Old Dec 05, 2012, 05:35 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
These smoked traces were most likely the effect of wrong polarity.
I strongly doubt that the equalisation current can reach such high values, but I will make a test to be sure.
Julez is offline Find More Posts by Julez
Old Dec 05, 2012, 08:59 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Unfortunately, not true Julez. Equalization current can easily smoke traces.
Quicky math with a fully charged 5000mAh cell with 1mOhm IR and a discharged cell of same specs:
2mOhm (aggregate cell resistance)
30mOhm (aggregate balance tap / connector resistance)
1.5V differential
1.5V / 32mOhm = 47A at connect.
Wimpy traces don't have a prayer. Suggest you use large packs with low IR and large voltage differential in your test to replicate the real world conditions of our RC Groups friends.
Agreed that with small packs with high internal resistance and low voltage differential (.1V/cell) there won't be an issue. However, with large capacity cells and larger voltage differential, making a universal recommendation without a disclaimer will alienate some folks as there will unquestionably be more smoked traces. The most disturbing part is many may never know since they're charging in parallel and could experience a lipoly fire as a result.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Last edited by mrforsyth; Dec 05, 2012 at 10:39 AM. Reason: correct typo in units.
Old Dec 05, 2012, 09:50 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
It is really a best practice to parallel charge packs with a 1.5v voltage differential?
Ohmic is offline Find More Posts by Ohmic
Old Dec 05, 2012, 01:25 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Mark
Wow, I have many parallel boards, and never ever thought about that possibility. I guess I would have smelled something if any traces burned away, but sure enough, I'll get the multimeter out tonight, and check them up just in case (and everynow and then after that). I'm a bad boy, and while you're discussing which one to plug first, I randomly plug mine, depending on which wire get in my fingers first when I grab a battery. Though, I always use a timer, and if for any reason, one battery is not used until the timer goes off (ex.: crash), then I charge that battery by itself. Otherwise, I know my batteries are always very close to each other. But it only bad management once, and take a full battery to make a mess I guess. Thanks for the tip!
RealGambler is offline Find More Posts by RealGambler
Old Dec 06, 2012, 01:53 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Ok, I will add a warning until my tests are finished.
Old Jan 28, 2013, 06:24 AM
Exaturbo is online now
Find More Posts by Exaturbo
Australia, NSW, Sydney
Joined Jan 2012
hi all.
just stumbled across parallel charging. didn't know it could be done.
this will save me a bunch of time charging big 6S 8000 packs !
i have 4x zippy 6S 8000 packs, wired up for 12S 16000 for use on my ebike.
what i want to do is permanently wire up 2x 6s packs in parallel using these parallel adapters from Hobbyking
http://www.hobbyking.com/hobbyking/s...arch=ec5%20par
and permanently parallel the balance taps using this http://www.hobbyking.com/hobbyking/s...=6s%20parallel
then parallel charge the pack as one 6S 16000 pack.
i would have 2x 6S 16000 packs and series connect them before the controller, giving me the required voltage for the controller.
i would split the series connection for charging.
and charge each 6S 16000 on a separate charger
as these would be permanently paralleled packs, as long as i make sure that the packs are within 0.050 volts (per cell)
it shouldn't matter if i connect the balance leads of the main leads first ?
this will save a boat load of time, as i currently charge each of the 4 packs on it's own.
now ill be able to charge 2 at a time, and having 2 chargers (now) means i can charge them all at the same time.
for reference, my chargers are the turnigy fatboy 8 chargers, and i have a meanwell 1000w PSU.
i know i wont get the maximum rates from the chargers with this supply, but it's still way quicker than what i have been doing till now.
i will also run a lipo alarm on each 6s 16000 pack for low voltage warning, set at 3.5v / cell.
can anyone see any major issues with this setup ?
Jason.
Exaturbo is online now Find More Posts by Exaturbo
Old Jan 28, 2013, 08:58 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Jason!
Everything is fine as you describe it! Even 0.1V difference won't be a problem.
You could even charge all your packs at once on one charger using such a parallel adapter:
http://www.progressiverc.com/adapter...arallel-boards
I charged my 16s 16Ah ebike battery with less than 4A current, and it was always fully charged in the morning.
So unless you are in a hurry, I wouldn't take higher charge currents than neccessary.
Old Jan 28, 2013, 06:46 PM
Joined Jan 2012
thanks for the confirmation.
Jason.
Old Feb 03, 2013, 02:35 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Can we have this thread stickied? Very valuable info here, couldn't find it again to recommend to someone
habitforming is offline Find More Posts by habitforming
Old Mar 01, 2013, 11:00 AM
rizky_p is online now
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
I didn't realized that different lipo capacity of the same Voltage can be charge in paralleled i always thought that it all needs to be the same capacity. Thanks Julez.
Just would like to confirm that charging this packs in paralel is safe (same state of charge)
2 x 6000mah 2S
2 x 5800mah 2S
1 x 5000mah 2S
in total there are 5 packs in total of 33600mah capacity in 2S configuration. Since my charger only got up to 10A (icharger 106) i'll set it to 10A and still saves charging time compares to charging them individually?
rizky_p is online now Find More Posts by rizky_p
Old Mar 01, 2013, 11:43 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Assuming that you'd normally charge at 2C or more (most modern batteries can take at least 2C), with "only" 10A capacity you wouldn't really save all that much time, except for the fewer unconnect/reconnect periods.
Even your smallest battery - the 5000mAh - could max out your charger at 2C, so by connecting them all together (33600 mAh), your max charge rate drops down to around 0.3C, and that's not going to save significant time.
Now if you had a bigger charger, say 30 or 40 amps, yes, you'd certainly be saving time to charge all that in parallel.
H2SO4 is online now Find More Posts by H2SO4
Old Mar 01, 2013, 11:58 AM
rizky_p's Avatar
Joined Apr 2007
I normally charge @1C and no higher.
Old Mar 02, 2013, 09:31 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Then it would safe you some time, and quite a bit of hassle.
Old Mar 02, 2013, 10:05 AM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Originally Posted by Julez View Post
Definitely not. The lower the power electronic components have to deal with, the longer their lifespan will be. It is even an exponential corellation, like half the power gives you 4 times the lifespan.
New to this
Looking at the PL6, Are you saying that useing it at it's 30 amp rating will shorten life? And does charging battery's at 3c to 5c makes a measurable difference in battery life.
It was my understanding that it made no significant difference.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Mar 02, 2013, 10:09 AM
So. Cal.
Your understanding is correct Dennis.
My iChargers have been run at full current on nearly every charge since the day I bought them several years ago and they're trucking along just fine. All well-designed electronics have headroom built into the design so I would not worry at all here.
Also, there's zero conclusive evidence that demonstrates that 3-5C charging has any deleterious effect on the usable life of a lipoly.
Mark
what is safer series or parallel charging of multi lithium packs? BING! Batteries and Chargers 13 Nov 10, 2003 07:04 PM
Re lithium and parallel charging Vanier Power Systems 1 Aug 12, 2003 02:40 AM
Parallel charging with isolation diodes? HankF Batteries and Chargers 4 Jan 05, 2003 05:22 PM
A Question About Slow Charging New NiMH Batteries? Coyoteair Electric Heli Talk 1 Jan 31, 2002 12:02 PM
