Old Oct 18, 2008, 08:20 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Originally Posted by Bilbobaker
I think I know what you did. A picture would sure be sweet.
Sorry. Don't have a good closeup camera.
Originally Posted by Tres Wright
Have you flown it since making the mod?
Works great!
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Oct 18, 2008, 02:09 PM
METZ is offline
Find More Posts by METZ
UK oxfordshire
Joined Dec 2004
Picco z batteries?
Hi guys, i was just wondering if anyone here has tried making there own battery yet out of lets say 3 to 4 piccoz lipos in parallel? im guessing the flight time would be longer? anyone?...
METZ is offline Find More Posts by METZ
Old Oct 18, 2008, 03:26 PM
RFpro is offline
Find More Posts by RFpro
Stuttgart DE, Austin TX
Originally Posted by Martyn McKinney
I just finished a very simple mod for faster forward and reverse flight.
With a pair of sidecutters, I cut the flat portion of the right-hand arm going to the right hand servo (PASSENGER SIDE IF YOU DRIVE IN NORTH AMERICA) extending from the swash, in half.
There is a center reinforcing ridge on the top of the remaining arm (stub) which I removed with a sharp X-Acto knife.
I then mounted the cut off piece, still attached to the servo, on top of the stub connected to the swash and glued it with a drop of CA.
I didn't even have to remove the body and the trims barely needed adjusting.
The fix took about 5 minutes and when I find the time, I also might do the left and right.
BE CAREFUL WITH THE CA GLUE! Don't let any get into the swash.
What I found with this mod is: at full pitch the Outer Shaft Retaining Collar will slide at the swashplate!
John
RFpro is offline Find More Posts by RFpro
Old Oct 18, 2008, 05:41 PM
Toronto Canada
Joined Dec 2002
Full pitch? Do you mean full forward, which I guess is also full pitch.
I had no issues. Perhaps it is dependent on the final length of the swashplate arm.
Old Oct 18, 2008, 08:18 PM
purdueaero is offline
Find More Posts by purdueaero
Joined Oct 2008
Here Is my Modded MCX for night flight
-Bret
http://www.rcgroups.com/forums/showthread.php?t=940554
purdueaero is offline Find More Posts by purdueaero
Old Oct 18, 2008, 10:37 PM
strburst is offline
Find More Posts by strburst
Joined Oct 2008
Lipo & Charger
Has anyone had any problems getting the LiPo out of the charger? I need to use a small screwdriver or other sharp object to pry it upword to disconnect it from the chargers plug. Grasping the top edge is nearly impossible to remove it.
strburst is offline Find More Posts by strburst
Old Oct 18, 2008, 11:00 PM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
My friends is that way but mine is easy.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Oct 19, 2008, 09:46 AM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Originally Posted by madmike43613
Here's the Huey and CH53. The .007" thick plastic came in and the weights are down some.
The Huey is now 5.2 grams assembled and painted. The CH53 is 7 grams assembled, painted, and with landing gear.
To use the CH53 you remove the tail fin and landing gear so that removes 2 grams. They both fly well but of course times do suffer some.
Mike - where did you get these? I love scale planes and helis, those bodies look great!
I'm surprised you didn't get a response to your post, guess everyone looks at this as purely a sport heli, but I enjoy these more with scale looks.
For those that want to see those scale bodies, its Post 89 on page 6
Angelo is online now Find More Posts by Angelo
Old Oct 19, 2008, 09:51 AM
Tread is offline
Find More Posts by Tread
RC Freak
Tread's Avatar
Colorado Springs, CO
Joined Oct 2008
-Bret
that is one SICK mCX!! i love it, great job!!
Tread is offline Find More Posts by Tread
Old Oct 19, 2008, 09:57 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
This heli is incredible! I own an E-Sky Lama V2, a fairly good first heli, but the gyro hold for yaw is NOWHERE as good as this. On the Lama, throttle (cyclic?) changes effect yaw stability, so you can have the yaw fairly tamed, then it goes away as soon as you throttle up or down. It also drifts with flight time, so you "fly the tail" a lot. This mCX is rock solid! The smaller size also makes it a lot easier to fly in the small rooms my house has.
I do like the scale look of the Lama, and really want to learn more about those bodies Mike showed.
Old Oct 19, 2008, 10:09 AM
yodafm1e is offline
Find More Posts by yodafm1e
JediBiker
Tomah, Wisconsin, USA
Flybar paddle
try this if you wish,..
If you have extra WA 4#3 flybar paddles, cut 30 to 40% off the span. Sand lightly to get weight of each exact. Mounts right on to the MCX flybar,..the airfoil is nice and thin, and please put it on Aerodynamically correct. If you do not, you have canceled out Bernoulliís Principle, even though the airfoil is symmetrical. And the premise of the relative wind "Attaching a Boundary Layer" to the flybar paddle, will Never take place. Drag, vibration, bending/flexing of the flybar, and a group of other negative things Will take place.
Michael,..
yodafm1e is offline Find More Posts by yodafm1e
Old Oct 19, 2008, 10:25 AM
yodafm1e is offline
JediBiker
not complete Dave
[QUOTE=superdave420]"need" is sorta subjective my thinking behind the bassakwards paddles is that the TE will cut the air more and react faster.
Yes Dave it will "cut" the Relative wind easier,...however,..it Will Not form a Boundary Layer around the flybar,..and the flybar must have a reasonable Boundary Layer from LE to TE because it is a functioning airfoil.
Mikey G,..your friend in WI
Old Oct 19, 2008, 10:46 AM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
[QUOTE=yodafm1e]
To Mike. Good to see you picked one up.
I must say. Despite fluid dynamics / coanda , boundry layers etc... Works great mouted backwards. I do admit I'm probably trading energy to center the top rotor faster. But that's n acceptable trade off for me. Now if the paddles rotated about the flybar axis then I would totally mount them properly.
Ok now I need to start my way back down this huge hill
(climbed to Mission Peak summit this morning in Fremont CA. Great iPhone coverage up here)
t
superdave42 is offline Find More Posts by superdave42
Old Oct 19, 2008, 01:38 PM
Toronto Canada
Joined Dec 2002
I understand why airfoil paddles might be an asset when they are controlled, but on this heli they are not controlled and in my opinion the stock paddles offer no advantage over weights.
A thinner paddle would likely offer less profile drag, however.
Old Oct 19, 2008, 11:12 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
I don't think there's enough headspeed on these for the flybar weight shape to have much impact. Mine is the earlier version with cylindrical weights, turn them any direction and they have the exact same "airfoil"
Tres Wright is offline Find More Posts by Tres Wright
FAQ HoneyBee CP2 & Blade CP Mods, Repair, Upgrades and Fixes - Winter 06 thru Jan 08 SSG Scott Micro Helis 2663 Apr 28, 2011 10:34 AM
Discussion Blade CX2 mods? Pepperami Coaxial Helicopters 13 Feb 08, 2007 01:51 PM
Links to Blade Heli Mods jdbercic Micro Helis 0 Nov 15, 2005 09:28 PM
Blade runner mods? grant31781 Scratchbuilt Indoor and Micro Models 0 Jul 05, 2005 01:34 PM
Yippee! Blade runner mods (good ones) dentflyer BladeRunner Heli 2 Dec 28, 2004 09:37 PM
