Go Back   RC Groups > Aircraft - General > Radios
Old Oct 01, 2008, 01:37 PM   #1
Blender Operator
simon737's Avatar
Setting up the DX6i with 3 position flaps?
Hi,
So how can 3 position flaps be set up using the DX6i, as far as I can tell you can only have either down or up, unless there is a cunning way of using the Gear switch as well as the Flap swich??
Anyone help??
Thanks in advance.
simon737 is offline Find More Posts by simon737   Reply With Quote
Old Aug 10, 2009, 04:29 PM   #2
A bit old this thread and maybe you already have the answer but here goes.
Use Mix1 to mix Gear into Flap. Choose how many % you want the flaps to go out on the gear switch. You will now have X% on gear switch and 100% on flaps switch. However don't use both switches at once as you will get 100% + the % you set for the gear switch.
SEALen is offline Find More Posts by SEALen   Reply With Quote
Old Nov 06, 2009, 07:58 PM   #3
Long-Time Member
James Frolik's Avatar
That is an awfully clumsy way to do it—and a potentially problematic one if inadvertently extended to that 100% + gear switch percent.
There has got to be a better hacker's way to do this. Of course it would voids any warranty or product guarantee. Reprogramming? Installing a digital wander switch? (If you can find—or build—one, such a switch would mimic proportional pulsations as to maintain a halfway point. The only negative is that it would really suck up battery current...and possibly ruin a servo.)
There's got to be a way. Or else Spektrum will not be my first 2.4Ghz radio. I really like Spektrum's Rx availability for all types of models, but this simple switch make them really look ignorant.
James Frolik is offline Find More Posts by James Frolik   Reply With Quote
Old Nov 07, 2009, 05:31 PM   #4
Air, Ground & Water
The DX7 comes with a 3 position flap switch but the DX6i only has a 2 positions flap switch. If you need to mimic a 3 position flap system then simply setup the flap as you want them in the lowest position then add a mix to add more when toggle.
My setup is as follows.
Norm Flap = Flap 0% Elev 0%
Land Flap = Flap 50% Eleve 10% Elevator % depends on you're model or if you want it.
Then I have a mix that when on will and travel to my flaps.
MIX 1 and or 2
Flap to Flap ACT
Rate D +50% U 0%
SW ELE D/R Trim INH.
What this does is my flaps work as a simply 2 position flap but when I toggle the Elevator dual rate switch right next to the flap switch I get a little more out of them.
All this is also setup as flaperons, alierons acting like flaps.
Just make sure what ever % you program in that you dont over travel the servo.
freechip is offline Find More Posts by freechip   Reply With Quote
Help in setting up Optic 6 with 3 channel plane louisd Radios 1 Feb 15, 2005 06:06 PM
Help Needed Setting up Revo mix with JR 6102 T.J. Kong Micro Helis 9 May 23, 2004 04:36 PM
Need help setting up Flash 5x with elevons MaxxTrip Radios 5 Mar 02, 2004 02:14 PM
Need help with setting up Voyager E with Futaba 8UHF Jack N Sagris rec.models.rc.helicopter 2 Feb 10, 2003 01:04 PM
Need HELP Setting up an ECO8 with Futaba 8U in the Bay Area, California ropuri Electric Heli Talk 4 May 14, 2002 02:43 PM
Bored? Want to fight?
Join the RCGroups clan!
