| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
If I were to go with the i106B+ to charge (4) 2200's in parallel, would this AC power supply handle it?:
http://www.hobbycity.com/hobbycity/s...idProduct=6477 Is there a better one I should use for this purpose? |
#47 |
Not even close. That PS is 15V/5A = 75W max. Charging 4 x 3s 2200 in parallel requires approx 102W charge power which means a PS rated for at least 120W. Since you are in the US I suggest you take a look at these HobbyLobby PS which are good value and will have some genuine warranty backup: http://www.hobby-lobby.com/powersupply.htm
For the scenario you describe you could get by with the 20A (270W) unit but get the biggest one you can afford. The ic106B+ is 250W output so needs a 300W supply to be able to give its all. |
#48 |
Thanks for all your great advice and help kgfly, I'm heading in the right direction now, thanks to all you guys and this excellent forum.
#49 | |||
Proud to eat Kraut ;-)
Although I can say from experience, that bad things will most likely not happen, it would not be wise to connect a depleted 400mAh pack and a nearly full 4000mAh pack. If one is fully depleded, and th other one has, let's say, like 25% left, then it is allright. You catch the drift. Quote:
#50 |
I just finished building all the cables and I received the power supply. For charging (4) 3S 2200's, what settings should my charger be set to?
#51 | ||||
Southern Pride
Why I modified my LBA6 years ago http://www.rcgroups.com/forums/showp...&postcount=189 Quote:
#52 | |
Your charging in parallel, so you add up the capacities. so 4*2200=8800 mAH, so 1C charge rate would be 8.8 amps. Just set your charger up like you were charging a 3S 8800 mAH pack. Remember when your in parallel with packs your not adding up the voltage, the voltage stays the same, just your capacity goes up. So make sure and set it at 3S. CJG |
#53 |
Thanks for the reply rotortuner, I have had this charger for just a few days now and have only charged one battery, by itself, so I'm pretty green over here. You are saying I should set the charge rate to 8.8A?
#54 |
Karma Police
Yes, that is exactly right. By combining your packs in parallel you have in essence created one 3S pack with a capacity of 8800 mAh. This pack can now be charged as a 3S pack of 8.8 Ah capacity, which at a 1C rate which equals 8.8 amps.
#55 |
Thanks guys, I understand the theory of it now as a direct result of your effort and patience, but I was wondering where exactly to set 8.8A on the charger. This is my first time using a charger without the idiot-lights (Eflite stock), so I wanted to make absolutely certain not to accidentally test the lipo-bag too.
Are there any other settings I should be paying attention to or are the defaults pretty good with the iC106B+? Would I be able to use the Fast Charge setting in parallel? |
#56 |
From what I see in your picture, it looks good .
Using Fast charge setting will be the same. It really doesn't do much! It might cut 5 minutes off of charge time? DanT |
#57 | |
Karma Police
.You could use fast charge mode as well to slightly reduce charge time by stopping the charge at around 95% capacity. |
#58 |
LiPo, 3S, 8.8A (if all four ar 2200mAh).
[EDIT] - Oops, should have refreshed the page. I see you already have all the good info from the others. |
#59 |
Thanks again for all your help guys, there is no way I could have figured all this out without you.
One last question, would it be a good idea to run a storage mode charge in parallel, before putting the batteries away, say for a week or two at a time? |
#60 | |
One comment on your parallel harnesses - You might keep an eye on the balance of your packs for the first few charges as you will be getting some IR drop in your long balance leads during the CV balance phase that may increase balance time. Ideally, the balance leads should be kept as short as possible to maintain the lowest voltage drop and highest accuracy during balancing. While it's not likely to present an issue, it's best to keep an eye on it to fully characterize your setup. -Mark |
| Thread Tools | |
| what is safer series or parallel charging of multi lithium packs? | BING! | Batteries and Chargers | 13 | Nov 10, 2003 08:04 PM |
| Re lithium and parallel charging | Vanier | Power Systems | 1 | Aug 12, 2003 03:40 AM |
| Battery flight packs, parallel charging? | Wan | rec.models.rc.air | 9 | Aug 06, 2003 04:04 AM |
| Parallel charging with isolation diodes? | HankF | Batteries and Chargers | 4 | Jan 05, 2003 06:22 PM |
| A Question About Slow Charging New NiMH Batteries? | Coyoteair | Electric Heli Talk | 1 | Jan 31, 2002 01:02 PM |
