Well yeah, so what you are suggesting is that everyone with an Extra/Yak/ Or a 3d capable model, should only putt putt around in circles, as to stay safe with an airplane?! That's what scale Cessna's are for! You are telling everyone to do no manouvers! |
Netherlands, NH, Edam
Joined Jul 2004
I routinely put my planes through a level of stress that would rip a full scale airplane to bits and pieces and up until now I haven't lost any due to structural failure. So to my opinion and experience Jim wasn't doing anything wrong here, frankly he probably saved the plane from a crash at a later date that might not have ended this well as the pilot would've been his buddy, who most likely has not practized this scenario in the simulator, hence kudos to Jim for saving his buddy's airplane. Cheers, Sander. |
How do we know the limits?? Are we supposed to buy some machine that will keep pulling on the plane until it snaps? Then we will know?? Many modelers probably don't worry about the limits, if the plane was high quality [Maybe Jim skipped some steps(I don't know)] and he did that maneuver (Sorry if I spelled it wrong, No one is perfect) this would have never happened. I see people at the field do WAY more stressful things to their planes, without EVEN CONSIDERING the plane might fall apart. But from your post it seemed as if everyone should monitor their planes (Which they all do) But to a point where a person has to obsess over their plane and fix every last tiny crack. [Which in reality will do NO HARM] |
Fredericksburg, VA
Joined Jan 2004
[QUOTE]How is one to know the structural limits of a model airplane? Due to the scale factor they can take far more 'abuse' that a full scale airplane, hence other than trail-and-error it is hard to guesstimate how well the wing (or any other part of the airplane) is going to hold up under stress.[QUOTE]
Sander, you make a great point. It's virtually impossible for one to know, with any degree of specificity, the structural limits of the airplane they are flying. And even more so, it's impossible to tell if they are nearing those limits while in flight. Honestly, it takes experience, which it seems you have as well as Jim. It takes an understanding of structural design, not at an engineering level, but a basic understanding of what a strong structure looks like versus one that was built light (intentionally) for improved aerobatic performance. The variables get even harder to sort out if the airplane was built from a kit vice an ARF. So, when you have inexperienced modelers out there "abusing" their airplanes, it creates a safety scenario that concerns me. Simulator practice is a great way to mitigate what we can't always predict. Not abusing your equipment and being smart is another way. MarcinB1995, you made my point for me: Quote:
Oh, another point, if I may: if you decide to abuse an airplane like that (meaning one that was recently repaired), make sure it's YOUR airplane and not your buddy's! Honestly, it's comical ... "I ripped the wing of my buddy's airplane, but made an amazing save ... hoorah for me!" |
Joined Jul 2004
However since these are model aircraft and require some amount of DIY to get them flyable it also comes down to how well it is constructed by the pilot. Using the wrong type of glue for example to glue some essential parts could reduce the ability of the airplane to withstand stress and cause for failures. So it is a combination of common sense, experience and not straying to far from the recommended setup in my book. Cheers, Sander. |
[QUOTE=AIVIA][QUOTE]How is one to know the structural limits of a model airplane? Due to the scale factor they can take far more 'abuse' that a full scale airplane, hence other than trail-and-error it is hard to guesstimate how well the wing (or any other part of the airplane) is going to hold up under stress.
Yeah you're right. I first fly around, then I check over the plane, and then I go and do some stunts, I don't just send it up and HOPE that it will keep together, though. I do not know if Jim did a snap roll at no throttle, full throttle, or even half throttle as the video doesn't show that. He should of started by "Putting" around, then check the plane, do mild maneuvers, check the plane, then go crazy after once again checking over the plane. If he did that he can safely say it wasn't his fault and he can be considered an RC "Hero" If he just took off and went crazy, we can obviously see who's fault it was. By the way, Why was Jim flying his buddies plane after repairs instead of his buddy ![]() Quote:
But if you buy an Avistar and try to do 3d with that, and the plane breaks apart, it is probably your fault. |
| Thread Tools | |
| Discussion May 07 Cape Cod Ma. video Guppy & Angelo falls off the Cliff... Ouch | fvigg | Slope | 0 | Jun 27, 2007 04:58 PM |
| Careful! Video-Safe and Sane Landing Approach-NOT | Paul Naton | Slope | 7 | Dec 05, 2006 07:34 PM |
| Help! Lama 4 in 1 chip falls off after hard landing!--with pictures | nuv22 | Coaxial Helicopters | 6 | Jul 16, 2006 03:21 AM |
| Range check adivice - short range after BEC cut off !!! | JensJakob | Foamies (Kits) | 0 | Aug 08, 2001 01:38 AM |
