OK, so I wanted some zip with my mCX. I had turned the poo out of the linkage with still no real zip. Enter swash mod.
As posted above, I bought a spare set of upper rotors, always nice to have on hand, and stole the screws. Then drilled the swash (while on the mcx) and put the screws in.
Here's where I departed from the previous methods. I took an old cx2 rotor, heck you could use carbon (which I may buy some and redo this) and I cut 4 SMALL sections. Then I used CA (man that is sticky) and glued them on top of the lower head ball rod
guide arms. This looks a little more stock and mainly, I couldnt find any tubing that small. Heck, when you look at it in person, you cant tell I did anything to it. The screws were a little loose, so I am trying to find the perfect thing to dip them in thats quick and coats them enough.
Anyway, this thing FREAKIN zips now. IF you havent done this, do it. I CANNOT believe the difference this makes. I'll try soon to make a video of it flying around. Now, if I can figure out a longer innershaft mod, then this thing will be perfect.
Thanks to those that came up with this. It is definately a MUST DO MOD if you are doing anything to your mCX.
Did I mention its zippy now. In ALL directions!
-----EDIT-----
Now, with this mod, if I lean full forward AND left, the swash
guide in the REAR comes out of track. I need to extend those now.
