Old Feb 14, 2003, 12:23 PM
MAKODS is offline
Find More Posts by MAKODS
N.Y.
Joined Jan 2003
Question
DC battery charger hook up.
I am looking at chargers that also discharge. I see that they are all DC only though. My question is; could I hook up a DC charger to a 12volt model train transformer for inside use rather than having to go by a deep cycle battery? Thanks.
MAKODS is offline Find More Posts by MAKODS
Old Feb 14, 2003, 02:25 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If the model train transformer can provide a regulated, stable 12V DC output under several amps load, yes.
..a
Old Feb 14, 2003, 06:36 PM
MAKODS is offline
N.Y.
Joined Jan 2003
Thankyou, I was hoping the answer was yes!!
Old Feb 14, 2003, 08:27 PM
bjsiegel@texas.net is offline
Find More Posts by bjsiegel@texas.net
EFlight=Fun,Big-T=BIG FUN
San Antonio, TX, USA
Joined Jan 2001
WHOA! HOLD IT!
Most train power packs do NOT have a regulated output for the throttle and the Accesory outputs are usually limited DC or AC only. Check the train power pack carefully.
Does it have an output (usually accesories) OTHER than the throttle? Is this output DC? What is its rating in Volts, Amps or VA?
It is NOT recommended to use the throttle output - the volts is variable and is typicaly NOT regulated - as load varies, so does the volts - this is part of the reason trains slow down on an upgrade.
A rating of 100VA for the pack with 12V DC output sounds good BUT... 100VA/12V=8.3Amps absolute MAXIMUM output - and most packs can NOT do that on the accessory output - they will fry themselves. Most train packs only offer 10VA to maybe 30VA, seldom more.
There are some large capacity power packs (our club uses a 20A, 12V DC supply for the LARGE layout) and some DCC (Digital Command Control) packs offer 5A or 8A outputs. These tend to be pricey.
A good 12V supply can be made from an old PC power supply - search Ezone. These power supplies are readily available - often free ofot the asking (want the old AT type, not the ATX type) Also Radio Shack has a GREAT deal on for a 25A 13,8V (car battery voltage) power supply for $60.
Bernard "Crash" Siegel
AMA, San Antonio Prop Buster
NMRA, San Antonio N-Track Model Railroad Assocation
bjsiegel@texas.net is offline Find More Posts by bjsiegel@texas.net
Old Feb 14, 2003, 09:43 PM
MAKODS is offline
N.Y.
Joined Jan 2003
I guess I will probably use the deep cycle battery that I use for my trolling motor then. Thanks.
Can I hook my Jeti Mini Charger to a car battery charger ? NetForce2K Parkflyers 0 Jul 05, 2002 12:06 PM
IntelliPeak AC/DC Digital Pulse Battery Charger Flying Cat Aircraft - Electric - Airplanes (FS/W) 0 Jun 20, 2002 03:19 PM
How do I hook up two brushless speed controllers to one receiver and battery? dom Foamies (Kits) 1 May 01, 2002 02:48 PM
Pyramid AC/DC Converter VS. Car Battery Charger Inverted-3D Electric Heli Talk 6 Jan 13, 2002 09:02 PM
