This thread is privately moderated by jbourke, who may elect to delete unwanted replies.
Old Oct 03, 2008, 01:06 PM
MikeSt is offline
Find More Posts by MikeSt
Toronto,Canada
Joined Jul 2002
Jim,
Originally Posted by jbourke
As for how to fly a plane with one wing, consider that the remaining wing has a lot of drag so it would be very hard to fly knife edge with the wing on the bottom. Putting the wing on the top helps the plane stay in knife edge. I consciously chose to put the wing on top and keep it there.
Not knowing much about aerodynamics, why would top vs bottom make a difference?
So how different did the plane "feel" compared to flying KE with two wings?
Do you think it would be even possible to take-off with one wing? With the 3d "monster power-weight ratio, as is common these days, maybe a "burst of power" with elevator would be enough to get it in the air, and then quickly transition to knife edge. ?
MikeSt is offline Find More Posts by MikeSt
Old Oct 03, 2008, 01:29 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
I don't think I can adequately explain it here, but basically anything that moves through the air produces drag against the movement. For a plane to fly in knife edge, it must be angled with the nose away from the ground. This is easier to do if the drag from the wing is helping, rather than hurting, that effort. The wing can only help if it is pointed straight up.
It wanted to roll left, so I had to hold right aileron. It wanted to yaw left, so I needed right rudder. It wanted to pitch down, so I needed up elevator.
It was not at all like flying normal knife edge. A properly trimmed airplane will fly knife edge almost on its own. A little bit of rudder is all that is needed.
That would be very difficult. The challenge is that during the initial acceleration there isn't enough airspeed over the control surfaces to overcome all the imbalanced forces. The plane is highly unstable in any orientation other than knife edge.
Also, I wouldn't want to have the engine anywhere near full RPM with the plane in this configuration!
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Oct 03, 2008, 03:33 PM
MikeSt is offline
Toronto,Canada
Joined Jul 2002
Ahh, ok, I get it now.
It wanted to roll left, so I had to hold right aileron. It wanted to yaw left, so I needed right rudder. It wanted to pitch down, so I needed down elevator.
Cool ! .. thx for the insight.
Jim
Oh, c'mon, throw together a cheap electric foamy, and cut off one wing.
You know you want to try it
Old Oct 04, 2008, 05:25 PM
James Frolik is offline
Find More Posts by James Frolik
Long-Time Member
James Frolik's Avatar
Cologne, Germany
Joined Dec 1996
Wow. I've already watched that video about 20 times and I smile every time. Is Keith going to fix it again or simply replace the model?
I hope to spend some of my 2008 Christmas bonus (yes, we get an extra month's salary here) on Real Flight. Will the program by then have a setting with Keith's one-wing Yak? And maybe get some BCRCC members lined up some day and record them yelling "Way to go!" so to imbed additional sound effects.
James Frolik is offline Find More Posts by James Frolik
Old Oct 04, 2008, 05:49 PM
pyrobus is online now
Find More Posts by pyrobus
outstanding in the left field!
pyrobus's Avatar
USA, IL, Marengo
Joined Feb 2007
Fly the pieces
Beautiful work. Bet you could do that again! Maybe a part of your new airshow act the one wing yak attack. You could practice a few one wing tricks and just fly around a bit more next time? Brings a new meaning to the phrase "fly the pieces"
Pyro
pyrobus is online now Find More Posts by pyrobus
Old Oct 05, 2008, 03:00 AM
flyinghigh is offline
Find More Posts by flyinghigh
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
I don't see any reason why the plane would prefer one roll orientation over another. The drag caused by the remaining wing imparts yaw only, assuming the plane is neutrally stable to begin with. Yak-54s have nice round fuselages and mid-wings, so they are about as neutral as you get. Of course, in the real world each axis is only in balance with all the pieces in place, so losing a wing will impart some amount of roll in some direction. That doesn't mean that the plane will stop with the wing up or down, though. Most likely it would just keep on rolling.
Holding the plane in knife edge and guiding it around required pressure on all three axes. By that, I mean that left on its own, it wanted to roll, pitch, and yaw. Finding the center position needed to keep the plane stable was really the only trick to the flight.
