Old Oct 01, 2008, 07:56 AM
Johan Moelich
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
ParkZone Radian Electric Glider for FPV
Have a look at this: http://www.parkzone.com/Products/Def...ProdID=PKZ4775
The Parkzone Radian looks like an ideal FPV plane and comes with brushless motor and 30A ESC. You can also choose a complete RTF Package with 2.4GHz 5-channel radio and lipo included. I spoke to our local supplier today who flew their demo model and he says this plane flies like a dream with vertical climbing potential and good handling. I'm definitely getting one!
Moelich73 is online now Find More Posts by Moelich73
Old Oct 01, 2008, 08:08 AM
Sweden
Great! It looks like an Easy Glider Pro - only cheaper!
How does this "Z-foam" material compare with Multiplex' Elapor though? Electronics' quality?
Dimitris
Dimitris76 is offline Find More Posts by Dimitris76
Old Oct 01, 2008, 08:11 AM
Sweden
Ooops! No ailerons?
Old Oct 01, 2008, 08:28 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
Yeah no ailerons but I'm sure it can be added if you feel adventurous. There's a discussion about it in the RCGroups Sailplane Forum
Description of foam types found somewhere on the net:
"EPP is very hard to break. I have EPP planes that have bounced 6 feet in the air without breaking. But it is somewhat rubbery so you end up having to stiffen it with spars and shafts. In the case of many EPP planes, it is the supporting structure that gives the EPP some body that will need repair, not the foam.
Elapor and Zfoam seem to be about half way between the two in their ability to take a hit, stay in one piece and hold their shape. In the case of these foams, they may survive a hit but the foam may be dented so you need to have a way to expand the foam to return the item to its original shape."
Old Oct 01, 2008, 08:35 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
Here's the PKZ 480 Parkzone motor. The ESC is from E-Flite.
Old Oct 04, 2008, 09:51 PM
Philippians 4:13
Seward, NE
Joined Nov 2006
Looks like a nice plane. Did you see it flying inverted on the vid?
ty_horn is offline Find More Posts by ty_horn
Old Oct 05, 2008, 12:48 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
I just watched the video now, didn't see it before. Looks like a really good flier. I wonder how it will handle in wind? And if it would perform well with ailerons added (Although I don't think it's really necessary for FPV on this one).
Old Oct 05, 2008, 08:46 AM
Joined Feb 2004
Those wings have so much curve to them it'd be hard to find a place straight enough to add ailerons.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Oct 05, 2008, 09:30 PM
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I like it. Those wings do have a lot of curve to them, but I bet that could be remedied easily enough.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Oct 05, 2008, 09:31 PM
Philippians 4:13
Seward, NE
Joined Nov 2006
Hey skunk. Long time no see :-)
Old Oct 06, 2008, 12:45 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
How would you get the curve out of them? Cut and paste?
Old Oct 06, 2008, 01:48 PM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
So I saw the Radian in action today... very impressive! It climbs vertically with no problem, glides really slow, turns on a dime, and looks like an overall good performer. It looks and feels very strong and light. There's enough space in the fuselage for FPV gear. I'm definitely getting one!
Old Oct 06, 2008, 01:53 PM
gwh
Fort Worth, Texas
Joined Dec 1996
I think the Eflite Apprentice has alot of potential for FPV also. The fuseage is huge and the 63" wing has some leading edge droops to aid low speed stability.
http://www.horizonhobby.com/Products...ProdID=EFL2725
gwh is offline Find More Posts by gwh
Old Oct 06, 2008, 02:19 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I redress the Easystar wing tip only by modeling them with my hand. I put pressure on the other side.
You can also use boiling water, just let flow some hot water on tip (few seconds) and add pressure with your hand
VRflyer is offline Find More Posts by VRflyer
Old Oct 06, 2008, 03:25 PM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
I didn't know you can do that! Maybe I should get an extra wing for the Radian and add ailerons...
UK: LittleStar Electric Glider for sale at BEFA Technical Workshop Neil Stainton Aircraft - Electric - Airplanes (FS/W) 2 Nov 01, 2003 12:30 AM
UK: LittleStar Electric Glider for sale at BEFA Technical Workshop Neil Stainton Aircraft - Sailplanes (FS/W) 0 Oct 30, 2003 04:29 PM
Seledkin hollow molded electric glider for sale neilo Aircraft - Electric - Airplanes (FS/W) 10 Jul 27, 2003 06:16 PM
Mini floh Electric glider for sale Steve H. Aircraft - Electric - Airplanes (FS/W) 5 Oct 21, 2002 06:50 PM
