This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Sep 28, 2008, 10:55 PM
The Don is offline
Find More Posts by The Don
Trader Rating: 695
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 695
For Sale
Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED)
I have some replacement 64mm EDF fan units for the EDO model (F-4, F-15) and some of the Hobby Lobby EDFs. Some models require the inlet lip to be removed so you may have to cut this off but that is easy to do.
Each set includes:
1 rotor
1 EDF housing
1 4mm screw
1 rotor plug for 2.3 mm shaft
Price:$11 per set plus $3 shipping for first class or $6 for priority mail.
I also have available special rotor plugs machined for use with 3mm shafts. They are identical to the stock one but are made to accept 3mm shafted motors instead. These are the same plugs I include with the Wicked EDF motors. They are an additional $5 each.
Don
The Don is offline Find More Posts by The Don
Old Sep 29, 2008, 10:01 AM
jhaywood is offline
Find More Posts by jhaywood
Trader Rating: 32
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
Trader Rating: 32
Sent you a PM...
jhaywood is offline Find More Posts by jhaywood
Old Oct 26, 2008, 12:34 PM
The Don is offline
Trader Rating: 695
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 695
Priced reduced on remaining EDF units.
Old Nov 03, 2008, 10:19 PM
Doubletap is offline
Find More Posts by Doubletap
Trader Rating: 183
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Trader Rating: 183
Don, I need one of these fans plus a 2.3mm plug. Sent you PM.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Nov 19, 2008, 09:29 AM
RCAV8R13 is offline
Find More Posts by RCAV8R13
Trader Rating: 20
I'm goin' Falcon nuts
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Trader Rating: 20
Hey Don,
What size is the motor housing?
Kip
RCAV8R13 is offline Find More Posts by RCAV8R13
Old Dec 06, 2008, 09:48 PM
yankeecanuck is offline
Find More Posts by yankeecanuck
Trader Rating: 40
Canada, BC, Victoria
Joined Sep 2003
Trader Rating: 40
Don, what would be my cost for one unit w/cheap shipping to Canada?
yankeecanuck is offline Find More Posts by yankeecanuck
Old Dec 06, 2008, 09:53 PM
The Don is offline
Trader Rating: 695
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 695
First class international will be $4.50 for one unit.
Don
Old Dec 06, 2008, 10:17 PM
Trader Rating: 40
Joined Sep 2003
Trader Rating: 40
Thanks, I'll check the motor and shaft size tomorrow and let you know.
Don
Old Dec 07, 2008, 01:27 AM
earaoz is offline
Find More Posts by earaoz
Trader Rating: 16
Winnipeg, Canada
Joined Apr 2007
Trader Rating: 16
Will this EDF work with the HL F18 (Starmax)?
E
earaoz is offline Find More Posts by earaoz
Old Dec 07, 2008, 01:45 PM
The Don is offline
Trader Rating: 695
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 695
Depending on which version, you may have to remove the inlet lip on the EDF housing. I just cut it off with scissors.
Don
Old Dec 07, 2008, 10:24 PM
Trader Rating: 40
Joined Sep 2003
Trader Rating: 40
I have an outrunner diameter of 25mm. Will this fan unit fit this motor size?
Help! A problem I am lucky to have…Need a home for 2 EDF fan units. DWA Foamy EDFs 13 Mar 27, 2008 02:52 PM
looking for info on hobby lobby F16 ARF derailed Electric Ducted Fan Jet Talk 19 Nov 10, 2003 04:46 PM
WTB.. 4 Kyosho fan units for EDF project gbruce Aircraft - Electric - Airplanes (FS/W) 8 Sep 16, 2003 10:25 PM
Two New DMC-20BB performance Motors for the EDF-50 Fan Units for sale or trade KZZ Aircraft - Electric - Airplanes (FS/W) 4 May 17, 2003 10:55 PM
New Hobby Lobby Jets balch Electric Ducted Fan Jet Talk 7 May 10, 2002 12:59 PM
