughed in but haven't done any real designing yet.
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Oct 03, 2008, 08:47 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Matt,
This will be a little larger than the average 40mm but as close to 90%FSA area inlet as I can get to keep performance as high as I can. Hope to get one flying before too long.
Eric B.
Old Oct 06, 2008, 09:06 PM
marineA4 is offline
Find More Posts by marineA4
MAR
marineA4's Avatar
Houston, Tx
Joined Jun 2004
Ah yes, what i've been wanting to model for the longest. Come on! Get her done Eric, i'd love to see one fly.
Is this going to be depron or balsa?
I've taken a break on EDF and moved over to the giant scale stuff. I've gone ahead and started on a Ziroli F4U Corsair build. Man, this thing is huge.....Its been atleast 8 years since I last built a giant scale.........
Good luck with the F-86 DeltaDog.........
Orlando
marineA4 is offline Find More Posts by marineA4
Old Oct 06, 2008, 09:58 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Orlando,
No balsa. Maybe a carbon tube spar.
I thought you might like it. It might be a fast one as it will be larger thant the average 40mm with arround 135in^2 wing area and 25in winspan. The inlets 98%FSA so it will be able to breath.
Good luck with the Corsair.
Eric B.
Old Oct 07, 2008, 10:38 AM
marineA4 is offline
MAR
marineA4's Avatar
Houston, Tx
Joined Jun 2004
25 inches is kind of small. Go ahead and make you a 70mm size Dog man! You sure can add more detail to it.
Nevertheless looks good and good luck. Looking forward to seeing it fly.
As for the Ziroli Corsair, I figured a giant scale gasser is what I miss flying. I've flown Ziroli planes before and they fly really good. Hope I can get her done, you know how that gets........
Orlando
Old Oct 07, 2008, 05:37 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Orlando,
Maybe a larger one later.
Eric B.
Old Oct 07, 2008, 10:15 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
A few more views of the airframe.
Eric B.
Old Oct 08, 2008, 08:59 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
A couple more pics to see how it is developing.
Eric B.
Old Oct 08, 2008, 09:26 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Nice Eric. Is that red ball for the CG calculated in your modeling software by any chance? That would be a nice feature, I am getting better at guessing where the gear needs to go but never quite perfect.
Are you planning to do the fuse in depron ala GGRN or some other method?
-Matt
Old Oct 09, 2008, 05:04 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Matt,
Fuselage will be CNC foam cut. The CG is calculated and placed by the software. The flying CG will have to be calculated by spreadsheet, then I will set a different color ball for it so I can compare the two. It does require the individual parts to be created so they represent the mass of the original part.
Eric B.
Old Oct 09, 2008, 08:58 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Nice - I gotta hop on that home CNC cutting bandwagon, the next five years or so are really gonna be interesting in this hobby.
That CG calculation is great - I don't think Rhino has any plugins to do that. The real advantage I see is setting the CG three dimensionally, not just in plan view - hopefully it'll be accurate enough for this kind of designing.
-Matt
Old Oct 10, 2008, 05:09 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Cool, just do not be fooled into thinking it is easy to build and make a reliable CNC system. If it were not for Orlando I dont think I would have been able to get some of the modifications done to make this one reliable.
Cheers,
Eric B.