Understand that I only have about a minute of real-world experience with this. We can watch the video over and over, but in real time it all happened very quickly.
My thought process was something like "Let me try a snap roll at high speed...oh, hey, the wing fell off...let's see if I can find a control center to keep it stable...looks like that keeps it in knife edge...I'll try turning it...looks like pitch and roll are coupled...I'll just coax it around to my right...keep the airspeed the same and bring it down in the pattern...I'll just put it over here in the grass...hmmm...I bet I can land it...I'll try rolling it level and see what happens...ok, back to knife edge...and now let me give it a shot...hey it worked!"
If you read that while you watch the video you'll have a sense of what I experienced, and you can see that there isn't much time to learn about this flight regime. However, I have played with it a lot on RealFlight, mostly because I kept getting confronted by people who thought this behavior was unrealistic in the sim. It turns out that RealFlight has it correct, and I was only able to do this in real life because the sim prepared me for it.
Jim
Jim ,
Me and my son have flown enough cheap foam gliders to know when the wing falls off the remaining wing always points up. Flying rather well also.
Good Save!
flyinghigh is offline Find More Posts by flyinghigh
Old Oct 05, 2008, 04:55 PM
helifrek is offline
Find More Posts by helifrek
3D Printing Enthusiast
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
Awesome save jim, check this out!
http://www.youtube.com/watch?v=xprTl6cPdH0
helifrek is offline Find More Posts by helifrek
Old Oct 07, 2008, 11:45 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Incredible ! Way to go !
Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Oct 08, 2008, 03:36 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
I'm sad I missed all the fun, show up for chili and end up witnessing an amazing feat. As if your inverted pylon racing skills weren't already a great endorsement of RealFlight.
SteveM732 is offline Find More Posts by SteveM732
Old Oct 08, 2008, 09:54 PM
Marcinb is offline
Find More Posts by Marcinb
3D Soon-To-Be....
Marcinb's Avatar
Chicago
Joined Apr 2008
I could have landed that with NO WINGS!
Marcinb is offline Find More Posts by Marcinb
Old Oct 09, 2008, 02:20 AM
FrogChief is offline
Find More Posts by FrogChief
Russian Federation, Sakha, Yakutsk
Joined May 2006
Epic!!!
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
Old Oct 09, 2008, 03:01 PM
Marcinb is offline
3D Soon-To-Be....
Marcinb's Avatar
Chicago
Joined Apr 2008
I know RIGHT!
Old Oct 11, 2008, 08:25 AM
Brandano is offline
Find More Posts by Brandano
Well, once a wing is lost, the plane will still need some positive AOA to fly. In this setup apart from the drag considerations from the remaining wing, the wing that is left will tend to weathervane in the airstream. This will tend to make the plane stabler in KE when the wing that is left is kept pointing upward, it might well be impossible to do any maneuvering with the wing pointing downward. Any pitch (yaw now?) will tend to get the plane rolling through 180 degrees
Brandano is offline Find More Posts by Brandano
Old Oct 11, 2008, 03:39 PM
what_the?! is offline
Find More Posts by what_the?!
Adelaide,South Australia
Joined Jul 2003
golden!- one of the best videos ive ever seen in RC flying!
great composure and flying JB.
can you post the video as download-able?
i want to save it to my hard drive to show and email to others.
what was especially impressive is that you also landed it on the runway!!
nice.
Tim
what_the?! is offline Find More Posts by what_the?!
Old Oct 11, 2008, 04:02 PM
SteveM732's Avatar
Joined Feb 2008
nice.
Tim
http://youtubedownload.altervista.org
Discussion May 07 Cape Cod Ma. video Guppy & Angelo falls off the Cliff... Ouch fvigg Slope 0 Jun 27, 2007 04:58 PM
Careful! Video-Safe and Sane Landing Approach-NOT Paul Naton Slope 7 Dec 05, 2006 07:34 PM
Help! Lama 4 in 1 chip falls off after hard landing!--with pictures nuv22 Coaxial Helicopters 6 Jul 16, 2006 03:21 AM
Range check adivice - short range after BEC cut off !!! JensJakob Foamies (Kits) 0 Aug 08, 2001 01:38 AM
