| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
You have to connect all 4 sets of balance leads in parallel but only one connection to the charger is needed.
#32 |
Julez
Can you slip all those lipo s ( in post #1 ) in to a lipo sack or container, so that you can leave and come back when they are done ( with safety)
I dont want to have a flame out in my computer |
#33 | ||
Proud to eat Kraut ;-)
The more packs you charge in parallel, the more you should make sure that the packs do not differ in state of charge. Life expectancy is not influenced in any way. Quote:
As a kid I found an ammo box of the german Wehmacht, perhaps I will use this as a charge bunker, should I get into frequent LiPo charges next season. At the moment, I almost only charge A123. Last edited by Julez; Oct 26, 2008 at 11:24 AM. |
#34 |
Julez
Can I parallel a 400 Mah 3s and a 1500Mah 3s at 1.9 A
Both in same state of charge 11.3 V And not be overcharging the little 400 Amp wise ? |
#35 |
Yes, this should certainly be possible.
Just think what would happen if you replace the 1500mAh pack with 3 pieces 400mAh packs. You'd have about the same capacity, but I see no reason why one particular pack should overcharge. Now if you combine the 3 400mAh packs into the 1500mAh pack, there is still no reason why the 400mAh pack should overcharge.
#36 |
Julez
Thats just great
All my 3S packs at once, that tends to make things easier in the battery department when preparing for the weekend , of course with proper protection around the batteries in case of accident |
#37 |
Hi Julez,
may I ask why on first picture the packs are connected from both sides ie. with balance connectors AND load connectors? Is the load connector for charging also? |
#38 |
On my setup it will only balance all the cells if I charge in series.
I think it's because of the type of charger I use? I'm using a Turnigy Accucell-6 charger with a CCB-723TPQF board . http://www.hobbycity.com/hobbycity/s...CB-723TPQF.jpg If I try and charger in parallel ( say , two 3 cell TP 1320 ) using this setup the charger will only show that 3 cell are being balanced not 6 cell. So I guess I would have to have a charger that charges using the balancing taps to charge in parallel ? DanT |
#39 | |
Attached is a photo of one of my parallel cable sets in action. Mark |
#40 |
mrforsyth,
Are you saying you don't use a separate balancer after charging in parallel? Not even once in a while? Do you use the packs individually or all together? |
#41 | |
My packs are discharged individually. Voltage after discharge is typically around 11.3-11.5V. Also, I frequently charge 3S 5000mAh packs in parallel with 3S 2100mAh packs. As they're in parallel and at the same voltage, this is completely safe. Mark |
#42 | ||
One can charge 100 pieces of 3s packs in parallel, but the charger will still only "see" 3 cells. |
#43 |
This is a great thread julez - very well done the pictures are great too!
So really what is happening here is that, with for example 2 x 3s packs connected in parallel, and the balance connectors also paralled ( in the right configuration of course ! ) the charger sees 1 big 3s pack, and although it also sees 3 cells in that pack, each cell it "sees" is really 2 x cells connected in parallel, and we are relying on the fact that each pair of cells will even each other out and therefore be balanced ? I think you are also saying that packs of different capacities are also fine to do like this ( same cell count of course ) and they do not necessarily have to be at the same state of charge when they begin charging. ? I am going to make up the balance plug parallel connector PCB that you show, and laso parallel the main leads too because I am likely to be charging like this - but at high rates so the balance wires will be unhappy with large charge currents. Again...nice one Julez!!
#44 |
Hi Julez
What is your opinion on putting 4Amps down the balance wires to charge your batteries
Im beginning to think its OK now , when first I heard, I didnt like the idea of putting that current down those small wires |
#45 | |
I personally prefer to have all of the main connectors handling the charge current and use the balance connectors to monitor individual cell voltage and provide balancing. Not entirely necessary, just my preference. |
| Thread Tools | |
| what is safer series or parallel charging of multi lithium packs? | BING! | Batteries and Chargers | 13 | Nov 10, 2003 08:04 PM |
| Re lithium and parallel charging | Vanier | Power Systems | 1 | Aug 12, 2003 03:40 AM |
| Battery flight packs, parallel charging? | Wan | rec.models.rc.air | 9 | Aug 06, 2003 04:04 AM |
| Parallel charging with isolation diodes? | HankF | Batteries and Chargers | 4 | Jan 05, 2003 06:22 PM |
| A Question About Slow Charging New NiMH Batteries? | Coyoteair | Electric Heli Talk | 1 | Jan 31, 2002 01:02 PM |
