Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
Old Oct 05, 2008, 07:52 PM   #16
...I once connected a fully charged and a fully discharged pack (100% charge difference), and the current was about 2C initially
That's "2C" not "2A" right ? So if they were 1000mA packs it would have been about 2A or 3300mA packs about 7A ?
While the resting voltages might have a considerable difference, as soon as a pack is charged, its voltage rises rapidly, and the voltage of a discharged pack decreases rapidly, this making the actual voltage difference of 2 connected packs fairly small.
Yes, this is the key. About the middle 80% of the discharge curve is very flat so the voltage differences amongst several partially discharged packs are likely to be small. This is also combined with the fact that you are charging via the thin balance leads which will act as resistors reducing inrush current.
kgfly is offline Find More Posts by kgfly   Reply With Quote
Old Oct 06, 2008, 06:05 AM   #17
Proud to eat Kraut ;-)
Julez's Avatar
Yeah, I tested it with 2 2s 850mAh packs, and the current was around 1.7A.
Julez is online now Find More Posts by Julez   Reply With Quote
Old Oct 07, 2008, 03:24 AM   #18
I assume that was with lipo.
Since A123 have more voltage drop under load,
I would expect the current should be even lower.
kjetilmh is offline Find More Posts by kjetilmh   Reply With Quote
Old Oct 07, 2008, 09:07 AM   #19
Julez's Avatar
I can test it tonight...
Old Oct 07, 2008, 06:52 PM   #20
Karma Police
Excellent thread Julian! Thanks for the well thought out and detailed explanation of parallel charging LiXX. This is sure to become a helpful and often cited reference.
- David
write2dgray is offline Find More Posts by write2dgray   Reply With Quote
Old Oct 07, 2008, 07:35 PM   #21
Quite so! Well done Julian. I have added a link to this thread in the "How to" section of this popular reference page: http://www.helifreak.com/showpost.ph...71&postcount=1
Old Oct 13, 2008, 04:16 PM   #22
Julez's Avatar
Hi!
I just connected a fully charged, and a fully discharged 4s 1100 A123 pack.
The initial current was 10A (not more than my usual charge current), and it rapidly decreased. After a minute, I had less than 2A.
Old Oct 13, 2008, 05:09 PM   #23
Dan Baldwin's Avatar
Originally Posted by Julez
Hi!
Your usual charge current is 9C ?!?!
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin   Reply With Quote
Old Oct 14, 2008, 04:01 AM   #24
Hi!
Old Oct 14, 2008, 08:44 AM   #25
Julez's Avatar
Dan
Yes?
A123s don't mind
Old Oct 26, 2008, 03:11 AM   #26
Julez,
I have begun following your thread with Junsi over at the iCharger forum, and was very impressed with your knowledge and devotion in assisting with the development of the 1010b and 106B+ chargers. I very much appreciate that you took the time to help others like myself begin to comprehend what it is we need and why, thank you!
In reviewing your parallel charging method as outlined in this thread, I was hoping you or another knowledgeable member could point me in the right direction.
I have (4) brand new 3S 20C 2200 Zippy's that have never been charged.
I am looking to purchase a charger that will charge and balance all four packs simultaneously, and yet use them separately or individually.
I noticed you referenced this pic as being another good example of parallel configuration or connection:
http://www.rcgroups.com/forums/showp...postcount=1895
This is exactly what I am looking to do.
Can you tell me what charger I should be looking for? Is there a single charger that is capable of what I am seeking? Is there any danger or folly in what I am asking to be able to do?
Thanks again Julez, for your knowledge and patience.
GreenBar0n is offline Find More Posts by GreenBar0n   Reply With Quote
Old Oct 26, 2008, 04:15 AM   #27
To charge 4 x 3s 2200 in parallel as 3s4p 8800 at 1C you need a charger capable of at least 100W output at 8.8A. The iC106B+ (6s, 250W/10A) would be ideal. You would need top make up an appropriate balance-charge adapter to connect the balance leads of all the packs in parallel and a matching main lead adaptor, as shown in the first post of this thread.
Old Oct 26, 2008, 04:34 AM   #28
Thank you kgfly, it's hard to understand why not many people have heard about this already, if it is as simple as this. I am most surprised that manufacturers aren't selling parallel cables as an option or included equipment, why aren't they touting this as a selling feature?
Is there anything else I should be cautious or aware of when charging in parallel?
Will the life expectancy of the packs be diminished in any way?
Old Oct 26, 2008, 05:06 AM   #29
It is not an off-the-shelf solution and many are reluctant to take a risk that they might get it wrong and cause a disaster. Given the potential bad outcomes with LiPo batteries being cautious is wise. I have gone down the path of having more chargers rather than charging more packs in parallel on the one charger, in part due to my interest in the chargers themselves and in part because until recently I too was concerned that the initial inrush current might be damaging. Having learned more and having moved part of my fleet to A123, I am no longer concerned about that aspect.
If you are concerned, send a PM to Rampman on this forum, he makes a parallel charging adapter board which guarantees to limit the cell-to-cell current to 1A, which is bound to be very safe IMO.
Old Oct 26, 2008, 05:40 AM   #30
Hi
The Cellpro 4S charges through the balance leads ., I guess you know that
If I wanted to parallel, charge and balance , 4 off 3S 900Mah batteries
can I just connect ( charge ) to one balance lead, and connect the others together, in parallel
NX-687 is offline Find More Posts by NX-687   Reply With Quote
what is safer series or parallel charging of multi lithium packs? BING! Batteries and Chargers 13 Nov 10, 2003 08:04 PM
Re lithium and parallel charging Vanier Power Systems 1 Aug 12, 2003 03:40 AM
Battery flight packs, parallel charging? Wan rec.models.rc.air 9 Aug 06, 2003 04:04 AM
Parallel charging with isolation diodes? HankF Batteries and Chargers 4 Jan 05, 2003 06:22 PM
A Question About Slow Charging New NiMH Batteries? Coyoteair Electric Heli Talk 1 Jan 31, 2002 01:02 PM
Bored? Want to fight?
Join the RCGroups clan!
